Old 03-18-2003, 09:22 PM   #1
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
Default utec stage 4 map and stage 4 tmi map the same?
i went to the turboxs site to download the stage 4 base map with no tmi but i noticed the file name was stage4tmi, so my question is are the two maps the same? i don't want to use the wrong map on accident and make something go boom
datdudedennis is offline   Reply With Quote
Old 03-18-2003, 09:43 PM   #2
topgrinder
Member#: 31649
yeah it appears the maps r the same.. i downloaded and printed em both,,,, the same
topgrinder is offline   Reply With Quote
Old 03-18-2003, 09:48 PM   #3
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
hey man....thanx i really appreciated. sorry to have made you go through the trouble of printing them and comparing them. must have been an eye sore
Old 03-18-2003, 10:12 PM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
I talked to the folks at TurboXS about it and Phil told me they are exactly the same because the base map is so rich, that with the extra boost (less pressure loss) from the TMIC, you're still running relatively rich. -Bolster
Bolster is offline   Reply With Quote
Old 03-18-2003, 11:37 PM   #5
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
A little clarification is needed.
The TMI has less pressure drop so the air charge is denser and therefore if you wanted to run the same AFR you would have to add more fuel. Since the TMI adds a significant amount of efficiency to the system we didn't want it run richer but instead leaner, thus the same voltage pull down in the fuel table.
While they are the same programs the result is very different. Not only is MAF voltage different because the car is breathing better but so is the AFR.
It just happened that the STG4 program gives the power we wanted to get out of adding the TMI. That doesn't mean there isn't significantly more to be had by further tuning
So don't call us as they are the same but different.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Do the 06-07 imprezza, wrx, and outback hatch all have the same trunk? hookedontronics Interior & Exterior Modification 5 10-13-2009 03:05 PM
Are the 08 WRX+ and 08+ STI sway bars the same? gaguilarsti Brakes, Steering & Suspension 1 07-23-2009 03:27 AM
And after countless expense and hours spent, I look the same as everybody else! Capt Crunch Member's Car Gallery 92 05-25-2006 05:48 PM
Do the gold wheels and silver wheels come with the same lugnuts? Butt Dyno STi Forum Archive 4 07-06-2003 02:50 PM
1pot and 2 pot brake lines the same? slide Brakes, Steering & Suspension 1 02-22-2001 06:59 AM
