#1 |
Member#: 18757
Vehicle:2000 2.5RS Coupe Blue |
Just finished adding some new parts to my car
My Mods are Borla Header Apexi n1 Exhaust Weapon R intake Act Clutch And Pressure Plate Unorthodox Light weight flywheel zex 55 shot Short Shift Kit Carbon Fiber hood Eibach Lowering Springs 17' wheels with toyo proxe fz4 These are my mods, Do you guys know about how many hp or how I would run In the 1/4, My Brother ran a 14.8 with a similar set up, but his is an auto, so I figure I should be able to run a low 14. Also what do you think my next mods should be.
#2 |
Member#: 4461
NWIC
Vehicle:02 2.slow |
Should be high 13s.. What part of oregon are you in?
#3 |
Member#: 18757
I live in McMinnville
#4 |
Member#: 13745
RMIC
Vehicle:2004 STI Silver |
Next mods should be Cams, some type of engine management, weight removal, and ditch the Weapon R Intake for a Cobb.
#5 |
Member#: 3149
Vehicle:01 V7 GC/R32 sky |
I agree with Joefocker once again
Get rid of the weapon R and go with cobb for sure. Cams should go on your "to do" list as well, everyone who has them, loves them.Dan 1/4 mile should be in the low 14s. |
#6 |
Member#: 4461
NWIC
Vehicle:02 2.slow |
14's??? Ive seen people on here run high 13's with far less done than that.
#7 |
Member#: 18757
I thought that I might do cams next which would you recomend, the street cams from cobb. I thought about ditching the weapon r but I live in oregon and it rains a lot here, but my brother has the injen cold air and he hasnt had any problems with rain getting in, so I guess thats something else to think about. Thanks for your suggestions. I was also thinking about getting a rear sway bar to stiffen things up a bit. Do you guys know if there is a camber kit for our cars because my tires wore down fairly fast on the inside, so I would like to do something to even out the wear on the tires.
#8 |
Member#: 3149
I had the cobbs street cams in my car and loved them. Good power gains for sure. I have a cobb intake and have no problem with water at all, unless you are in water up to your wheel well, you shouldnt have a problem.
I switched to cobbs racer cams which are more aggressively ground for N/A only...they also make power way past the stock redline (8,500 rpm.). Idle quality suffers...nice and lumpy! Good luck. Dan |
#9 |
Member#: 17178
Vehicle:2001 2.5RS Coupe Silverthorn Metallic |
i have real bad inner tread wear as well.. its down to the chord now. i also would wanna know if a camber kit would help even this out? sorry for being a bit off topic..
#10 |
Member#: 12235
NESIC
Vehicle:2006 WRX Limited Red |
When Installing cams, what other mods would be recommended to go along with the Cobb street cams?
#11 | |
Member#: 34
VIC
Vehicle:2005 WRX STi World Rally Blue |
Go get an alignment.
#12 | |
Member#: 13745
RMIC
#13 | |
Member#: 17178
#14 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
Nope. Imprezas have a high degree of adjustabiity (for a factory setup).
| Thread Tools | |
| Display Modes | |
| Got bored so I added a decal to my car... | the2rz | Mid Atlantic Impreza Club -- MAIC | 15 | 09-29-2004 03:51 PM |
| Added some goodies to my car again | Unabomber | Mid Atlantic Impreza Club -- MAIC | 3 | 07-28-2003 12:42 AM |
| just some new pics of my car | rpone605 | Member's Car Gallery | 16 | 01-22-2002 06:23 PM |
| New intro to my car page! | SoCalScooby | Member's Car Gallery | 1 | 10-24-2001 11:13 PM |
