Old 03-20-2003, 05:03 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default 98 2.5rs MAF based?
Does the 1998 2.5RS have a MAF sensor in the intake tract?
Old 03-20-2003, 05:16 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
yes , 98 and 99 are MAF
Jay
Old 03-20-2003, 05:17 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
Cool. Are these the engines with higher than normal headgasket failure? Do they require 87 octane?
Old 03-20-2003, 05:44 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
your DOHC engines are the ones that have a head gasket issue...
this would be 98's and some 99's...
Jamie www.subiegalracing.com
Old 03-20-2003, 06:16 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
Dangit. A searching I will go
By chance has a fix been found? Perhaps metal bead HG and head studs instead of bolts?
Old 03-20-2003, 06:42 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
IIRC, there is a service bulliten on the bad head gaskets, im sure they improved the gaskets.
Jay
Old 03-20-2003, 07:08 PM   #7
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Yes, if yours has failed, Subaru has heavy duty gaskets. You can do it yourself or have the stealership do it for ya. It depends on how dirty you'd like to get. Course, I haven't done it (yet) so I don't know how much of a pain it can be.
AJ711 is offline   Reply With Quote
Old 03-20-2003, 08:00 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
Hmm, Ive had plenty of past experience with "upgraded" Oem gaskets so that is not something I would trust.
So nobody is using an aftermarket gasket?!
My past experience was with Toyota Supras. The HG failure was extremely common, almost guaranteed failure before 100k on every vehicle.
The fix became installation of HKS (other brands too) metal HG and Arp studs or bolts. Toyota redesigned the gasket a couple times. Just search for Supra and BHG and you will see what I mean
Old 03-21-2003, 11:28 AM   #9
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I believe Rallispec was able to source copper hgs for the DOHC engines. You should get in touch with them. Gonna have to find a place to o-ring the block, though.
2.5GT is offline   Reply With Quote
FS Mn:RS 98 2.5rs MAF housing bikerboy 1993 - 2001 Impreza Specific Parts 0 11-14-2007 08:44 PM
Maf Sensor 98 2.5RS Markcjr Bay Area Impreza Club Forum -- BAIC 0 08-23-2007 05:16 PM
WTB: MAF Sensor for 98 2.5RS Markcjr Private 'Wanted' Classifieds 0 08-23-2007 01:00 PM
98 2.5RS turbo kit to a 2.2 Legacy will it work HELP SWEETBOY Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-27-2004 11:00 PM
98 2.5RS short block compare to 99-04 2.5RS short block. ChAi Normally Aspirated Powertrain 10 03-16-2004 05:27 PM
