Old 03-24-2003, 10:58 PM   #1
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Default is it ok to have a 3" up and down pipe? and go 3 all the way back?
is it ok?
gokou006 is offline   Reply With Quote
Old 03-24-2003, 11:00 PM   #2
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
I wouldn't think that a 3" up-pipe would be good as its going to be a lot larger than the manifold outlet and the turbo inlet which won't be good for flow. 3" all the way on the post turbo side is good though.
driggity is offline   Reply With Quote
Old 03-25-2003, 09:00 AM   #3
Shark
Member#: 21487
Thumbs down 3" Upipe Bad
A 3" uppipe is not good. The manifold outlet diameter is about 2". So you are basically "dumping" the exhaust into a larger volume pipe which would cause too much turbulence as it gets to the turbo. You want the upipe to match the manifold outlet and turbo inlet as close as possible. Some uppipes are 2-1/4" diameter or less at the manifold and go down to 2" at the turbo which acts as a velocity chamber causing the exhaust gases to compress letting the turbo spool faster etc. I am not a physics expert and I am sure someone else out there can explain in more detail but you getthe jist of it.
so you basically need to stay away from 3" uppipes if there are any outl there.
-Shark
Shark is offline   Reply With Quote
Is it ok to have the spt intake and spt exaust on with cobb accessport stage 1 Cobb2006WRXJR AccessPort 3 11-18-2009 08:19 PM
Is it bad to drive with DCCD in manual all the way back daily? elitescouter Newbies & FAQs 6 03-27-2008 04:44 PM
is it okay to have newer tires up front, and half warn tires in the back? Kevex Tire & Wheel 3 10-04-2003 11:09 AM
Is it ok to have one last fling before marriage? Thug Off-Topic 44 11-25-2002 08:28 PM
