Old 03-24-2003, 05:22 AM   #1
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Default there's a hole in my engine block
Driving on an up hill canyon run. After the last turn I shifted into forth. Heard a clank clank, noticed power loss, more noise. Got up to the peak and my friends didn't even know who i was... Then it died. Openned the hood and check oil. A tad low. Let the car cool for a while. Added oil. Tryed to start. sounded like a blown barring in the crank. So we realize that I needed to AAA. No one has any cell phone reception. Others reached the peak. No good. Checked the oil again it was over. I had only added 2 quarts. Started the car. Wasn't nice. I kept the car in idle and was pushed down the canyons. That was interesting. Got out. Called AAA. Towed the car home. Get home, started the car to get it into the garage. Got out. Noticed a trail of oil. Popped the hood. Saw oil all over the place found a hole on the top of the in the middle above the crank. oh well... lesson learned... Change your oil after coming back from a 2.5 month vacation. So much for putting a turbo on a phase I 2.5. I guess it's JDM 2.0 time. hehehe
i had 113,478 miles on it
i got my 2.5RS on 5/11/99
MY99 had 4 miles on it when she became mine
I knew i should've changed the oil.
i think i need an oil cooler, that would help from that from happening again...
is the before 95 water cooled style intercoolers good?
is it hard to add a different switch to the water pump resevior so i can make a home made water intercooler spray kit.
should i cut after the plug?
i wonder if a v VIII would fit?
i should check out the auctions
mark
gokou006 is offline   Reply With Quote
Old 03-24-2003, 11:42 AM   #2
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
I thought phase I was DOHC? Isn't your car SOHC or phase II?
Sorry about your engine.
Fred Zaplitny is offline   Reply With Quote
Old 03-24-2003, 07:29 PM   #3
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
i have a phase I SOHC
Old 03-24-2003, 07:31 PM   #4
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
i have an early 99, phase II's didn't appear till later that year
Old 03-24-2003, 07:57 PM   #5
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Phase I is DOHC.
Phase II is SOHC.
BTW...use the "edit" button instead of adding 30 posts of youre own.
DDMan is offline   Reply With Quote
Old 03-24-2003, 08:07 PM   #6
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
how can you check to see what phase you have ?.. cuz i have a 99 and also which one is better
PumpsGOTAWD is offline   Reply With Quote
Old 03-24-2003, 10:01 PM   #7
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Phase I is a MAF sensor type, to check. Look by the air filter. If there is a sensor with wirers in the middle of the intake.
If there are no wirers and sensors on your intake near the air filter. Then you have a phase II MAP sensor type
Old 03-24-2003, 10:04 PM   #8
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Originally posted by DDMan
Phase I is DOHC.
Phase II is SOHC.
please let me catch up... look at my member number...
Old 03-24-2003, 10:04 PM   #9
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Phase I is DOHC.
Phase II is SOHC.
Old 03-24-2003, 10:06 PM   #10
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Phase I is DOHC.
Phase II is SOHC.
my car was a MAF and it was a SOHC
Old 03-24-2003, 10:11 PM   #11
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
in a MAF setup the Fuel Ingectors automatically open and open furter according to how much air is coming through the intake.
in a MAP set up Fuel Ingectors are opened in stages when air reaches required amounts of air, like points on a graph.
Old 03-24-2003, 10:12 PM   #12
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Old 03-25-2003, 10:31 AM   #13
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Phase I is DOHC.
Phase II is SOHC.
Yep. All MY99's were phase II. That was my point.
And I second the "edit" suggestion.
Old 03-25-2003, 10:34 AM   #14
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Nope. MY99 was a phase II with MAF. Phase # had nothing to do with whether or not you had a MAF or MAP. No MY99 came with a MAP sysytem.
MY98 was DOHC Phase I
MY99+ was SOHC Phase II
Old 03-25-2003, 07:59 PM   #15
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Actually Fred It all depends on your build date,Early 99's were phase 1.
Old 03-26-2003, 10:17 AM   #16
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
I do not believe that. How could they advertise a SOHC engine in their brochure and give you a crappy old DOHC Phase I? I've heard what you said many times, but STILL have yet to see one. Do me a favor, if you get one in at Hodges, call me and I want to come see it.
Old 03-26-2003, 10:28 AM   #17
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
you got the SOHC heads, but they were bolted to a Phase I block in early 99.
Eric SS is offline   Reply With Quote
Old 03-26-2003, 01:37 PM   #18
Charge
Member#: 3313
Yep, as stated before, 99's had SOHC with Phase 1 bottoms early and Phase II bottoms later.
98 RS = Phase I block with DOHC (with MAS?)
early 99RS = Phase I block with SOHC (MAF)
late 99RS= Phase II block with SOHC (MAF)
00-current= Phase II block with SOHC (MAP)
I might be wrong on the sensors, just a guess.
Charge is offline   Reply With Quote
Old 03-26-2003, 02:20 PM   #19
Watsonpa
Member#: 31099
1998 Impreza 2.5RS
Blooooooo
98 RS = MAF
I just changed mine two weeks ago, so I'm sure of it.
The way it was explained to me by the dealership is that they changed the MAF portion of the Phase I engine on models made after June 1998. Those of us who have the early models have to buy a $330-$350 MAF sensor assembly while the later models can just buy the sensor itself for ~$120.
I don't know if the late model 98's MAF assembly is the same as the 99's but it could be.
Watsonpa is offline   Reply With Quote
Hole in my engine subikid Normally Aspirated Powertrain 19 09-04-2008 01:54 PM
There's A Hole In My Carpet bluboy103 Interior & Exterior Modification 5 03-06-2005 09:11 AM
WTB: Belt covers for block. Last friday, my belts cut a hole in my coolant line.... psyber_0ptix Mid Atlantic Impreza Club -- MAIC 5 12-20-2004 05:46 PM
hole in my engine block gokou006 Southern California Impreza Club Forum -- SCIC 3 03-25-2003 12:51 AM
('93-'01) There's a hole in my car's rug, next to the clutch pedel Deznuts05 Impreza Forum 2 07-06-2001 02:05 PM
