Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 03-22-2003, 06:17 AM   #1
wrx_n_ah
Member#: 17254
2002 WRX Wagon
Platinum Silver
Wink changed dash color/how to change cruise control light?
So I changed the bulb condoms on for my dash, stereo and hvac controls. Now I want to change the cruise control/fog lamp ones too. Can anyone tell me how to get to the bulbs for those? Thanks.
Oh, and here are some pics so far. They are a lot brighter here since the iris of the camera is wide open. The LCDs in the gauge cluster and stereo are also more of a teal as I used blue condoms there.
wrx_n_ah is offline   Reply With Quote
Old 03-22-2003, 07:02 PM   #2
LYHTSPD
Member#: 26374
2004 WRX Sedan
San Remo Red
i like the red color
LYHTSPD is offline   Reply With Quote
Old 03-22-2003, 08:00 PM   #3
SpoolinUp
Member#: 34159
That looks good.
I know you were looking for the answer to your question, but was the intallation of them hard to get to? and where did u get the colored condoms for the bulbs.
Thanx
SpoolinUp is offline   Reply With Quote
Old 03-22-2003, 09:41 PM   #4
wrx_n_ah
Member#: 17254
2002 WRX Wagon
Platinum Silver
It was pretty easy to replace the bulb condoms. You can get to the bulbs of the gauge cluster pretty easily from the back, and the hvac controls are also pretty simple. The stereo was pretty easy except for the LCD which was a bit of a pain. Overall, I would say 2 hours total or so. I took longer because I played with blue and red covers. The blue isn't as bright as the red, and not as blue. Do a search for dash lighting and you'll find some threads on how to do it. You can get the covers from partsexpress.com. Search for lamp covers.
Old 03-26-2003, 12:52 AM   #5
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
You have to take the switches out from the dash. You might need to push them out from behind. Once you have them out there are little sockets that twist out of the switch, just put some condoms on the bulbs and re-install them. The bulbs are very small, smaller than the dash and HVAC bulbs. I don't know if you need smaller condoms or not.
Khail
khail19 is offline   Reply With Quote
Old 03-26-2003, 01:42 PM   #6
Tobey
Member#: 21400
2015 WRX Limited
ISM
has anyone been able to change the color of the clock or compass in the subaru mirror?
Tobey is offline   Reply With Quote
Old 04-06-2003, 10:55 PM   #7
imprezive one
Member#: 16906
2k3 wrx wagon
Wow. That's nice, I heard that just changing the bulb condoms didn't provide enough brightness but I guess it does. What kind of guages are those? OEM?
imprezive one is offline   Reply With Quote
Old 04-09-2003, 07:42 PM   #8
imprezive one
Member#: 16906
2k3 wrx wagon
what size bulb condoms did you use? .12" or .2"? Thanks.
Old 04-11-2003, 10:41 AM   #9
silvertoy
Member#: 23580
2003 WRX Wagon
You'll have to use both sizes, I think two packages of the .2 and one package of the .12 was adequate to do hvac, stereo, and instrument as well as boost guage. You'll want to put two on in most cases to give a deeper (less pink) color.
silvertoy is offline   Reply With Quote
Old 04-16-2003, 03:48 AM   #10
Adiliyo
Member#: 33762
2004 WRX
WR Blue
woow, that looks great! i wanted a red guages, if it's easy like you say maybe i'll try it out this summer...anyways, i'm jealous!
Adiliyo is offline   Reply With Quote
Old 04-17-2003, 04:58 PM   #11
elsanto
Member#: 34832
1989 M3
i did my fog and Cruise switches as well.. its a PITA... you have to take apart the switch because the bulb doesnt color the light, there is a film on the backside of the peice you see (the little window) what i did was take apart the switch, sand off the backside of this, and then reassemble the switch.. be careful with 2 things though.
1. taking apart the switch theres a tiny spring (or 2?) that like to pop when you open them up.
2. when sanding not to press too hard on the backside of the window, as the entire plastic peice will pop out, this happened to me, and i crazy glued it back in with no problems.. now that i think about it, that may be easier than sanding with a pencil eraser (i put the sandpaper around a pencil eraser to get down into the switchs..
I also managed to blow one of the bulbs in the cruise indicator and havent gotten around to fixing this...
the only light i couldnt figure out how to do was the lighted window switch on the drivers side.. its a tiny led.. i mean TINY, i didnt really feel like soldering on that board..
let me know if you have any Q's.. I still havent done my gauge cluster, thats next. btw yours looks great.
elsanto is offline   Reply With Quote
Old 04-17-2003, 06:06 PM   #12
bucknroses
Member#: 25961
2002 WRX Wagon
WR Blue
I did all of my lights in blue condoms (dash, clock, HVAC, gear select lights(4EAT), and fog/cruise). For the fog/cruise, just take a flat screwdriver with tape and pry them from the bottom. Once out there are 2 circles on the side. Use a screwdriver to turn these and pull the bulbs out (use .12" condoms). Careful when using the screwdriver, there are multiple slots, some have wiring that i cut with the screwdriver on accident. Also, these were stingy in coming out, they won't just fall. The condoms were strong enough to penetrate throught the green film and change the color. It is a teal color, as is the rest of my interior to match my head unit (Kenwood Excelon). Don't know if it will work with red. On the clock I used 2 layers of blue acetate (local art supply store) to get that teal. I used 2 condoms for every light. Hope this helps.
bucknroses is offline   Reply With Quote
Old 04-17-2003, 08:48 PM   #13
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
Thats cool. The member Griffy on this board has his whole interior in red also. Very nice... but rather dull lighting. Alittle too dim. Where you able to get around that?
Oo DaRk StAr oO is offline   Reply With Quote
Old 04-19-2003, 07:38 AM   #14
subyroo
Member#: 8520
2003 2.5 XS Forester
White over Dk Grey
wrx_n_ah
Q. How does the radio settings show up during the daytime?
I find the standard green bloody hard to see on my MY01 Liberty (aka Legacy) here "downunder", I am supposed to be able to depress the Volume Knob for 2 seconds and the lighting will increase ala the Climate Control (that one works) but it only turns the radio off which it is supposed to do anyway.
subyroo is offline   Reply With Quote
Old 04-21-2003, 02:44 AM   #15
GDBlitz
Member#: 32758
2003 WRX
Default stereo
how do you take apart the stereo to get to the lights?
GDBlitz is offline   Reply With Quote
Old 04-21-2003, 12:01 PM   #16
Kooldino
Member#: 34561
2001 Protege MP3
Vivid Yellow
Sweet! Looks like the gauges I have on my mp3. I used white faced Autometer gauges w/ red condoms to match the orange color...
I'd post pics, but I can't figure out how...
Kooldino is offline   Reply With Quote
Old 04-24-2003, 03:01 AM   #17
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
Is this possible for a MY00 GC8?
pistoffjstr is offline   Reply With Quote
How to change dash light color? lawrence_P Electrical & Lighting 4 10-04-2009 07:41 PM
How to change dash lights to LED?? Skin Irritant Interior & Exterior Modification 3 01-23-2009 04:45 PM
how to set cruise control > 80 mph ride5000 Engine Management & Tuning 27 11-17-2003 01:41 AM
How to replace climate control lights? Snowphun Legacy Forum 4 04-12-2002 02:20 AM
Does anybody know how to change the light in the dash? imajinaxn Interior & Exterior Modification 2 02-08-2001 01:49 AM
