Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 03-20-2003, 05:18 PM   #1
quentinberg007
Member#: 7887
Default Replacing dashboard light on 93 L?
As of right now, I am driving around at night with no use of my speedo, tach, or any other gages, for that matter. The bulb behind the gage cluster has either come loose or burnt out. Today I attempted to get back in there, but I'm having a hell of a time getting the gage cluster to come out. Is there some other way to get back in there to check?
I think the bulb may just be loose, concidering the light will come on once every few months, but recently, i've been completely in the dark. (and yes, i checked the dimmer dial on the turn signal switch )
~~Quentin
quentinberg007 is offline   Reply With Quote
Old 03-20-2003, 06:47 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
if its similar to an RS there should be three bolts that hold the cluster in.
on a 93 there as probably a speedo cable you will have to disconnect out side the car and pull that through, thats probably what is giving you the problem, and why it wont pull out easily.
HTH
Jay
Old 03-20-2003, 11:48 PM   #3
quentinberg007
Member#: 7887
thanks i got the cluster unbolted, but it was still being held in by the cables... where do i go to unhook the speedo cable? below the car, under the hood, etc?
~~Quentin (feelin' like a n00b even though i have specialist under my name)
replacing driving light on '06 Tribeca Shootist Electrical & Lighting 0 01-07-2009 06:53 PM
Replacing fog lights on 08 WRX with HID's Prefontaine84 Interior & Exterior Modification 1 07-10-2008 10:28 PM
('93-'01) Installing daytime running lights on 93 Impreza? stigc8 Impreza Forum 1 04-22-2008 03:12 PM
Wanted: Replace my starter on 93 Mitsubishi (easy) TODAY for $40 - Arlington, VA Jessie James Off-Topic 2 09-26-2004 12:04 PM
Dashboard light replacement help! bfg9k Service & Maintenance 2 11-29-2003 03:48 PM
