Old 03-18-2003, 06:02 PM   #1
M3toWRXin3seconds
Guest
Member#:
Default Scooby mods- improve factory boost solenoid mod...
Well I did it today, it was very simple, and only took 5 minutes...
It worked exactly as it said...and for $2.88 how can you argue with that. Boost actually peaks at 1 bar in every gear now...never used to happen in second gear...read the page its self explanitory
I noticed a little difference, but i also installed a K&N drop in intake...so maybe that had a little to do as well.
here is the link to the page
http://www.scoobymods.com/forums/sho...p?threadid=542
Old 03-19-2003, 10:26 PM   #2
Davenow
Member Sales Rating: (21)
Member#: 23676
Default Report back in a week or two
So you can finally disprove all the guys that say the ECU learns around it and it stops working. (it never stopped working in my car)
Old 03-20-2003, 06:57 PM   #3
M3toWRXin3seconds
Guest
Member#:
Default just installed another
in my friends car...worked too...so far its still the same.....happy boosting
Old 03-26-2003, 02:29 AM   #4
M3toWRXin3seconds
Guest
Member#:
Default well it is a week later....
its still working.....ecu does not adjust to it...it keeps on boostin the full in 2nd
Old 03-29-2003, 11:42 PM   #5
el~sharko
Member Sales Rating: (5)
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
mine adjusted it within a few days. then agian i haven't reset my ecu yet. But it definately adjusted it back to normal
el~sharko is offline   Reply With Quote
Old 04-01-2003, 01:42 AM   #6
turboICE
Member Sales Rating: (9)
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Two weeks yesterday, my ECU has not learned around it. Boost continues to build earlier and hold better. Still getting right around .1 on 93 octane at sea level.
Here is the updated link
http://www.scoobymods.com/forums/sho...&threadid=1564
turboICE is offline   Reply With Quote
Old 04-02-2003, 04:41 PM   #7
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
oh yeah I just realized I've gotta be atleast 1000ft above sea level here in Illinois, I guess I'll know for sure when I get back to Bmore
Old 04-07-2003, 04:03 PM   #8
M3toWRXin3seconds
Guest
Member#:
Default unfortunately
i think my ecu is catching on, i dont see the peak boost as much anymore...allthough it sometimes does sneak past it and bump up to .1mpa...it definately doesnt do it very much anymore
waste...
Old 04-09-2003, 06:28 PM   #9
Rice Boi
Member Sales Rating: (11)
Member#: 25811
2002 WRX (6spd)
2010 TDI CupEdition (DSG)
When did you guys get your car. The ECU have been tuned diffrently through out the line of 2002 WRXs. I'm not sure but the early WRX were the ones that are less sensitive to changes.
Also I can't get the link to work
Rice Boi is offline   Reply With Quote
Old 04-10-2003, 01:10 AM   #10
scrappydoo
Member Sales Rating: (4)
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Had mine for a year before going to a mbc and ecu never adjusted to it, although I did have a boost spike problem in the begining. I just did a reset and the spiking went away. But I haven't had a problem since then.
Marcel
scrappydoo is offline   Reply With Quote
Old 04-10-2003, 01:16 AM   #11
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
The link at the top of the thread is an old one, the count on it was increased when Kastle posted my additional pictures from my install.
This one works as of this post.
Old 04-10-2003, 04:13 AM   #12
Rice Boi
Member#: 25811
2002 WRX (6spd)
So all you do is replace one coupling right? Why are the guys buying two of them?
Old 04-10-2003, 08:03 AM   #13
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
There is only one to replace. We get two because most are just packaged that way. Share with a friend.
Old 04-10-2003, 11:00 AM   #14
M3toWRXin3seconds
Guest
Member#:
Default yeah they come in packs...
i noticed that kind of spike your talking about...it would just stick to .1mpa or 14.7 psi and than level out at around 12psi...and eventually cut its way down when redline came around....i'll have to check it out again.
Old 04-10-2003, 01:24 PM   #15
Rice Boi
Member#: 25811
2002 WRX (6spd)
Are you guys just reseting the ECU by discunnecting the battery or are you actually reseting with the OBD device?
Sorry for asking all these questions, just want to do it right.
Old 04-10-2003, 04:43 PM   #16
M3toWRXin3seconds
Guest
Member#:
Default resetting by
disconnecting the battery...and i tried to boost it up again in second and it hit 14.7 psi again so i guess its still working....(after oil change and shifter/bushings install)
Old 03-02-2008, 03:19 PM   #17
hoffmanEstates
Member Sales Rating: (33)
Member#: 122043
04 wagonier
psm
Default yeah
3/16 coupling and a 3/16 T some one did and says it works even better. i have pics pm
hoffmanEstates is offline   Reply With Quote
Old 03-02-2008, 11:59 PM   #18
thejaredhuang
Member Sales Rating: (53)
Member#: 86206
2006 WRX Wagon
Does it still work 5 years later?
thejaredhuang is offline   Reply With Quote
Old 03-03-2008, 12:51 AM   #19
hoffmanEstates
Member#: 122043
04 wagonier
psm
Default weird
i did the mod in the parking lot of autozone, the 3/16 connector worked awesome b oost to 15psi in every gear. when i got home and shut off engine it only boost 9psi max what the heck? i will say it is smooth transition inbetween gears and boosting but 9 psi? what am i doing wrong? and dont say the 3/16 connector? now do i need the 3/16 connector with the restrictor in it or the open design?
Improve factory boost solenoid for $2.88 SnortWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 717 01-12-2014 12:58 AM
Improving Factory Boost Solenoid Hokie Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-19-2004 02:41 AM
Improve factory boost solenoid additional mod saleen90181 Newbies & FAQs 7 10-16-2002 04:08 PM
Improving the factory boost solenoid - part 2 SnortWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-16-2002 01:56 AM
Grounding Mod Improves Stock Boost! SnortWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-18-2002 03:24 PM
