Old 03-22-2003, 03:45 PM   #1
impreza2002
Member#: 30428
1999 Impreza 2.5RS
RALLY BLUE
Smile Redline WaterWetter???
Have anyone using this "redline waterwetter" in their car? I just bought one, but don't know how to apply it. It would be great if someone can give me some directions on it! Thanks.
impreza2002 is offline   Reply With Quote
Old 03-22-2003, 06:04 PM   #2
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
I use the Redline Water Wetter in my car... I noticed absolutely no subjective difference, but I have no objective measurement means other than the stock water temp gauge (which did not change after the addition of water wetter).
Instructions:
1) Open cap
2) Open foil wrap
3) dump into coolant tank.
Actually, if your coolant level is full when your car is completely cold, you need to siphon out the approximate contents of the Water Wetter bottle. Since I needed to top off my coolant anyway, I was good to go by just adding it in.
-Bob
dookiebob is offline   Reply With Quote
Old 03-22-2003, 10:35 PM   #3
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
um...arent there directions on the bottle?
I believe you jsut add it to the coolant.
DDMan is offline   Reply With Quote
Old 03-22-2003, 11:34 PM   #4
kickin_81
Member#: 16679
2004 Forester XT
It'd be better to do a coolant flush and mix it into the radiator when you're refilling. That way, you won't be overfilling the already filled radiator.
kickin_81 is offline   Reply With Quote
Old 03-23-2003, 12:12 AM   #5
philip_g
Member#: 32906
unless you're running pure water for the track or something, I'd skip it. I ran it in my motorcycle (aprilia, with a digital water temp gauge) and noticed ZZZZERO degrees difference over straight antifreeze blend.
philip_g is offline   Reply With Quote
Old 03-23-2003, 12:14 AM   #6
BillJC
Member#: 31002
Your car will run just as hot after you put the waterwetter in as it did before. The thermostat determins the operating tempurature. What the waterwetter does is increase the cooling capability of the coolant. In basic terms, the car will cool down faster but, will operate at the same temp.
BillJC is offline   Reply With Quote
Old 03-23-2003, 01:14 AM   #7
philip_g
Member#: 32906
the thermostat is open or closed, once you hit XX degrees it opens. You probably don't run right at 180F or w/e the stat is. Bottom line the stuff is ideally to improve the cooling properties of pure water. The bottle says you can run it in glycol but I don't believe that was ever the intention.
Old 03-23-2003, 01:44 AM   #8
Roo
Member#: 14931
Default I'd swear by it!!
I had this product placed in my car when it had the head gaskets replaced, and the car seems to run one notch cooler on the temp gauge then before the head gaskets blew. Which when I'm running at speed on the back roads, is VERY important.
'Officer, I was only doing 55 (using base 2 math)'
Roo is offline   Reply With Quote
Old 03-23-2003, 01:04 PM   #9
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
you dont have to overfill the radiator, you just have to take some coolant out (turkey baster). I use it, though without a temp guage, and on my stock car, I couldnt tell you if it works, as a few degrees difference wont be noticable. I got it for piece of mind on the track.
Chris.
subyguy2 is offline   Reply With Quote
how much redline water wetter do you add? M32WRXin3seconds Newbies & FAQs 11 02-02-2004 06:07 PM
mixing Redline Water Wetter wrx2sti Service & Maintenance 11 11-02-2003 08:31 AM
Redline Water Wetter Snitt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-02-2003 11:56 AM
How many guys running Redlines Water Wetter? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-28-2002 09:23 PM
RedLine Water Wetter?? donjuan Technical Forum Archive 15 09-29-2000 05:20 PM
