Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 03-23-2003, 10:53 PM   #1
bluespeed
Member#: 27744
2002 impreza wrx
blue
Default problem with utec remote map switch
ok I have two maps on my utec. one a peak power map and another tunned down a little bit. I installed my remote map switch this week and since the power has seemed to go down a good bit. I made sure that the rotary switch was at map 0 and I hooked my laptop up and in the dashboard mode I looked to see if when I switched maps with the remote switch it was working, and it was fine. every time I hit the switch the it would read the same on the laptop. also some times when I would change maps and start the car up the cel would not flash at all.I unpluged the remote switch today and flipped the rotary back to map 1 and I definatly had more power. the only thing that I can think of is the remote switch is falty and my car was actualy staying in stock mode as a result of the rotary switch being set at 0. if anyone has any other thoughts please let me know
also I tried using the remote switch to flip between the vallet mode and my other maps to see if there was a difference and the car rode the same
bluespeed is offline   Reply With Quote
Old 03-23-2003, 11:57 PM   #2
WRX Jim
Member#: 22321
the car has to be off to switch maps dont u?
WRX Jim is offline   Reply With Quote
Old 03-24-2003, 07:57 AM   #3
Rich10
Member#: 14934
Default Re: problem with utec remote map switch
I could easily tell the difference between the valet map and the other maps. Another thing that you could try is the security map (IIRC, position 7). If the car starts, you definately have a switch problem.
WRX Jim, the utec will switch maps provided that rpm's are below 1600.
Rich10 is offline   Reply With Quote
Old 03-24-2003, 03:41 PM   #4
SysRq
Member#: 31347
() support your
/\ sysadmins
...and once switched to map 7, security mode will become active only after UTEC loses power and reboots. It may take up to a couple of minutes after you turn the ignition off.
The fact that the UTEC dashboard reports correct switch position is a good indication that the switch is OK.
SysRq is offline   Reply With Quote
Old 03-24-2003, 04:02 PM   #5
nmyeti
Member#: 4980
Do you have the newest version of the switch with flying lead for the clutch switch?
If so make sure that those connections do not touch! This will cause your switch to malfunction when running the 2.5B software.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
TurboXS Universal UTEC Remote Map Switch UTEC-SWITCH monSTIer Engine/Power/Exhaust 9 09-01-2008 12:39 PM
FS: UTEC Remote map switch 03WRXMA Private 'For Sale' Classifieds 6 07-16-2004 06:51 PM
IL: Utec Remote Map switch...55 shipped Shaitiger Private 'For Sale' Classifieds 1 03-10-2004 10:08 AM
03 ECU, UTEC Remote Map Switch, AEM Pulley Kit biker360 Private 'For Sale' Classifieds 10 02-24-2004 10:23 AM
03 ECU,UTEC Remote Map Switch, AEM Pulley kit biker360 Private 'For Sale' Classifieds 14 02-14-2004 10:38 AM
