Old 03-19-2003, 08:45 PM   #1
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Question Elevation affects coolant level?
Can anyone tell me how much the coolant level would be effected by a change in elevation?
Eg: Would going from sea level to ~1,500m (~4,900ft.) on a road trip cause the overflow tank to expand all of the way near the top?
Ken is offline   Reply With Quote
Old 03-20-2003, 08:36 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Default Re: Elevation affects coolant level?
No, it shouldn't.
I've driven many long distance trips, over the rockies and the continental divide and have had no issues like you speak of.
Legacy777 is offline   Reply With Quote
Old 03-20-2003, 11:13 AM   #3
C-daleRidr
Member#: 18074
2008 Speed3
Default Re: Re: Elevation affects coolant level?
Originally posted by legacy777
No, it shouldn't.
Same answer. I drive from Oklahoma to Window Rock at least twice a year, going from under 2000 feet to almost 7000. I also drive around the mountains of southern Colorado several times a winter. I've not ever seen the problem that's described here.
C-daleRidr is offline   Reply With Quote
Old 03-20-2003, 04:18 PM   #4
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Thanks for the input guys.
They say it all checks out. The pressure tested it, ran it up the local mountain to the ski hill and the radiator itself is full as it should be, no matter what the level is in the overflow tank. So it doesn't look like it's an air bubble or clog in the system to keep the coolant from flowing. They installed a new block 3,500 miles ago under warranty, so it's not like the water pump is shot or anything, and the gaskets can't be blown already. The heads are from my old engine and were resurfaced. In any case if it ever does overheat (like it used to on the old block) when I let it idle, and throws a CEL, then I'll be going back and pissed. They're going to mountain fight it this afternoon again just to make sure.
I think what they said about the coolant expanding, related to elevation is a bit BS...
I've noticed on the TS wagon i'm driving today, the coolant level only rises about an inch in the overflow tank when driving around town.
Any more input?
Old 03-20-2003, 06:40 PM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Yea, I got a comment for you. Jerry is a walrus-clown.
Keiho is offline   Reply With Quote
Coolant level low - mix coolants? Tolew45 Newbies & FAQs 14 04-09-2010 10:23 PM
How much does elevation affect performance? bulgarianfreak55 Newbies & FAQs 10 12-17-2009 09:46 PM
coolant level geb04 Forester Forum 6 01-02-2004 08:24 PM
coolant level prspect06 Newbies & FAQs 2 02-22-2003 06:45 PM
WRX coolant level keeps going down? Scooby do Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-24-2001 10:55 PM
