Old 03-19-2003, 11:27 PM   #1
waitandbleed92
Member#: 33990
09 WRX STI
Lightning Red
Default How can you translate the factory boost gauge?
I am hittin bout .9 on the factory boost gauge how many Lbs is this and how can i translate the rest of the gauge into lbs?
waitandbleed92 is offline   Reply With Quote
Old 03-20-2003, 12:03 AM   #2
sochico
Member#: 18377
2002 wrx
midnight black
i think what u mean is .09 that is about 13.5 psi and .1 is about 14.5 to almost 15 psi
sochico is offline   Reply With Quote
Old 03-20-2003, 12:31 AM   #3
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Here is a converter
ftp://ftp.wsdot.wa.gov/public/Metrics/convert.exe
Just click on the 'Pressure' tab and enter for 'megapascal' that's what the stock boost gauge reads
Then for 'Output' select PSI or whatever you want to see it in
.09 MPa = 13.053 PSI
MAD REX is offline   Reply With Quote
Old 03-20-2003, 12:48 AM   #4
WRX300
Member#: 17974
.1 on the gauge = 1 bar = 14.7psi
hehe i just approximate from there
hth
~wrx300
WRX300 is online now   Reply With Quote
Old 03-20-2003, 01:09 AM   #5
Tical83
Member#: 32958
2002 WR Blue WRX
07 Spec B, '11 LR WRX LTD
multiply the readings from the gauge by 145
Tical83 is offline   Reply With Quote
Old 03-20-2003, 10:26 AM   #6
z&cobb
Member#: 12344
2002 2JC
blue
I thought that when the gauge hits 0.1 that equals 14.4 psi.
Plus or minus one additional line is then just plus or minus 1.44 psi. I like to see it at 0.115 at 4000rpm in 4th (UTEC stg 2 + TXS TMIC).
z&cobb is offline   Reply With Quote
How do you test the Factory Boost Solenoid? stealthECC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-13-2008 12:24 PM
How do i decipher the factory boost gauge affinity1 Newbies & FAQs 17 05-19-2006 11:57 AM
How accurate is the factory boost gauge compared to other gauges? snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 08-06-2004 11:44 PM
How accurate is the factory boost gauge? DJDaizzy STi Forum Archive 3 07-14-2003 11:08 PM
How can you tell if your boost gauge is accurate? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2001 08:24 PM
