Old 03-24-2003, 11:19 AM   #1
jeffg
Member#: 2958
2001 WRX (GC8)
Default Fuel Pressure and running rich
I was wondering if lowering the fuel pressure would help our cars from running to rich. Is there a minimum fuel pressure we should not go under?
I assume that you would need an adjustable fuel pressure regulator, but would a restrictor in the vacumn line that goes to the FPR work? Kind of like the used on WRXs to control boost?
I imagine if you lowered the vacumn the FPR sees there is a possibility that you could end up lean at high throttle precentage, but it seems like we have a lot of room to work with.
J
jeffg is offline   Reply With Quote
Old 03-24-2003, 12:37 PM   #2
nySulli
Member#: 32617
2008 STi
i wouldn't screw around with the fuel pressure, if you want to run leaner then i'd just go with some engine managment and adjust the fuel map
nySulli is offline   Reply With Quote
Old 03-24-2003, 01:31 PM   #3
jeffg
Member#: 2958
2001 WRX (GC8)
While I value you comments, the possibility of a near free way to slightly lean the air/fuel ratio is worth investigating.
To play around, I moved the vacumn source for my stock FPR to the vacumn port on the top of the intake manifold, rather than the one on the #3 runner. The fuel pressure dropped about 2 psi under cruising (low throttle precentage), but jumped right back to normal at idle (closed throttle) and heavy acceleration (high throttle precentage).
My EGTS went up ~75-100 depending on throttle application. Right now I am running at ~1400 @75 on the freeway with the cruise set, and about 1300 running around town. My EGT is in the #3 header primary.
J
Old 03-24-2003, 01:50 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Which line did you tap into on top of the manifold? Was there some other line attached at that point?
Your findings do make sense.....there's going to be more vacuum in the center of the manifold then in one particular intake runner.
But I would keep an eye on things.....
Legacy777 is offline   Reply With Quote
Old 03-24-2003, 03:27 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
The line I tapped into origionally went to the evap emissions valve. My valve is broken so there was no line on this port. I had it blocked with a plug.
I will keep an eye on the car and see how it turns out.
J
Old 03-24-2003, 08:51 PM   #6
Legacy777
Member#: 4800
J
There is a problem with doing this.......the canister purge valve tube only sees vacuum when the throttle is open.
So at idle the fpr isn't seeing any vacuum.
Unless of course you've modified things a little, or they have changed where the canister purge valve hooks up.
Old 03-25-2003, 08:51 AM   #7
Hawk296
Member#: 14555
1995 Impreza L
Baja
I was considering tweaking the Fuel pressure regulator myself after my 2.5l swap cause with the 1.8l ECU it runs really rich. Im looking for a totally cheap way to fix that problem. ide like to learn more of this.
Hawk296 is offline   Reply With Quote
Old 03-25-2003, 01:20 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
Can you explain to me how this is different from where the vacumn line was origionally connected?
I can imagine that there is some vacumn in the runner going to the cylinder because of the smaller immediate volumn, but really the intake runner and the intake phenum (spelling?) are the same air space, so vacumn should be the same at both parts. Obviously this is incorrect because I see a difference in fuel pressure.
Further problems could exist if you left the purge vavle connected to this same vacumn line. Since my purge valve is broken I had no vacumn hose on this port, just a cap.
anyway, I am going to keep it this way and watch for problems. So far it seems to be working just fine. I have an autocross this Sunday and I will keep an eye on things to see how it handles aggressive driving.
J
Old 03-25-2003, 01:45 PM   #9
Legacy777
Member#: 4800
J
Well.....not knowing 100% thatyour TB/intake is setup the same way as mine.....I'm going to explain why it wouldn't be good to do what you did on my car.
If you can get a hold of some pictures of your engine and exactly where the vacuum tube is located, I should be able to tell you whether it's the same setup or different as mine.
On my car the vacuum line on the TB that the CPV hooks into is right on the edge of where the throttle plate sits.
When the throttle is closed the vacuum hole/source is behind the throttle plate and there is no vacuum. When you open the throttle vacuum is created at that source.
The way the CPV works is that the charcoal canister absorbs excess fuel vapors. When engine rpm is above a certain point for more then a specified time....the ECU sends a signal to the CPV which opens up, and allows the vacuum from the intake manifold to suck up those fuel vapors in the charcoal canister to be burned in the engine.
That is how things work on my car. There is a chance they have changed how/when this operation occurs and they may just give it a constant vacuum.
Have you hooked a vacuum gauge up to both locations and read vacuum and see how it changes with a change in throttle?
I would suggest doing this, that way you have an actual number/gauge needle and you can compare the two vacuum sources. Do this, see what you get, and if they are different, post what the differences are, and we can try and discuss the reasons why.
Josh
Old 03-25-2003, 01:55 PM   #10
jeffg
Member#: 2958
2001 WRX (GC8)
Josh,
I have found the problem. the purge valve vacumn port on the EJ25 is well behind the TB. It is tapped into the actual intake manifold, rather than the TB housing. I can see on your car where the vacumn port is on the wrong side of the TB, where you would be in trouble.
I guess what it comes down to is that fact that all I did is move the vacumn hose from a single runner of the intake manifold to a port on the phelum.
My idle fuel pressure is exactly the same. The only thing that is really changed is the low throttle precentage fuel pressure, which dropped by about 2 psi.
J
Old 03-25-2003, 06:30 PM   #11
Legacy777
Member#: 4800
hmmmm......anyway you could get some vacuum readings off the two ports?
What sort of mods do you have on the car? Do you have an intake of some sorts?
Old 03-26-2003, 11:37 AM   #12
jeffg
Member#: 2958
2001 WRX (GC8)
I do not have an actually vacumn guage but I can try and borrow one.
I do have a cobb CAI, but I dont think that would really effect this. I think if I can find a good engine bay picture it will make sense.
J
Old 03-26-2003, 02:16 PM   #13
Legacy777
Member#: 4800
Let me know if you can borrow a gauge or not.
Here's my hypothesis......with an intake you create a freer flowing intake system. At idle, throttle plate is closed....so that won't matter much what you have, so vacuum should remain the same no matter where you tie into the manifold.
At light throttle with the intake on, you have more air flow....especially in the main chamber where you've hooked the fpr line up to. This could produce more vacuum then at this particular point, compared to at the no. 3 intake runner.
I guess if you wanted to test this theory, you'd have to put the stock air box & crap back on......unless someone with a stock intake system and same MY car can take vacuum readings at the same two points.
Josh
For Sale: DEFI BF AMBER IMPERIAL fuel pressure and oil pressure syoung0298 Interior/Dressup/Audio & Security 5 06-09-2008 01:12 PM
97 Sti Afterfiring and running rich - Please help bradsti Newbies & FAQs 9 04-16-2008 07:30 PM
BOV means MAF messing up and running rich? Eijin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-08-2007 02:33 AM
relieve fuel pressure without running engine? gatts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-30-2007 05:08 PM
First results: High fuel pressure, and... scootr Normally Aspirated with bolt-on Forced Induction Powertrain 12 11-24-2001 02:18 PM
