Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 03-18-2003, 11:18 AM   #1
ScoobArmada
Member#: 12974
2005 STi
Whiter than Faded BRP
Default NGK Plug Wires
Anyone know where to find NGK plug wires? The NGK web site is pretty much useless.
I'd also be glad to hear from anyone that actually uses these wires. How do they fit and do they ever pop off? Looking for an alternative to the whole Magnacore-fits-no-they-don't-yes-they-do thing.
ScoobArmada is offline   Reply With Quote
Old 03-19-2003, 10:22 AM   #2
ScoobArmada
Member#: 12974
2005 STi
So everybody has just glued on their Magnacores?
Bump for anybody that has NGK wires or knows where to find them.
Old 03-19-2003, 03:58 PM   #3
Yeoman
Member#: 175
2000 Impreza 2.5RS
2012 Legacy 3.6R
I have NGKs!, I got them from a local shop, I don't know if they ship....
http://www.speedbump.info
there you go!
BTW, no problems, no popping off, and they're nice and blue!
Yeoman is offline   Reply With Quote
Old 03-19-2003, 04:25 PM   #4
speedracer47
Member#: 2765
anyone know the NGK part number?
speedracer47 is offline   Reply With Quote
Old 03-20-2003, 12:03 PM   #5
ScoobArmada
Member#: 12974
2005 STi
Default update
After some digging, I got ahold of NGK's parts phone number. According to them, they do NOT make plug wires for the 2000 Impreza. That doesn't mean another year's wouldn't fit, but the support guy couldn't answer that question.
So question for Yeoman, exactly what NGK wires did you get and can you post the part number?
And for anyone that wants to call and double-check, NGK's customer service/parts line is 877-473-6767.
Post if you hear differently.
Old 03-20-2003, 01:11 PM   #6
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
what year do they make them for? I would assume all 4 years of the 2.5l engine would be the same...
DanzBorin is offline   Reply With Quote
Old 03-21-2003, 12:49 AM   #7
Siper2
Member#: 1134
2007 BMW 328xi wagon
Exclamation
I'm liable to get kicked in the head for this.
I think that the whole plug wire upgrade thing is negotiable. A lot of people say that it's really only good for looks.
I'm a car stereo nut. A while back, I got involved in some online discussions (I think in the www.audioreview.com forums) regarding Monster Cable versus Home Depot/Radio Shack plain copper cable. The argument being that you're paying out the nose for a pretty look, just regular cable, maybe twisted in a fancy fashion, but it it offers no discernable advantage over plain speaker cable you can buy off a roll somewhere. Now, the undeniable fact is that you need the proper gauge. After that, the rest is a HUGE, heated debate.
Some time later, I looked into some plug wire arguments. I made a comment somewhere stating that perhaps the line of thinking might be the same... I mean, essentially it's just the passing of electrical current, right? So, as long as it's the proper thickness, what advantage, performance-wise, will there truly be?
If you're in it for looks, go for it. Otherwise I don't know of a real value to these things. No I'm not bashing anyone's choice, just trying to get a discussion started.
-S2-
Siper2 is offline   Reply With Quote
Old 03-21-2003, 12:46 PM   #8
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
I think the boots that attach to the head part are 2 different shapes IIRC from another post, maybe the one about mangnacore’s popping out.
Poppa smurf is offline   Reply With Quote
Old 03-30-2003, 10:55 AM   #9
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
The later 2.5s have coil towers with terminals that resemble the terminal half of a spark plug, so the connectors on both ends of the spark plugs are very similar.
As for them popping off, it may be related to another problem. They're also very hard to press onto the spark plugs. I found a solution to that problem; it just occured to me that it may also be a solution to the popping-off problem with new-style coil towers:
http://bbs.legacycentral.org/viewtopic.php?t=263
vrg3 is offline   Reply With Quote
Old 03-30-2003, 02:57 PM   #10
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
I changed out my stock set (found a split inside one of the boots) to a Beck/Arnley blue OEM match set
anyone have these? they are blue, like the NGK's, and the match the stock wires exactly.... maybe a little bit longer, that's all
anyway, they work great.
Cujo31 is offline   Reply With Quote
Whare are NGK plugs wires??? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-12-2003 10:17 AM
Anyone have NGK plug wires? mpaone Normally Aspirated Powertrain 4 07-21-2003 07:57 AM
NGK Plug wire part number? racer25rs Normally Aspirated Powertrain 0 11-14-2002 06:18 PM
NGK Plug Wires SSLegacyGT Normally Aspirated Powertrain 0 08-16-2002 01:16 AM
Need NGK Plug wire numbers for 2.2 Impreza drew510 Service & Maintenance 2 06-23-2002 11:47 PM
