Welcome to the North American Subaru Impreza Owners Club Thursday October 23, 2014
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 03-21-2003, 09:21 AM   #1
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default STi Suspension Geometry
This somehow ended up in my in-basket and I'm passing it along. It's a specification for USDM 2004 Imprezas. Note how the STi's front swaybar is slightly smaller than the WRX's while the rear swaybar is substantially beefier. You AutoX guys will undoubtedly recognize other important differences.
Jon [in CT] is offline
Old 03-21-2003, 12:51 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
wow look at the castor ...
it should be a turning machine
Jaxx is offline
Old 03-21-2003, 01:04 PM   #3
somebody else
Member#: 21618
Yes! This is one of the points Subaru made in their So. Cal. intro event a couple months ago. It is essentially an "anti-lift kit" as standard equipment. As an aside, it causes the STi wheelbase to measure a centimeter or so longer.
Yes, this is a good car.
--scott
somebody else is offline
Old 03-21-2003, 01:53 PM   #4
no_rex_yet
Member#: 7351
04 330cic
That's odd, the wrx sedan and wagon now both have a 17mm rear bar? Didn't the 02-03 sedans have 20mm bars?
no_rex_yet is offline
Old 03-21-2003, 02:44 PM   #5
JT-KGY
Member#: 7852
03 White Lan EVO 8
97 Techno-Violet BMW M3/2
If the front is already 20mm.. then I doubt the rear will be also
20mm... usually rear is smaller as a way for manufacturer adding
some understeer to the car...
Glad it is the reverse for the STi...
Jon, is that right?
JT-KGY is offline
Old 03-21-2003, 03:01 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Yes, according to the manual, the 02 WRX sedan has 20mm stabilizers front and back. It appears for 2004 that the WRX sedan's rear stabilizer has been changed to match the WRX wagon, which remains the same as before, 17mm.
Old 03-21-2003, 05:26 PM   #7
bemani
Member#: 5673
2002 WRX/2005 LGT
09 Ducati M696/ZX6R
17mm? Ouch. Understeer, baby! Now you may just see the oem 20mm rsb go up in value in for sale forum
bemani is offline
Old 03-21-2003, 06:15 PM   #8
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
check the rear camber out too!!!
that will help a lot in neutralizing the car
ellisnc is offline
Old 03-22-2003, 12:58 AM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The performance suspension kit (STi) for the bug-eye uses a 19mm front bar.
However I believe there is a change to one of the figures you posted.
ANZAC_1915 is offline
Old 03-22-2003, 03:13 AM   #10
Kostamojen
Member#: 2272
2013 Subaru 599 :P
Galaxy Blue Sexy
I dont even know why they upsized the front bar on the new cars to 20mm at all... Should have just left them at 19mm like the 93-01's, oh well
Kostamojen is offline
Old 03-23-2003, 04:26 PM   #11
ae82gtm
Member#: 31740
2004 STi
WR Blue
check out the notes at the end. It says that front + rear toe are adjustable (good) but ONLY front camber is adjustable (not so good).... but the aftermarket should take care of that, via eccentric bolts or camber plates.
just a thought,
Mikhal
http://www.geocities.com/ae82power
ae82gtm is offline
Old 03-23-2003, 08:11 PM   #12
ellisnc
Member#: 4229
2003 S2000
just a thought,
Mikhal
the WRX is the same way...
ellisnc is offline
Old 03-23-2003, 08:33 PM   #13
kpratte
Member#: 2760
'08 4Runner V8 Ltd
'10 Tundra Ltd CrewMax
[b]17mm? Ouch. Understeer, baby!
if that was the only changed, then yes, but they supposedly also change the strut dampening, so we'll have to see how much body roll it has and how it affects understeer. The '03 Forester revised suspension you notice practically pulling out of the parking lot.. Heck even my wife noticed it.
- Ken
kpratte is offline
Old 03-23-2003, 10:46 PM   #14
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Without knowing spring rates it is difficult to guess the effects of any given sway bar combo.
Old 03-24-2003, 03:15 AM   #15
97itr153
Member#: 17887
05 LGTW Ltd AT
05 Evo RS
Extra Castor on the STi = more direct steering feedback and greater tendency for self-centering = good!
97itr153 is offline
Old 03-24-2003, 11:06 AM   #16
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
um...sorta
more like
Extra Castor on the STi = more direct steering feedback and less tendency for self-centering = twitchy!
Jaxx is offline
Old 03-24-2003, 12:49 PM   #17
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
I wonder how the rear camber values are going to affect wheel/tire choice for those purchasing aftermarket wheels. From what I've experienced, the WRX slightly rubs with +48mm offset wheels with 225 width Kumhos and rear camber at -1.4 (using camber bolts)...I've run less but the rubbing was worse with cornering.
All of this isn't a problem of course with the stock wheels and 225 width tires.
Hmm...just speculation I guess but it would seem to me that wheel and tire choice is going to be tough (unless the fender is changed on the STi...which I doubt).
AnimalMother
AnimalMother is offline
Old 04-02-2003, 02:35 PM   #18
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
more like
Uh, I think 97itr153 had it right.
drees is offline
Old 04-02-2003, 02:42 PM   #19
JT-KGY
Member#: 7852
03 White Lan EVO 8
Can someon please describe "self-centering"??
I've heard it a few times... not sure what it means..
JT-KGY is offline
Old 04-02-2003, 02:55 PM   #20
drees
Member#: 25905
2003 Silver Wagon
That's when you let go of the steering wheel and it straightens out if you had it turned. It keeps it straight if you are going straight. Additional castor increases this effect.
drees is offline
STi vs WRX suspension geometry AllAWD Brakes, Steering & Suspension 3 11-20-2006 05:27 PM
WRC suspension geometry pcowan Brakes, Steering & Suspension 1 10-16-2003 02:32 AM
Suspension Geometry = anti-lift somebody else STi Forum Archive 9 01-16-2003 05:36 PM
Attn: People who understand suspension geometry and alignments, please help.. paultg Brakes, Steering & Suspension 6 08-10-2002 06:58 AM
suspension geometry question... TerenceT Brakes, Steering & Suspension 10 03-04-2002 07:12 PM
