Old 03-25-2003, 10:50 AM   #1
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
Default Fresh new twist on the DIY headlight mod
Drew888 is offline   Reply With Quote
Old 03-25-2003, 10:51 AM   #2
mdot
Member#: 15884
2002 wrx wagon
i like it.
mdot is offline   Reply With Quote
Old 03-25-2003, 11:15 AM   #3
Stripe
Member#: 9820
02 WRX
Nice, built in eyelids
Stripe is offline   Reply With Quote
Old 03-25-2003, 11:57 AM   #4
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
WOW...that looks good man..I like that...a lot!
Matt
2pt5RS is offline   Reply With Quote
Old 03-25-2003, 12:00 PM   #5
Bigpants
Member#: 12807
I think it looks cool, any pics from a little distance?
D
Bigpants is offline   Reply With Quote
Old 03-25-2003, 12:32 PM   #6
Drew888
Member#: 6459
Ther is only one a little farther away, but I'll take some after I wash it today.
Here is another couple of pics (if you haven't already seen them all on my pic hosting site yet).
http://albums.photo.epson.com/j/View...p=63038314&f=0
http://albums.photo.epson.com/j/View...p=63036805&f=0
http://albums.photo.epson.com/j/View...p=63036806&f=0
Old 03-25-2003, 01:15 PM   #7
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
How bright is the turn signal though? If you reduce the distance at witch you see the signal then it could be a problem.
DetroitWRX is offline   Reply With Quote
Old 03-25-2003, 01:31 PM   #8
sonicblue
Member#: 25227
2012 Escape
So basically it's a "Koji" mod without painting the parking light area? Looks like a quality job and I applaud the innovation.
sonicblue is offline   Reply With Quote
Old 03-25-2003, 02:02 PM   #9
Wrxified
Member#: 16222
2005 STi
Platinum Silver Metallic
Do you guys use hi-temp paint to do the headlight mod?
Wrxified is offline   Reply With Quote
Old 03-25-2003, 02:30 PM   #10
Drew888
Member#: 6459
The turn signal is very bright. Seems brighter than before, probably because the light is more focused. I painted the interior of the PVC with chrome paint first. I reused the orange turn signal cover. I simply cut it 1/16" larger in diameter than the PVC and pressed it in. A very tight fit.
The orange cover has two square areas that reflect the light sideways. I carefully aligned it so that it still does this.
To eliminate people not seeing me from the side completely I complemented the light mod by wiring up the side markers to blink with the turn signals. I covered all bases and it works great!
It's Koji style without painting the parking light part of the headlight and inserting of the old turn signal orange reflector.
High temp paint ...yes. I used whatever high temp engine paint the parts store had. I bought both gloss and flat and after a little testing the flat works much better.
Drew,
Old 03-25-2003, 02:44 PM   #11
Javabean2
Member#: 9752
2002 WRX Wagon
Kudos, this looks fantastic! I do want to see what it would look like on a non-black car though, since the contrast between the colors would be greater.
Javabean2 is offline   Reply With Quote
Old 03-25-2003, 02:50 PM   #12
Amazake
Member#: 9889
looks good especially in the night shots
Amazake is offline   Reply With Quote
Old 03-25-2003, 03:05 PM   #13
Drew888
Member#: 6459
Thanks guys!
People have commented on the fact that this mod only takes about 3 hours. Oh NO...to do what I did and take your time (ok the first time doing anything takes longer) it takes about 7hrs.
One more Pic;
http://albums.photo.epson.com/j/View...p=63036209&f=0
Old 03-25-2003, 07:32 PM   #14
fuzzycuffs
Member#: 32309
2003 Silver WRX
Who needs a car in Tokyo?
Question, sorta unrelated:
Where'd you get the corner markers? The ones I got from procarparts fit decently enough, but the part of the marker above the actual bulb is clear and not, how would you say, textured to add reflectiveness. I like the way your's look more.
fuzzycuffs is offline   Reply With Quote
Old 03-25-2003, 08:35 PM   #15
clsmooth71
Member#: 15552
'87 Hutch TRICKSTAR
babyblue on pinkTuff II's
Arrow Nice, But...
Very clean & creative work on the turnsignal portion, but IMO, painting the chrome bezel portion w/the parking light looks better.
Peace
CL
clsmooth71 is offline   Reply With Quote
Old 03-25-2003, 09:22 PM   #16
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Lookin' good!
Mike~~
N'CTRL is offline   Reply With Quote
Old 03-25-2003, 10:56 PM   #18
Drew888
Member#: 6459
Jeff,
We are Suby owners...no worries. I'll walk you through it whenever you are ready. It is really easy to do.
After doing it I would make some minor changes in the order things got painted and epoxied (sp?).
Aside from that it is only time consuming.
Drew
Old 03-25-2003, 11:50 PM   #19
Yungimoto
Member#: 14940
Looks nice!
Yungimoto is offline   Reply With Quote
Old 03-25-2003, 11:54 PM   #20
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Originally posted by Yungimoto
Looks nice!
agreed
moogoob is offline   Reply With Quote
Old 03-26-2003, 03:14 PM   #21
WRXmy02
Member#: 14938
02 Wrx
Bright idea !
WRXmy02 is offline   Reply With Quote
Old 03-26-2003, 03:51 PM   #22
DragII
Member#: 16354
2000 VW Golf
pretty cool, very differant.
DragII is offline   Reply With Quote
Old 03-26-2003, 03:54 PM   #23
Sandkicker
Member#: 6954
05 FXT
Pre: 02WRX, 98RS, 99RS
That looks awesome, I was thinking about doing the same thing (paint-wise), but not with the PVC.
Do you guys think leaving the stock orange bubble would leave the blinker bright enough from the side if painting the entire area behind it black? For instance, Drew88's got it figured out because he's got the sidemarkers wired up which is probably a good idea since the PVC won't allow for much of a side-view of the blinkers... but if instead of the PVC you just left the orange bubble, but painted everything as he did, would the blinker be very bright at all from the side?
this is main thing keeping me from doing this. I've got the STi sidemarkers so i don't have the sidemarkers to wire up. I'd love to do the "eyelid" type look, but without eyelids and without sacrificing visibility of the blinker from the sides.
anybody done this?
Sandkicker is offline   Reply With Quote
Old 03-26-2003, 05:28 PM   #24
jcme262
Member#: 13694
nice, very original
jcme262 is offline   Reply With Quote
Old 03-26-2003, 08:19 PM   #25
sonicblue
Member#: 25227
2012 Escape
Sandkicker-
Can't say I can recall someone doing this mod and leaving the orange bulb cover. It's hard for me to envision how it would look color-wise on other cars to make a blanket statement, but I think it would look good on your black car (going to do the headlight in black, right?). As far as visibility, from what Drew said about the little triangular sections in the cover, sounds like leaving that piece on could only help visibility versus leaving it off. I say go for it - place them on your car after doing the paint job but before reassembling. If you don't like it, leave it off (and go orange bulb or that one that looks silver but illuminates orange) or add the PVC and make it a Koji-style mod and screw the visibility issue. I think it's kinda unlikely any po-po would give you isht for that anyway........
BTW, personally, I'm Koji-mod and sidemarkers wired up:
Does the DIY headlight mod for the 02 wrx affect lighting at all? waitandbleed92 Interior & Exterior Modification 2 12-16-2003 08:55 PM
Can anyone give me a link to the diy headlight mod for 04??? FryRice Electrical & Lighting 2 07-16-2003 06:43 PM
How difficult is the DIY headlight mod? waitandbleed92 Electrical & Lighting 9 06-16-2003 11:31 PM
Downsides to the DIY headlight mod? Butt Dyno Newbies & FAQs 9 03-25-2003 03:22 PM
A new twist on the 3/16" connector! VetteVert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 47 07-28-2002 09:51 PM
