#1 |
Member#: 4024
Vehicle:2004 impreza WRX STi World Rallye Blue |
I just received a pdf file with the spec of the new STI, canadian version...
Curb weight: 1484kg The intercooler tank is in the trunk Fuel: recommended 93 or higher, 91 minimum Fuel economy(city/hwy): 13.4L/9.1L (100km) Gear ratios: 1=3.636 2=2.375 3=1.761 4=1.346 5=0.971 6=0.756 Reverse=3.545 Final 3.900 Drag coef: 0.33
#2 |
Member#: 7852
Vehicle:03 White Lan EVO 8 97 Techno-Violet BMW M3/2 |
3,271.65997 lbs...
#3 | |
Member#: 33424
NESIC
Vehicle:2004 STI Blue/Gold |
Minus heated seat US will be different |
#4 |
Member#: 4024
minus speaker, minus cd player... but who gonna ride the STI without those....
#5 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Thanks for supplying the best estimates so far for the three TBDs on the USDM PDF spec sheet:
Curb Weight (lbs): 3271.7 EPA city mpg: 17.6 EPA highway mpg: 25.8 |
#6 | |
Member#: 26315
BAIC
Vehicle:07 Outback Silver/Silver |
#7 | |
Member#: 17887
Vehicle:05 LGTW Ltd AT 05 Evo RS |
#8 | |
Member#: 17887
Paul H. What's your take on this? |
#9 | |
Member#: 7852
million times?... Current WRX (STi) platform is already design to pass US safety requirements... so if the WRX weighs around 3000lbs... I hoping not much more for the STi.. The extra 0.5 liter should also save some weight.. ![]() |
#10 |
Member#: 18384
Vehicle:2004 STi: 580 AWHP Java Black Pearl |
Here's a link to the Subaru Canada site. It's got a high tech interface. Slick.
http://www.wrx-sti.ca/ I couldn't find specs though. Russ |
#11 |
Member#: 4024
I have the file (PDF) if some1 want
to host it I will send him ( I dont have a scanner... ) |
#12 | |
Member#: 18384
Russ |
#13 |
Member#: 26315
BAIC
3272 (weight from Canadian pdf) - 3085 (WRX weight from subaru's web site) = 187 pounds.
That's not that much more weight. If you add up the big stuff like the 6 speed MT and bigger brakes, that probably consumes most of the 187 pounds. Then there are little things like bigger inter-cooller, gigantic wing ... That sounds just about right. I wish it would be around 3085 also. It's a pretty tall order when you're adding big stuff unless you go really high tech. Hopefully we'll be pleasantly suprised by Subaru when they announce the weight for the USDM. If not, for me, 3272 is still a very acceptable weight. I don't race, my ride will probably only see a couple of lapping sessions/year and some spirited canyon driving. |
#14 | |
Member#: 7852
http://www.subaru.co.jp/impreza/sedan/09/index.html it has the same 6 speed (I believe), same omitted radio, same intercooler...same giant wing... and weighs 1440 kg or 3175 lbs... (Although I'm wondering if this is dry weight or curb weight...??) http://www.subaru.co.jp/impreza/sedan/09/09_02.html The difference should be that USDM gets 2.5 liters (lighter than JDM) and different turbo (not sure about the weight)??? Anyways.. I hope to be surprised by subaru as well... ![]() BTW, here's the translation of the japanese pages... 1st: http://babelfish.altavista.com/babel...p=ja_en&tt=url 2nd: http://babelfish.altavista.com/babel...p=ja_en&tt=url |
#15 |
Member#: 18384
I would imagine the brakes would be lighter. My massive Stoptech Big Brake Kit is lighter than the stock setup (Aluminum instead of cast iron calipers, Aluminum rotor top hats)
Russ |
#16 |
Member#: 26315
BAIC
JT-KGY,
I beleave that the JDM people weight their autos dry. Thanks for the info. |
#17 | |
Member#: 6016
Vehicle:MY05 Toyota Prius Silver |
Does this mean it won't produce 300HP using 91? |
#18 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
91 is the MIN AKI.
What do y'all think it will make on 91, 285? Of course until we get the US specs we won't know for sure. I'd be surprised if the EVO made 271 on 91 either. Glenn PS the 6MT+DCCD probably accounts for a lot of the weight difference. |
#19 |
Member#: 18384
#20 |
Member#: 4024
Well ... here 93 is very hard to find... is it complicated to boost the octane with octane booster ? like 91-92 to 93-94 ? Do I need a lot of booster to do it? Some1 know the price of a can of booster?
#21 |
Member#: 25243
SCIC
Vehicle:2006 Legacy Outback Blue |
Boost juice is expensive and only adds tenths of points of octane. I add two gallons of 114 octane toluene to each 10 gallon fill up of 91 octane gas ... giving me 94.8 octane. I believe this does give me a bit more punch ... and seems to have smoothed out my torque curve. The head mechanic at the garage that put on my exhaust said that my WRX seemed a bit stronger then other ones with similiar mods.
My local ICI Paint store ... big chain ... sells me a gallon of toluene for $5.84 ... 100 octane "racing" fuel is going for $5.85/gallon here is the Los Angeles area. I've opened up an account with them ... and can get that deal at any ICI store ... using the card they sent me. |
#22 |
Member#: 30598
Vehicle:2000 Lancer Evo 6 Hot Pink |
1484kg?? That's a fat car . . . just as bad as the Evo8
Maybe that's why Subaru took so long to release the figures. ![]() The Evo makes a lot more power when using 100 octane gas as compared to 92 octane gas. There wont be much difference between 93 and 91 octane though. Hmm, at 1484kg for the STi, the Evo with much nicer seats and slightly cheaper price is beginning to look more appealing . . . |
#23 |
Member#: 4203
South East
Vehicle:2009 WRX 5spd hatch Platinum Silver Metallic |
"Nicer seats and slightly lower price"
If the seats are what's important to you, than by all means go for the EVO (or Taurus or something ).Just kidding around - don't forget that most Subaru dealers won't be selling above MSRP, whereas it seems most EVOs are going for thousands above MSRP, basically evening out the price. The STi gets a 6 speed, a much more advanced all wheel drive system, weighs less, nicer interior, a gas tank larger than a milk jug, and oh yeah, a lot more power. The EVO gets Recaros, and.... that's about it. |
#24 | |
Member#: 17270
NESIC
Vehicle:2000 Fender Bender SORTA RUBICONEY... |
#25 |
Member#: 456
NWIC
The DCCD is a big differentiator, at least for the people that care about it.
| Thread Tools | |
| Display Modes | |
| SPT Power Packs from Subaru for the STi | Burkesrally | Factory 2.5L Turbo Powertrain | 28 | 09-17-2006 08:31 PM |
| What's the gear oil weight and grade for 2004 STi? | Need Speed | Transmission (AT/MT) & Driveline | 2 | 06-02-2004 12:20 AM |
| will there be an official public release event for the sti locally? | Benjamin Tang | Vancouver Impreza Club Forum -- VIC | 7 | 01-15-2003 01:40 AM |
| OFFICIAL "Fact or Fiction" Thread for the STi........... | xfactor834 | STi Forum Archive | 8 | 01-09-2003 10:22 PM |
