Old 03-21-2003, 12:50 PM   #1
waitandbleed92
Member#: 33990
09 WRX STI
Lightning Red
Default Will cusco rear sway bar bolt up to factory sway bar mounts?
On a 02 wrx?
waitandbleed92 is offline   Reply With Quote
Old 03-21-2003, 12:53 PM   #2
Safir
Member#: 3873
. Paradise is
like Disney with hookers
yes - the only thing you need to replace are the bushings - and ones o fit the bar you purchase will be included with it.
Note - this is a direct answer to your question... the suitability of the factory mounts to your uprated swaybar is an entirely different matter.
Safir is offline   Reply With Quote
Old 03-21-2003, 03:28 PM   #3
Austin
Member#: 7089
2016 STi
Yes. Fits like a glove. I've been using the 24mm bar with stock mounts and stock endlinks for about two years.
Austin is offline   Reply With Quote
Old 03-21-2003, 08:58 PM   #4
Carbon
Member#: 6981
Yes. Put a lot of silicone grease on the Cusco bushings. And do a search first next time.
Carbon is offline   Reply With Quote
will usdm sti strut assembly bolt up to my usdm 03 wrx? blackie Brakes, Steering & Suspension 8 12-01-2005 02:09 PM
will the 05 sti exhaust bolt up to an 02 wrx sam caldwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 05-03-2005 06:19 PM
Will a 2.5rs catback bolt up to a 2.2L ? TurboCharged97L Normally Aspirated Powertrain 4 10-13-2004 05:53 AM
will axelback for JDM STi bolt up to USDM WRX? silverF4turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-04-2003 02:42 AM
will the recaro SRD seats bolt up to my stock rails and brackets slammedWRX Interior & Exterior Modification 9 03-06-2003 03:43 PM
