Old 03-17-2003, 08:29 PM   #1
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
Default 1st CEL with light mods...HELP
Got my first CEL today.
Only mods are MBC @ 15.5 in third (never going over 1.1.mpa in 5th), and Vishnu's EMI adaptor.
Still runs great, nothing out of the ordinary.
What can be happening?
Drew
Drew888 is offline   Reply With Quote
Old 03-17-2003, 08:49 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: 1st CEL with light mods...HELP
Drew
Could be a P0420 or something else.
You should plug a code scanner in and read it. Some auto stores like Autozone will do it for you. The dealer might charge you 60 bucks for that and probably wouldn't like what you have done. You can buy an OBD-2 scanner (reader, eraser, systems monitor) for about $140 at Autozone.
I just cleared one for a friend with a 2002 RS. He called the dealer and told him that I had a scanner, and the dealer said to do it, since there is no reason to take it in for them to do it.
It was a P0420 on a stock RS.
z&cobb is offline   Reply With Quote
Old 03-17-2003, 10:30 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Re: 1st CEL with light mods...HELP
Given that his only admitted mods are a boost controller and a Vishnu EMI adapter, my bet is on "something else."
Jon [in CT] is offline   Reply With Quote
Old 03-18-2003, 12:15 AM   #4
Drew888
Member#: 6459
Thanks for the help!
After the car sat for about 2+hrs the CEL went away.
Probably 'something else'?
If I pick up a scanner, does someone have a list of OBD-2 codes?
Thanks again,
Drew
Old 03-18-2003, 08:53 AM   #5
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Thanks again,
Drew
Scanners typically come with a list of the generic Type 0 codes, which are the ones you'll commonly see. FYI - I picked up the very nice Equus 3100 ODB II Scanner for $129 at Checker Auto Parts.
http://www.partsamerica.com
You can also look up codes here:
http://www.northursalia.com/t...obd2/obd2.html
-Steve
MNbiker is offline   Reply With Quote
Old 03-18-2003, 08:57 AM   #6
z&cobb
Member#: 12344
2002 2JC
blue
Thanks again,
Drew
The Actron scanner I have gives the code and an English description of what it is. It does not give diagnostic/repair procedures. Vol 3 (Engine) of the set of Subaru service manuals provides diagnosic tests for each code.
Some things (cat inefficiency, misfire, gas cap loose) can just be erased and then you wait to see if they come back. A blinking cel is very serious.
Erasing cels can put the Inspection/Monitoring systems in a "not ready" condition. It is informative to check those systems after clearing a code. After some time they should set back to "ready" again. The handheld scanner supports those checks too.
'02 White WRX with light mods cwb124 Private Vehicle 'For Sale' Classifieds 18 10-30-2003 01:54 PM
Fog light mod help BlueWRXagon Electrical & Lighting 8 10-01-2003 09:58 PM
Should I expect to get a CEL with these mods? sdseagles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-02-2003 09:56 AM
Can't reach full boost in 1st gear with new BOV, HELP!!! revelation Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-25-2002 12:33 AM
front badge with light mod? RS-Boarder Interior & Exterior Modification 6 12-01-2000 05:10 PM
