Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 03-21-2003, 05:16 PM   #1
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Default Rotating JIC camber plates to get max castor?
I just got my JIC's today.
I'd like to install them with the camber plate rotated so that I can max out the castor. The slot in the plate is cut at a bit of an angle. When they are rotated, the slot should let me push the top of the strut very far back, but they only go inward a bit, so they should only increase the negative camber by a little bit. There should be enough adjustment on the normal front camber bolt to set the camber to a reasonable setting.
I know that people have suggested doing this, but has anybody actually done it? Any interference problems?
Thanks,
Kevin
Red Rocket is offline   Reply With Quote
Old 03-21-2003, 07:46 PM   #2
Carbon
Member#: 6981
If you swap sides (move left camber plate to right strut and vice versa) you should be able to move it in the castor direction entirely.
I'm not saying you should do this or anything, but it gives you even more castor, and doesn't affect your camber.
Carbon is offline   Reply With Quote
Old 03-22-2003, 12:49 AM   #3
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I took a close look at mine, and it looks like they were already swapped...oops....
I looks like that it should be how you said, but not quite 100% in the castor direction. Close enough though.
Man these things are cool.....just sooooo beefy.
Kevin
Old 03-22-2003, 03:20 AM   #4
Halz
Member#: 6674
1989 Nissan 240SX
Midnight Blue Pearl
Are the bolt holes not equally spaced in the strut tower? I didn't think there should be a left side and a right side for the car...
While increasing caster is good, increasing the KPI (kingpin inclination) (also called SAI, steering axis inclination) is not good! Higher KPI basically subtracts from the negative camber-adding effects of caster.
Making camber adjustments at the strut tower (as opposed to eccentric bolts further down the strut) has an effect on KPI. Pulling the top of the strut 'in', giving negative camber, also increases KPI.
If at all possible, arrange the plates so the top of the strut is not only pulled back to the firewall, but is also pulled 'out', away from the engine.
Halz is offline   Reply With Quote
Old 03-24-2003, 01:38 AM   #5
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
I've been running my camber plates rotated for both camber and caster adjustment for a couple months now. The only issue was weird toe measurments, but an alignment solved that problem.
You should be fine doing it.
thebusiness999 is offline   Reply With Quote
RCE Camber Plates vs. Whiteline Max-C Plates? williaty Brakes, Steering & Suspension 48 01-08-2009 07:36 PM
JIC camber plates w/ Tein SS coilovers? Carreragt2e Brakes, Steering & Suspension 3 07-18-2008 01:33 PM
JIC camber plates front WRX milkman Suspension/Brakes/Handling 11 10-05-2007 02:54 PM
Which camber plates to get? Got Pink? Motorsports 44 05-19-2005 03:05 PM
JIC camber plates for sale (GC body) subyguy2 Mid Atlantic Impreza Club -- MAIC 2 05-20-2003 09:06 PM
Message Board Statistics All times are GMT -4. The time now is 03:19 AM.
