Old 03-18-2003, 04:50 PM   #1
sdseagles
Member#: 17296
Platinum Silver Metallic
Default Who's got the best thread on how to install a turbo-back exhaust and up-pipe?
I looked on scoobymods.com and couldn't find a good one with any real detail. If someone could link me up I'd really appreciate it. Thanks
sdseagles is offline   Reply With Quote
Old 03-18-2003, 05:33 PM   #2
jjunior887
Member#: 16738
2015 WRX Limited
CWP
jjunior887 is offline   Reply With Quote
Old 03-18-2003, 05:42 PM   #3
sdseagles
Member#: 17296
Thanks. Stupid question though . . . are the instructions the same regardless of manufacturer?
Old 03-18-2003, 05:55 PM   #4
jjunior887
Member#: 16738
2015 WRX Limited
CWP
some of them do things a little differently such as what bolts you tighten first on the uppipe and such but they should all get you to where you want to be w/o too much hastle. The one thing I would suggest is use new gaskets where you can, it sucks to have to go back in there once you think you're finished. alot of times it seals okay w/o new gaskets but it's better not to take the chance if you can help it. Now would be the time to drill and tap the manifold and put a EGT sensor in there if you plan on getting a gauge in the near future. -James
Old 03-18-2003, 05:58 PM   #5
sdseagles
Member#: 17296
James, I did the EGT already. As far as gaskets, I know to replace the up-pipe gaskets, but what others are recommended to be changed as well?
Old 03-18-2003, 06:02 PM   #6
jjunior887
Member#: 16738
2015 WRX Limited
CWP
You should be okay with just those but I ended up with a leak where the DP meets the turbo which may have just been a fluke. The only other one you're messing with would be the crossover pipe to the manifold gasket. I didn't need it for mine but it might be a good idea depending on how anal you are. -James
Edit: I forgot about the manifold to the block gasket but I havn't heard of any leaks there yet.
Old 03-18-2003, 08:55 PM   #7
sdseagles
Member#: 17296
Anyone else done this? I was planning to replace only the uppipe gaskets, but I'll change out the others if needed
Old 03-19-2003, 08:05 AM   #8
sdseagles
Member#: 17296
By the way, APS states that all their exhaust systems come with detailed instructions (in case anyone is interested)
Old 03-19-2003, 07:52 PM   #9
sdseagles
Member#: 17296
Both gaskets for the up-pipe right?
FS: Stock 04 WRX exhaust jouka NESIC Private Classifieds 24 06-22-2010 10:54 AM
2004 Stock Turbo back exhaust and up pipe Adrenalin Rush Private 'For Sale' Classifieds 2 04-30-2005 12:38 AM
F/S Turbo back exhaust and up-pipe Squish Private 'For Sale' Classifieds 15 08-05-2004 06:19 PM
FS: Turbo XS turbo-back exhaust and up-pipe DwithBoost Private 'For Sale' Classifieds 9 05-24-2004 10:40 PM
Who's got the best deal on down pipes? Sports Wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-19-2003 07:09 AM
