Old 03-25-2003, 12:14 AM   #1
sub25rs
Member#: 4319
2000 2.5 RS
BRB
Default Weird Squeak and power loss
Driving along w/ the radio off the other day and Ive discovered my car has a squeak that happens at like 2000-2700 rpm- it sounds like its coming maybe from the engine or transmission- i really cant tell but when the squeak happens the RPMs sometimes drops and there seems to be a moment of hestitation. Anyone have an idea what the heck is going on?
sub25rs is offline   Reply With Quote
Old 03-25-2003, 03:43 PM   #2
Silver2000RS
Member#: 857
Does the problem only occur when you have the A/C on?
If yes, ...
Check your A/C belt. The squeek could be a loose or worn belt. You feel a 'power loss' and see a drop in RPM because of the load created by A/C compressor switching on.
Silver2000RS is offline   Reply With Quote
Old 03-25-2003, 11:59 PM   #3
sub25rs
Member#: 4319
2000 2.5 RS
BRB
nope- just occurs when im driving... i dont know what it is.. im gonna go get it checked out when i get back into town.. i was just wondering if anyone has had this problem
Old 03-26-2003, 08:28 AM   #4
live311
Member#: 10801
2008 Outback
An accessory belt could be slipping. Try to twist each of the belts. If you can twist it more than 90 degrees, it may be a little loose. If you can twist it 180 degrees or more, it's definitely too loose. Have it adjusted.
live311 is offline   Reply With Quote
intermittent weird noise w/ power loss stil2stock Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-07-2009 04:31 PM
Weird noise and LOTS of power loss HondaDestroyer Newbies & FAQs 6 04-18-2006 04:08 AM
weird on acceleration power loss? disillusioned Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-23-2005 01:33 PM
CEL and power loss SlackMeister Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-21-2005 03:21 PM
balancing the clutch and throttle for minimal power loss time between 1st and 2nd asbWRX04 Newbies & FAQs 30 05-20-2004 12:44 AM
