Old 03-20-2003, 02:42 PM   #1
ripGTS
Member#: 5567
2002 Subaru Wrx
Default Broken Exhaust boost problem?
I hit a big pot hole yesterday and i no there is a big leak somewhere around the Downpipe area
Now the car does not want to go to full boost i have a Vishnu STG2 instead of 17psi the car chokes and stays around 14/15psi
it does not want to get boost at WOT
it started as soon as the leak started so im pretty sure that is
but just to make sure i though id ask
ripGTS is offline   Reply With Quote
Old 03-20-2003, 03:19 PM   #2
codean
Member#: 10186
Are you sure your up-pipe didn't crack? A leak after the turbo would not effect boost. But if the pot hole caused the up pipe to crack a flange it would cause the type of problems that you are having.
I would bet that it's the flange that connects to the exhaust manifold.
codean is offline   Reply With Quote
Old 03-21-2003, 09:48 AM   #3
ripGTS
Member#: 5567
2002 Subaru Wrx
It does not seem to be coming from there the leak sounds like its in the middle of the car
i listened to the leak its no coming from the engine bay
Broken Boost Gauge or Boost problems? undrgroundskat3r Newbies & FAQs 7 08-03-2009 12:02 AM
07 Sti over boost problem with catless downpipe and uppipe exhaust system Jimmy168 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 04-21-2008 06:23 PM
Cam gear broken around edge. Problems? shu_chen4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-22-2006 07:15 AM
Broken OEM Boost Controller Minnesota WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-16-2001 11:05 AM
Help with boost upgrade - high boost problem alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-06-2001 06:15 AM
