Old 03-18-2003, 01:45 AM   #1
boostedgst
Member#: 27356
2006 Evo 9 MR
Tuned by Shiv
Default Front strut bar without moving ac line??
Is there a front strut tower bar out there that doesnt require moving the damn AC line?? I have the Whiteline and it sucks ass, I dont want to jack the AC line up.
boostedgst is offline   Reply With Quote
Old 03-18-2003, 09:22 AM   #2
Pat L.I.
Member#: 20498
2006 WRX TR
i know this doesnt answer your question exactly but i have the cusco bar and i dont htink you have to worry about messing up the ac line. your just relocating it down a little. yeah you have to bend it but it sounds a lot worse than it is! You barely have to move it that much, and i do not believe this slight movement has an effect on the integrity of the line. Sorry but i dont know any bars that completely clear the line.
Pat
Pat L.I. is offline   Reply With Quote
Old 03-18-2003, 12:24 PM   #3
boostedgst
Member#: 27356
2006 Evo 9 MR
Tuned by Shiv
Ive seen it with the Whiteline bar, and the AC line looks like crap. I mean it looks all bent and whacked out. The symmetry of the engine bay is compromised I feel when looking at it. I may just get the Cusco ver. II underbrace. It will probably to a better job of keeping the front stiff than a strut bar.
Old 03-18-2003, 06:39 PM   #4
KJR
Member#: 16879
it most definitely will!
KJR is offline   Reply With Quote
Old 03-18-2003, 06:59 PM   #5
Moses
Member#: 19148
I will try to get you the pics tomorrow...I installed the Cusco strut tower bar last fall. I had to bend the A/C line a little bit. I was quite worried about it before doing it, but if you bend it slowly and just a little bit, everything will fit. You probably won't even notice that the A/C line is moved at all after it is done.
Those pics are one my home computer...will upload them either tonight or tomorrow.
Brian
Moses is offline   Reply With Quote
Old 03-18-2003, 07:05 PM   #6
boostedgst
Member#: 27356
2006 Evo 9 MR
Tuned by Shiv
cool Brian I'm interested in seeing them!
Old 03-19-2003, 01:27 AM   #7
RacerX
Member#: 1513
2003 WRX
WR Blue Pearl
Default Sti replica bar
I installed an Sti replica bar. I removed the A/C bracket attached to the fire wall, then moved it down so the bracket was just attached with one bolt. This moves the line down about an inch. With a LITTLE bending (really hardly any), the Sti bar fits over the A/C line quite easily. I think this is a better set up than the Whiteline bar which goes under the A/C line. I can email you install pics if you want.
RacerX is offline   Reply With Quote
Old 03-19-2003, 10:50 AM   #8
Moses
Member#: 19148
Default Re: Sti replica bar
Originally posted by RacerX
I removed the A/C bracket attached to the fire wall, then moved it down so the bracket was just attached with one bolt. This moves the line down about an inch. With a LITTLE bending...
I forgot to mention this. The Cusco comes with a bracket to move the driver side of the A/C line down about and inch. And no it should not hit or rub the A/C line when you are done. Here are the pics...hope they help. Do like I did and get some balls and Just Do It!
Before anyone asks, that is the COBB intake.
If you have any other questions, just let me know.
Brian
Carbon Fiber front strut bar without brackets bsmitty 1993 - 2001 Impreza Specific Parts 21 12-12-2008 10:15 PM
Whiteline confirms: KSB632 front strut bar clears 06 WRX a/c lines chimchimm5 Brakes, Steering & Suspension 11 02-26-2007 07:18 PM
Cusco Front Strut Bar (TypeOS) AC bracket.. WTF?! 409Industries Brakes, Steering & Suspension 0 10-08-2006 05:35 PM
White Line Front Strut Bars Clears TMIC jalow72 Brakes, Steering & Suspension 0 03-29-2005 12:14 PM
Front Strut Bar & AC Hose Silver04WRX Brakes, Steering & Suspension 8 07-16-2004 10:17 PM
