Old 03-22-2003, 05:48 AM   #1
topgrinder
Member#: 31649
Default need help with my utec log....please
heya folks im runnin a stage 4 modiefied for a vf35 turbo...this is a typical log for me... when i hit the throttle i run rich while acclerating.. is this ok or should i increse timing or decrease fuel? .... also after i let go of the throttle in high rpms my log oftens shows i read lean at some points between 1200-3000 .. is this normal or should i tune this out?? any advice would be grateful... im also noticing the psi on my logger reads much lower than my boost gauge.. which one is correct???????? thanx ahead of time for any helpful replies
651 -9.0 1.2 0 00 00 14.7 +14.2 3.0 ECU. -5.5 ECU. 1.2
645 -9.0 1.3 0 00 00 14.7 +14.4 3.0 ECU. -5.5 ECU. 1.2
644 -9.0 1.3 0 00 00 14.7 +14.3 3.0 ECU. -5.5 ECU. 1.2
643 -8.8 1.3 0 00 00 14.7 +14.4 3.0 ECU. -5.5 ECU. 1.2
606 -8.8 1.3 0 00 00 14.7 +14.7 3.0 ECU. -5.5 ECU. 1.1
642 -8.8 1.7 10 00 00 14.7 +14.0 7.0 ECU. -5.5 ECU. 2.1
1142 -7.0 1.8 16 00 00 13.4 +15.3 28.0 ECU. -5.5 ECU. 1.9
1437 -5.2 2.1 17 00 00 14.6 +25.0 4.0 ECU. -5.6 ECU. 2.0
1673 -3.4 2.2 17 00 00 17.0 +29.0 6.0 ECU. -5.7 ECU. 2.1
1846 -1.6 2.4 81 00 00 14.4 +30.9 8.0 ECU. -5.9 500.00 2.3
1974 -1.4 2.4 96 10 00 13.1 +30.6 9.0 ECU. -5.5 500.00 2.3
2022 -1.0 2.5 97 10 00 12.5 +30.2 10.0 ECU. -5.4 500.00 2.3
2115 -0.6 2.5 98 10 00 12.7 +30.2 11.0 ECU. -5.4 500.00 2.4
2256 -0.4 2.6 97 10 00 12.2 +30.8 11.0 ECU. -5.4 500.00 2.4
2342 -0.2 2.6 97 10 00 12.4 +30.2 12.0 ECU. -5.3 500.00 2.4
2500 +0.4 2.7 97 10 00 12.2 +30.9 13.0 ECU. -5.2 500.00 2.6
2662 +0.6 2.8 97 10 00 12.0 +31.0 15.0 ECU. -5.0 500.00 2.7
2810 +1.2 2.9 98 10 00 12.2 +31.0 16.0 ECU. -4.7 500.00 2.7
3000 +1.6 3.0 98 20 00 rich +28.9 19.0 ECU. -4.4 360.00 2.9
3211 +2.2 3.0 97 20 00 rich +27.7 22.0 ECU. -4.1 360.00 2.9
3411 +2.8 3.2 97 20 00 rich +26.9 25.0 ECU. -4.0 360.00 3.1
3699 +3.8 3.3 97 30 00 rich +25.2 30.0 ECU. -4.1 360.00 3.2
3972 +5.4 3.5 97 40 00 rich +21.9 38.0 ECU. -4.8 360.00 3.4
4301 +7.6 3.7 97 60 00 rich +15.6 51.0 ECU. -6.0 360.00 3.7
4741 +10.0 3.9 97 70 00 rich +17.4 60.0 +23.0 -6.0 360.00 3.7
5159 +12.0 4.1 97 70 00 rich +23.4 69.0 +23.0 -6.2 340.00 3.8
5518 +13.6 4.1 97 80 00 rich +23.4 74.0 +23.0 -6.2 340.00 3.9
5858 +14.4 4.2 97 80 00 rich +25.1 79.0 +24.1 -6.3 340.00 3.9
6060 +14.2 4.3 97 70 00 rich +26.9 82.0 +25.0 -6.1 340.00 4.0
6640 +13.8 4.3 97 70 00 rich +31.1 85.0 +25.7 -5.7 320.00 4.0
7002 +13.2 4.3 97 70 00 rich +30.7 87.0 +26.0 -5.3 320.00 4.0
6816 +13.0 4.3 97 70 00 rich +31.4 86.0 +26.0 -5.0 320.00 4.0
5151 +13.4 4.2 97 80 00 14.0 +23.3 86.0 +23.0 -6.1 360.00 3.8
4510 +13.8 4.0 97 80 00 rich +14.9 62.0 +22.0 -6.0 360.00 3.7
4655 +14.6 3.9 97 80 00 rich +16.7 64.0 +22.5 -6.0 360.00 3.7
4789 +15.0 4.0 97 90 00 rich +18.3 65.0 +23.0 -6.0 360.00 3.8
4916 +15.8 4.0 97 90 00 rich +18.9 68.0 +23.0 -6.0 360.00 3.8
4938 +15.8 4.0 97 80 00 rich +20.7 69.0 +23.0 -6.2 340.00 3.8
5151 +15.8 4.1 97 80 00 rich +22.7 71.0 +23.0 -6.2 340.00 3.8
5208 +15.6 4.1 97 80 00 rich +23.3 73.0 +23.0 -6.2 340.00 3.9
5464 +14.8 4.1 97 80 00 rich +23.3 75.0 +23.0 -6.2 340.00 3.9
5050 +14.8 3.8 18 00 00 rich +29.2 31.0 ECU. -5.5 ECU. 2.0
5081 +8.6 2.2 0 00 00 rich +10.7 31.0 ECU. -5.5 ECU. 2.0
4960 +2.2 2.1 0 00 00 24.2 +10.7 31.0 ECU. -5.5 ECU. 2.0
4761 -3.8 2.1 0 00 00 24.2 +10.8 31.0 ECU. -5.5 ECU. 1.9
4323 -10.6 2.0 0 00 00 24.5 +11.1 31.0 ECU. -5.5 ECU. 1.8
3512 -11.4 1.8 0 00 00 24.5 +11.3 31.0 ECU. -5.5 ECU. 1.7
3063 -11.6 1.7 0 00 00 24.2 +11.3 31.0 ECU. -5.5 ECU. 1.8
3055 -11.6 1.6 0 00 00 24.5 +11.3 31.0 ECU. -5.5 ECU. 1.5
2992 -11.8 1.6 0 00 00 24.5 +11.4 31.0 ECU. -5.5 ECU. 1.5
2949 -11.8 1.6 0 00 00 24.2 +11.4 31.0 ECU. -5.5 ECU. 1.5
2883 -12.0 1.6 0 00 00 24.2 +11.5 31.0 ECU. -5.5 ECU. 1.5
2836 -12.2 1.6 0 00 00 24.2 +11.5 31.0 ECU. -5.5 ECU. 1.5
2773 -12.2 1.6 0 00 00 24.2 +11.5 31.0 ECU. -5.5 ECU. 1.5
2750 -12.2 1.6 0 00 00 24.5 +11.5 31.0 ECU. -5.6 ECU. 1.5
2688 -12.2 1.6 0 00 00 24.5 +11.5 31.0 ECU. -5.6 ECU. 1.5
2639 -12.2 1.6 0 00 00 24.5 +11.8 31.0 ECU. -5.6 ECU. 1.5
2566 -12.2 1.6 0 00 00 24.5 +11.6 31.0 ECU. -5.6 ECU. 1.5
2517 -12.0 1.6 0 00 00 24.2 +11.7 31.0 ECU. -5.6 ECU. 1.5
2476 -12.2 1.6 0 00 00 24.5 +11.8 31.0 ECU. -5.6 ECU. 1.5
2410 -12.2 1.6 0 00 00 24.2 +11.8 31.0 ECU. -5.6 ECU. 1.5
2380 -12.0 1.6 0 00 00 24.2 +11.6 31.0 ECU. -5.6 ECU. 1.5
2365 -11.8 1.6 0 00 00 24.2 +11.8 31.0 ECU. -5.6 ECU. 1.5
2347 -11.8 1.6 0 00 00 24.0 +11.7 31.0 ECU. -5.6 ECU. 1.5
2347 -11.6 1.6 0 00 00 24.2 +11.7 31.0 ECU. -5.6 ECU. 1.5
2313 -11.8 1.6 0 00 00 lean +11.8 31.0 ECU. -5.6 ECU. 1.5
2318 -12.0 1.6 0 00 00 24.5 +11.8 31.0 ECU. -5.6 ECU. 1.5
2272 -12.0 1.5 0 00 00 24.2 +11.8 31.0 ECU. -5.6 ECU. 1.4
2261 -12.0 1.5 0 00 00 24.5 +11.8 31.0 ECU. -5.6 ECU. 1.4
2240 -12.0 1.5 0 00 00 24.5 +11.8 31.0 ECU. -5.6 ECU. 1.4
2223 -11.8 1.5 0 00 00 24.2 +11.9 31.0 ECU. -5.6 ECU. 1.4
2191 -12.0 1.5 0 00 00 24.2 +11.9 31.0 ECU. -5.6 ECU. 1.4
2195 -12.0 1.5 0 00 00 24.5 +12.0 31.0 ECU. -5.6 ECU. 1.4
2171 -11.8 1.5 0 00 00 24.5 +11.8 31.0 ECU. -5.6 ECU. 1.4
2161 -11.8 1.5 0 00 00 24.2 +11.9 31.0 ECU. -5.6 ECU. 1.4
2135 -11.8 1.5 0 00 00 24.2 +11.9 31.0 ECU. -5.6 ECU. 1.4
2107 -11.8 1.5 0 00 00 24.5 +11.9 31.0 ECU. -5.6 ECU. 1.4
2100 -11.8 1.5 0 00 00 24.2 +11.9 31.0 ECU. -5.6 ECU. 1.4
2075 -11.8 1.5 0 00 00 lean +11.8 31.0 ECU. -5.6 ECU. 1.4
2063 -11.8 1.5 0 00 00 24.5 +11.9 31.0 ECU. -5.6 ECU. 1.4
2042 -11.8 1.5 0 00 00 24.5 +12.0 31.0 ECU. -5.6 ECU. 1.4
2044 -12.0 1.5 0 00 00 24.5 +12.0 31.0 ECU. -5.6 ECU. 1.4
2119 -12.0 1.8 3 00 00 24.2 +17.2 8.0 ECU. -5.6 ECU. 1.9
2303 -11.2 2.0 5 00 00 16.4 +35.1 5.0 ECU. -5.6 ECU. 1.9
2310 -10.2 1.9 0 00 00 15.3 +36.8 5.0 ECU. -5.6 ECU. 1.6
2219 -9.8 1.7 0 00 00 12.9 +20.3 3.0 ECU. -5.6 ECU. 1.6
2143 -9.8 1.6 0 00 00 13.1 +15.4 3.0 ECU. -5.6 ECU. 1.4
2033 -10.4 1.5 0 00 00 13.5 +12.0 3.0 ECU. -5.6 ECU. 1.4
1982 -11.2 1.4 0 00 00 23.7 +12.0 3.0 ECU. -5.7 ECU. 1.3
1970 -11.6 1.6 0 00 00 24.0 +14.8 2.0 ECU. -5.7 ECU. 1.5
2079 -11.4 1.8 2 00 00 24.0 +23.5 3.0 ECU. -5.6 ECU. 1.7
2182 -11.0 1.8 1 00 00 16.5 +28.1 4.0 ECU. -5.6 ECU. 1.7
2197 -10.4 2.0 6 00 00 15.3 +29.7 12.0 ECU. -5.6 ECU. 2.1
2303 -9.0 2.3 10 00 00 12.8 +36.6 7.0 ECU. -5.6 ECU. 2.1
2352 -7.6 2.3 10 00 00 15.4 +36.6 8.0 ECU. -5.6 ECU. 2.1
2377 -6.6 2.3 10 00 00 14.4 +36.5 8.0 ECU. -5.6 ECU. 2.2
2392 -5.4 2.3 10 00 00 13.5 +36.9 8.0 ECU. -5.6 ECU. 2.2
2406 -5.0 2.3 10 00 00 13.7 +36.9 8.0 ECU. -5.6 ECU. 2.2
2411 -5.0 2.3 10 00 00 14.0 +36.9 8.0 ECU. -5.6 ECU. 2.1
2415 -5.2 2.3 10 00 00 14.2 +36.9 8.0 ECU. -5.6 ECU. 2.2
2332 -5.4 1.7 0 00 00 13.9 +35.5 5.0 ECU. -5.6 ECU. 1.6
2177 -6.6 1.6 0 00 00 rich +20.6 3.0 ECU. -5.6 ECU. 1.5
2146 -8.0 1.7 1 00 00 rich +19.6 3.0 ECU. -5.6 ECU. 1.6
2136 -9.4 1.8 1 00 00 13.2 +25.0 3.0 ECU. -5.6 ECU. 1.6
2191 -10.4 2.0 5 00 00 16.1 +27.7 33.0 ECU. -5.6 ECU. 2.0
2297 -9.6 2.2 7 00 00 12.0 +39.4 5.0 ECU. -5.6 ECU. 2.0
2318 -8.6 1.9 0 00 00 17.0 +39.7 5.0 ECU. -5.6 ECU. 1.6
2178 -8.4 1.7 0 00 00 12.3 +19.7 3.0 ECU. -5.6 ECU. 1.5
2093 -8.8 1.5 0 00 00 12.8 +14.7 3.0 ECU. -5.6 ECU. 1.4
1988 -10.0 1.5 0 00 00 14.2 +12.1 3.0 ECU. -5.7 ECU. 1.4
1930 -11.2 1.4 0 00 00 lean +12.0 3.0 ECU. -5.7 ECU. 1.3
1909 -11.6 1.4 0 00 00 lean +12.1 3.0 ECU. -5.7 ECU. 1.3
1888 -11.8 1.5 0 00 00 24.0 +12.0 3.0 ECU. -5.7 ECU. 1.4
2055 -11.6 2.0 7 00 00 24.0 +17.5 4.0 ECU. -5.6 ECU. 2.0
2266 -10.4 2.1 7 00 00 14.0 +39.4 6.0 ECU. -5.6 ECU. 2.0
2272 -9.0 2.1 7 00 00 14.5 +39.1 6.0 ECU. -5.6 ECU. 2.0
2308 -7.6 2.2 8 00 00 14.2 +38.7 7.0 ECU. -5.6 ECU. 2.1
topgrinder is offline   Reply With Quote
Old 03-22-2003, 09:04 AM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Looks good. You'll want to adjust your TPS calibration so you read 100% at WOT. You also might want to adjust your MAP max value to the highest value your boost reached. This adjusts the whole boost curve so everything fits nicer. You will also actually use the 100 load column when your MAP is adjusted.
Lean during a shift is fine. It happens to everyone.
Why are you running such low boost? I thought that stage 4 was 17-18 psi or so.
Hope I've helped.
Seth
mbiker97 is offline   Reply With Quote
Old 03-22-2003, 09:05 PM   #3
topgrinder
Member#: 31649
my autometer boost gauge shows bout 2 psi higher boost than my utec logger..... seems like my guage is off........ also i will calibrate my tps,, i thought i did it correctly first,, went from 96 to 98,, i guess i have to fine tune it some more
Old 03-24-2003, 12:13 PM   #4
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
as long as you see rich while accelerating and no knock counts, you are set in terms of safety. But yea, up the boost a bit. At see level, I would favor the UTEC over gauges. Also, your spool up is oddly slow, you may want to play with the boost gain if it doesnt spool up quicker with higher boost values.
HS WRB-rex is offline   Reply With Quote
Need help with my home AC please!!! Speed Factory Mid Atlantic Impreza Club -- MAIC 0 06-28-2008 11:53 AM
Need help with my headunit install, please! Sylon Car Audio, Video & Security 8 04-19-2007 01:14 PM
Need help with my Utec WRX_Nick UTEC 7 06-21-2006 05:46 PM
need some help with my utec logs Sharky NRK Engine Management & Tuning 2 11-18-2005 08:42 PM
I need help with my Ground Controls-Please MY99 2.5GT Brakes, Steering & Suspension 15 07-04-2001 02:37 PM
Message Board Statistics All times are GMT -4. The time now is 07:47 PM.
