Old 03-18-2003, 04:25 PM   #1
OJL
Member#: 25163
2002 2.5 RS Sedan
Default Rear Sway Bar on 2002 2.5 RS
Does the 2002/2003 2.5 RS have the same stock suspension setup as the WRX? Specifically, what size is the rear sway bar in the 2.5 RSs compared to the WRXs? Also, what would be a good sized sway bar (and brand) to get the 2.5 RS to handle close-to-neutral?
OJL is offline   Reply With Quote
Old 03-18-2003, 04:47 PM   #2
pdlindor
Member#: 7446
2002 Impreza RS
2009 Forester Limited
The RS has a 13mm rear sway bar; the WRX has a 20mm rear sway bar. Rear sway bars are interchangeable between the RS and the WRX, fitment-wise.
RS vs. WRX suspension: Front sway bar is the same size (20mm) but different fit, struts are the same, RS springs are softer but same fit, RS strut tops are slightly softer but same fit.
Sway bar brand: I've always been a fan of OEM in this department, as you'll avoid most of the squeaking/clunking associated with aftermarket bars. Size is up to you - but be sure you can handle what you switch to. I went with a 17mm off of a WRX wagon at first, and I'll eventually switch to a 20mm from the WRX sedan. 13 to 20 is an awfully big step if you're not ready for it.
Lastly, you'll get far more responses if you put this in the Suspension forum
~Paul
pdlindor is offline   Reply With Quote
Old 03-18-2003, 05:44 PM   #3
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
~Paul
Not at all... just remember what you did and that oversteer is an option... 20 is great...
DanzBorin is offline   Reply With Quote
Old 03-18-2003, 06:03 PM   #4
pdlindor
Member#: 7446
2002 Impreza RS
I'll definitely be going to 20 when I upgrade my springs, etc. I guess I was gunshy because of all the snap oversteer warnings - the last car I drove was a Saturn SL1, so I was wary.
~Paul
Old 03-18-2003, 06:14 PM   #5
windfactory
Member#: 16108
02GD Tuned EJ251 NA
Blue Ridge Pearl
Subaru 18mm RSB on mine, good enough for street/autox
windfactory is offline   Reply With Quote
OEM 19mm Front Sway Bar from a 2.5 RS - $10 GC8WSI 1993 - 2001 Impreza Specific Parts 0 11-18-2008 02:59 PM
Suggestions for rear sway bar on 08' 2.5i? DKPGraphics Newbies & FAQs 4 02-19-2008 12:32 AM
05 WRX Rear Sway Bar on 05 2.5RS shortysman999 Brakes, Steering & Suspension 1 10-28-2005 05:07 AM
Advice on 2002 2.5 RS Setup GlennZippy Normally Aspirated Powertrain 20 12-18-2001 09:49 AM
