Old 03-21-2003, 05:57 AM   #1
karl_hungus
Member#: 7507
2002 WRX Wagon
Unhappy Why am I running so rich??
My car recently seems to be running very rich. I have a Greddy A/F gauge and while granny driving I usually stay quite lean... 14s to 13s on the gauge mostly with the occassional trip into the 11s and 10s when I get on the gas.
Lately I'm usually in the 12s to 10s range even under very light throttle with trips into the 8s and 9s. The car also seems to be idling a bit rough and has had 2 instances where it didn't want to start.
My major mods include Brullen header-back, Cobb CAI, and Yoshio tuned ECU. I'm on my second front O2 sensor and am wondering if its starting to crap out on me again.
Any insight would be appreciated.
karl_hungus is offline   Reply With Quote
Old 03-21-2003, 03:07 PM   #2
joefocker20
Member#: 13745
2015 STI
It could be your o2 sensor, since Yoshio should have tuned the car to not runas rich..
joefocker20 is offline   Reply With Quote
Old 03-21-2003, 04:39 PM   #3
karl_hungus
Member#: 7507
2002 WRX Wagon
Ya thats sort of what i've been thinking too.
I wonder if its possible to find out if the O2 is failing. Does anybody know if there is any diagnostics the dealer can do or something I could check through the OBD II with a scan tool?
Old 03-21-2003, 04:41 PM   #4
joefocker20
Member#: 13745
2015 STI
Are you getting any CELs or piss poor gas mileage?
Old 03-22-2003, 03:26 PM   #5
karl_hungus
Member#: 7507
2002 WRX Wagon
On the highway my mileage is good but around town its terrible.
No CELs either...
Old 03-22-2003, 09:02 PM   #6
goobie
Member#: 8273
2006 WRX Wagon
Default ECU Tuned correctly?
Well even though MY00+ RS's tend to run a little rich (Mine seems to as well) Your ECU has been tuned. Maybe you should talk to Yoshio. I would have assumed that by tuning the ECU he would have adusted to the fuel map until he achieved the best A/F ratio for your set-up???
A little OT but...
I have been toying with the idea of doing ECU tuning (and cams), Did you notice an improvment after the tuning?
Cheers,
Chad
goobie is offline   Reply With Quote
Old 03-23-2003, 11:27 AM   #7
karl_hungus
Member#: 7507
2002 WRX Wagon
Default Re: ECU Tuned correctly?
There was definately a noticeable difference after getting tuned with the mods I have. Yoshio will ask you what you want out of your car and he will tune for that. So you could see very different results depending what you want. I went for an autocross setup that maximizes acceleration over top end and the car now has a very linear power delivery, it feels much more smooth and although I don't have numbers to back it up... I'm sure there is more power there.
I got tuned by Yoshio back in October and everything was fine up until recently so I'm sure that something has changed that is causing me too run so rich. It seems to have even gotten worse and my A/F gauge needle is pegged full rich on the highway. I'm definately going to have to do something so I guess I'll fork over the cash and pick up a front O2.
Old 03-23-2003, 12:00 PM   #8
SubaruStu
Member#: 8972
2003 WRX Wagon
A little OT but...
Cheers,
Chad
Time for another test drive??
Stu
SubaruStu is offline   Reply With Quote
Old 03-23-2003, 12:02 PM   #9
SubaruStu
Member#: 8972
2003 WRX Wagon
Default Re: Re: ECU Tuned correctly?
Fortunately the front one is not the "expensive one", about $125
tax incl. from the dealer. The rear is $275
When mine went, it started to idle poorly, sucked gas and lots
of soot on the exhaust pipe, until it started to throw slow response
codes.
Stu.
Old 03-23-2003, 10:11 PM   #10
goobie
Member#: 8273
2006 WRX Wagon
Haha! I was impressed with your car Stu... Is it still running nicely? What impressed me the most about your car was how smooth it delivered power across the entire power band. I would be interested in doing back to back g-tech runs with my car and then you do yours to see how they compare. Other than the cams and ECU tuning, we have a similar set-up... I would be interested to see the results. Doing anything next weekend?? J/K!
Question: Would there be any benefit to raise your rev-limit 500RPM or so with the addition of the cams? Has anyone done it?
Cheers,
Chad
Old 03-24-2003, 08:51 AM   #11
SubaruStu
Member#: 8972
2003 WRX Wagon
Cheers,
Chad
You could definitely get a little more out of it by raising the redline,
even a little. The power does not fade at redline, so I am sure
it would keep pulling well past. I should have done it when I got
the ECU done. There is still more in there. Due to a cramped schedule,
I didn't get a chance to get Yoshio to do any more than the basic
tuning, which was based on 87 octane (which was in the tank at
the time). There is still room to go up to 89 or 90+ octane and raise
the redline another 500 or so. I may send it down for some tweaking
when the weather is a little better for working on the
car. I wish that I could bring myself to spend on a port and polish, and upgraded valvetrain. Sigh.
I should be able to make it to the April meet next week.
Stu
Old 03-24-2003, 09:00 AM   #12
SubaruStu
Member#: 8972
2003 WRX Wagon
Oh yeah, the car s still running fine. It was a little more picky about
starting in the cold weather because of the cams, but it never
let me down. There was an issue with Misfire CELs when it went
from fast idle to normal. I believe that it was due to less than ideal
ignition (the cams are right near the edge and require a good clean
spark). That went away with a new battery. A good set of wires
would also help. The only thing to clean up is the Cat Inefficiency
CEL, if I ever get around to doing the electronic fix.
Cheers...Stu
Why am I running rich? criscross79 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-11-2006 07:26 PM
why am i running better when car is cold. what sensor is it Pat L.I. Normally Aspirated Powertrain 8 03-20-2006 01:06 PM
HELP! car reassembled now running so rich it wont even idle sinnerlv Engine Management & Tuning 10 09-15-2005 11:58 PM
Why am I running rich? spooledwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-07-2005 10:37 PM
Why am I running so rich? Dorkfish Normally Aspirated Powertrain 4 05-22-2004 11:19 PM
