Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 03-21-2003, 09:35 AM   #1
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default USDM STi Injectors
As you may know, 2000+ EJ25 engines in the Impreza, Legacy and Forester use a UJ fuel system (see http://www.endwrench.com/pdf/fuel/FtFuelEmmisionW00.pdf), whereas the WRX and JDM STi use a Denso (aka ND for the old name - Nippon Denso) fuel system. What type and size injectors will the USDM STi use?
I would have expected Denso, but I've been told that the USDM 2.5 STi has reverted to a version of the UJ fuel system. The UJ injectors are said to be the same impedance as those on the WRX and JDM STi, but the connector is blue, they are side feed, and they flow roughly the same as the JDM STi (pink) injectors. Oh, and the so called "green brackets of death" apparently would interfere with the side-feed arrangement and are gone from the USDM STi.
BTW, can someone clue me in to what the acronym "UJ" expands to?
Jon [in CT] is offline
Old 03-22-2003, 08:40 PM   #2
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Jon
I found this
http://www.aeromech.usyd.edu.au/ther...wirl/swirl.htm
Seems "uj" means ??????
Sorry I can't as yet do better than this.
Wombat North is offline
Old 03-22-2003, 09:35 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Thanks, Wombat North, but I am confident that the term UJ, when seen in Subaru service literature, is almost certainly a reference to a fuel injector/system manufacturer's name, not a concept.
Old 03-22-2003, 11:34 PM   #4
xephyr
Member#: 665
1998 2.5 RS-T
Possibly "UNIASIA-JECS"
JECS=Japan Electronic Control Systems=the brand of ECU in all Subarus.
xephyr is offline
Old 03-23-2003, 01:39 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
Bingo. Except the company's name is Unisia Jecs Corporation and, although UJ did supply the ECUs for versions of the WRX PRIOR to the New Age WRX, current WRX ECUs come from Denso.
So would a switch from the Denso fuel system to the UJ fuel system say anything about the USDM STi's ECU? Could FHI have been nervous about the abundant reflashing of WRX Denso ECUs? Might FHI have worried that Denso ECUs may no longer comply with OBD requirements that the OBD computer be "tamper proof?" Would a switch to UJ ECUs solve these problems?
Old 03-23-2003, 01:53 PM   #6
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Maybe it wouldn't make them tamper proof, but perhaps it would keep hacking them from being cost effective.
If there are only a few thousand WRXs with this ECU being sold worldwide per year, perhaps people who research ECU flashing (like ECUTEK), would deem it "not worth their time" to hack these ECUs knowing they will only sell a few hundred units per year.
Corn-Picker is offline
USDM STI Injectors vs JDM Injectors? Any different CC? Chandy69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-05-2015 12:42 AM
EJ20K injectors = USDM STi Injectors? linsavy Pre-2002 Factory Turbo Powertrain 1 04-26-2007 11:33 PM
USDM STi Injectors - JDM WRX Injectors TurboGC8FL Engine/Power/Exhaust 1 02-17-2007 01:47 AM
STi Wing, STi Scoop, Stock STi BPV, USDM STi Injectors, APS CAI keyser_soze MWSOC Private Classifieds 4 09-02-2006 03:07 AM
USDM STi injectors in USDM WRX Lancer3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-08-2005 06:23 PM
