#1 |
Member#: 19214
Vehicle:'07 STI in the slow lane |
What ratio? How much power you running? How would you rate them for the 1/4 mile or auto-x? What's the max speed in each gear? What rpm for 75 mph in 5th? Durability?
I have an 02 WRX with an SR30 and fmic (plus STi injectors and a Walbro). A daily driver, it's shooting for 12's in the 1/4 but will see much more time in local auto-x. Thanks,
#2 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
I was in contact with one of the Aussie guys on this board regarding the gearset and he was very pleased with it. I was looking into getting it a few months ago but decided to go with a 6-speed instead. Mike Shields at SPD Tuning is using the Kaaz gearset as well. Here are the ratios:
1st: 3.167 2nd: 2.267 3rd: 1.667 4th: 1.250 5th: 0.964 As you can see, it's really short 2-5. Basically drive your car around as if 4th gear was the last gear and that's how it will be. First is a little longer than 1st in the WRX. Phil |
#3 |
Member#: 15194
Vehicle:2004 Lightning, 2001 BMW 330ci |
If you are pumping out 293whp @16psi (very impressive I might add), you are well into the 12's.
| Thread Tools | |
| Display Modes | |
| Anyone ever use/see one of these used? | Damn Yankee | Off-Topic | 5 | 05-26-2010 02:59 PM |
| STi 6spd? STi RA gears? KAAZ gears? What should I use with a GT30R/ej207? | vipernj | Transmission (AT/MT) & Driveline | 7 | 01-10-2006 01:17 AM |
| is anyone here using these gears | Aspenwhite02 | Transmission (AT/MT) & Driveline | 2 | 03-16-2003 12:37 AM |
| Anyone using the KAAZ gearset? | Imprezer | Transmission (AT/MT) & Driveline | 8 | 11-15-2002 09:26 AM |
| Anyone use adjustable cam gears? | Gerry | Normally Aspirated Powertrain | 7 | 10-25-2000 03:07 PM |
