Old 03-20-2003, 10:51 PM   #1
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Default Running warm...seems strange
The last two mornings Iv been stuck in some pretty bad traffic for about 5 mins, and both days I have been creeping along at just a little faster than idle. I mean like 1000-1500RPM sliping the clutch almost the whole time (lotsa stop-n-go). Thing is I have watched my Water temp gauge go right to the top "normal temp" line... I hear the fans kick in sometimes, but Im not 100% sure when. I am just worried because I'v been in this situation (stop and go) in 100 degree weather and the temp gauge never moved an inch (normally just below dead center). In fact, once the car has reached operating temp, it has STAYED there, and never moved. It was only about 50 degrees out the last two mornings.
Its good to know that after about 30 sec. of driving (at 40mph) the temp was right back to normal. Should I be worried? I dont want this to be an early warning for some empending problem. My car is about 18 months old and has 15,000 miles on it.
DDMan is offline   Reply With Quote
Old 03-21-2003, 01:45 AM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
mods/anything non-stock under the hood??
Albert is offline   Reply With Quote
Old 03-21-2003, 09:36 AM   #3
DDMan
Member#: 11221
2002 2.5 RS
Doh...sorry..
PDM Racing Intake.
Borla V4 Headers.
N1 (ScoobySport) Lightened pulleys.
Custom bent cat-back with resonator built in.
Magnaflow muffler with single 3" tip.
ProECM Power chip.
Old 03-21-2003, 11:55 AM   #4
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
None of your mods seem to be the obvious culprit.
Non the less,
--Double check the PDM vent hoses, ensure you have proper engine venting/circulation.
--Contact ProECM (or vendor) maube they'll give you some feedback.
If you eventually have to take her in to the dealer keep in mind Subaru doesn't like cars with mods
Old 03-21-2003, 02:36 PM   #5
DDMan
Member#: 11221
2002 2.5 RS
Ya...Im not TOO worried, becuase once I got up to speed I was ok. If I have troubles Sunday at the Auto-x then I might consider getting worried (iv done other auto-x's in 90 degree weather and had no problems), but unfortuately the WORST conditions for the cooling system is exactly where I was. Higher than idle under load, but not really moving fast enough to cool.
08 STi not running right, acting strange T-WREXXX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 12-12-2009 04:52 PM
Paypal question, is this legit? Seems strange. WhiteH2O Off-Topic 19 09-21-2009 04:10 PM
Seems strange, but WTB: stock lugnuts minhha2006 Private 'Wanted' Classifieds 3 11-05-2008 11:51 PM
A seemingly strange spring rate comparison 98kPa Brakes, Steering & Suspension 6 05-23-2002 04:18 PM
is it my car, or does the wrx seem to take a long time to warm up? wrxxtc Newbies & FAQs 16 11-13-2001 02:35 PM
