Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 08-11-2005, 08:49 PM   #276
Godfather Inc 03
Member#: 84050
i am thinking about getting sse professor sp-1 wheels but they only come in 8.0 with 49 offset or 8.5 with a 47 off set...what do you think?
Godfather Inc 03 is offline   Reply With Quote
Old 08-23-2005, 03:47 AM   #277
subeesteve25
Guest
Member#:
2005 wrx wagon. 18 x 7.5 et45 with yoko avs es 100, 225-40-18??????????????????????????????????????stock height, not planning on lowering
Old 08-23-2005, 08:43 PM   #278
Z1 Performance
Member#: 9327
Either will fit a WRX sedan - the latter size gives you tons of clearance for big brakes down the road
Z1 Performance is offline   Reply With Quote
Old 08-25-2005, 10:40 PM   #279
misterbee123
Member#: 55863
05 White WRX Sedan
TeamBLEW Racing
I've been reading on 17x8.5 wheels and correct me if I'm wrong but the ideal offset is 48mm. What are the advantage or disadvantage of having a 52mm offset?
misterbee123 is offline   Reply With Quote
Old 08-26-2005, 01:20 AM   #280
Z1 Performance
Member#: 9327
there really is no such thing as ideal - there are offsets for a given wheel that work or don't work. Some wheels, due to the nature of their spoke design, pad height, etc necessitate a lower offset, and others, due to their spoke design, pad height, etc can get away with lower offsets.
It has been said that the lower offset wheels can potentially cause wheel bearing failure. My own personal view is that it does not - and this is purely anecdotal based on me having had friend/customers with pure stock wheels on RS's and WRX's (without suspension mods either) have to do wheel bearings.
Old 08-31-2005, 02:12 PM   #281
GDA
Member#: 4324
02 GDA
Platinum
Question
I assume having a 17x8 35mm offset for STI is just gonna kill it down the road?
thanks,
GDA
GDA is offline   Reply With Quote
Old 08-31-2005, 08:14 PM   #282
Z1 Performance
Member#: 9327
kill it? I would doubt it to be honest. The wheel bearing issue does not only strike those with aftermarket wheels - I have plenty of customer with relatively low mileage cars and stock wheels that had to replace them too...it's a wear item
now, handling wise, it will be very darty due to the offset
Old 09-11-2005, 10:33 PM   #283
Juztjin
Member#: 93254
1999 Impreza 2.5 rs
Default 05 subaru legacy rim questions
I have a 99 2.5rs coupe and i have the 05 subaru legacy rims. They are 16 X 6.5-inch 5-spoke rims, and on them are 205/55/16 falkin ziex.This is the ? why are they cambered? Do i need a camber kit? Whats the deal?
if anyone can help me it would be much appreciated
Juztjin is offline   Reply With Quote
Old 09-30-2005, 07:49 AM   #284
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
I wanna fit 17x8's on my car with 245/45R17's What offset would i need to makes this not rub?
012.5RS is offline   Reply With Quote
Old 09-30-2005, 09:19 AM   #285
Z1 Performance
Member#: 9327
you are not going to get those on a GC8 without fender mods
Old 09-30-2005, 07:22 PM   #286
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
what do you mean by fender mods, what all would i have to do? flare them out?
Old 10-03-2005, 11:42 AM   #287
Z1 Performance
Member#: 9327
at the very least yes
Old 10-04-2005, 02:48 AM   #288
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Whoof!!! What an informative read... I've just spent the last 5 hours reading MOST of the offset threads and I think I'm beginning to understand what the offset issue is all about. So this is what I think I know, please tell me if you think I'm understanding this because someone wants to sell me a set of wheels with a +38 offset (on 17X7 wheels that I will mount 225/45/17 tires on) and I'm thinking that would be a bad thing...
Offset is primarily about three variables, bearing loading, fenderwell clearence and suspension geometry. It's a trade-off between the three. I looked at the design of my front wheel bearings and they're a couple inches inside (offset) from the mounting plane of the wheel. So a +53 offset will put the center of the wheel/tire pretty close to the center of the bearings. With that established can I assume that this position will put the wheel/tire in the middle of the space between the springs and the outside fender well (I guess I can measure that)? If that's true then the width of the wheel/tire will determine any clearance issues. If the standard offset doesn't put the wheel/tire in the middle of the space, then you would have to adjust the offset to center it, is that correct? Can I also assume that having the wheel/tire centered over the bearing is the best position for the suspension geometry to function correctly? If that's true then you don't want to move that offset too far for that reason as well...
So I'm thinking it would follow that a +38 offset would put too much load on the outer bearing by moving the centerline of the wheel/tire too far out regardless of whether the tire would rub on the fender, and it might upset the suspension geometry too. Do I understand this correctly? I just want to be able to explain to this person why I think I need an offset closer to 50. Unless of course I'm AFU...
STirocket is offline   Reply With Quote
Old 10-04-2005, 12:05 PM   #289
Z1 Performance
Member#: 9327
STirocket - you got it, but keep in mind it is all relative to wheel width as well
Old 10-04-2005, 12:48 PM   #290
STirocket
Member#: 84006
WRB with Goldies
If my understanding is correct the only thing wheel width will affect is whether or not the wheel/tire will fit in the wheel well without rubbing. If a +53 offset puts my 8" BBS wheel in the centerline of the wheel bearings, then a +53 offset 4" wide wheel (with a corrispondingly smaller tire) will also put it in the centerline of the bearing. The wheel/tire might not be centered in the wheel well anymore, but as far as bearing loading goes it would still be in the centerline of the wheel bearings.
I can see that people might WANT to put real wide wheels on a car that wasn't designed for them, and you would have to change the offset to make the wheel/tire fit in the wheelwell. But it is my thinking that the offset is dependant only on suspension geometry and bearing loading/wear.
Am I missing something?
Old 10-04-2005, 05:56 PM   #291
pprocter
Member#: 74239
2005 STi
Question Simple question, multiple answers
Does anyone know for certain what the offset of the stock BBS wheels on the 2005 US STi is?
pprocter is offline   Reply With Quote
Old 10-04-2005, 06:24 PM   #292
STirocket
Member#: 84006
WRB with Goldies
Did you read the last few posts? ET53... The number (53) is cast into the wheel by the hub/bolt ring
Old 11-27-2005, 06:05 PM   #293
wheets
Member#: 99976
'06 STI
Steel Gray
Does this mean spending one winter on 17x8's +35 with 225/45's isn't going to be the end of the world for me?
wheets is offline   Reply With Quote
Old 11-29-2005, 02:41 AM   #294
eshaun
Member#: 51839
so did u you end up running 18x8s or the 17s? I'm looking at a picking up a set of 18x8s 51mm offset and have not found anyone with this combo who can attest to them clearing the brembos and other wheel well harzards.
Originally Posted by BOFslime
can you cite your sources?
I've had this question burning since i bought my car.. and i'm 2 day's away from ordering my wheels.
OZ Racing Superleggera are 17" x 7" with a +48 offset (part number SL770C48)
I haven't spoken with Tirerack.com yet to find out if infact this is the same offset that they provide for MY02/03 WRX Sedan. When I order I will have to see what they say.
edit/update:
Direct from www.ozracing.com under fitment guide; selecting subaru | 2002 | WRX:
eshaun is offline   Reply With Quote
Old 11-30-2005, 04:02 AM   #295
silentbob343
Member#: 57307
lol after going through this thread there is still no clear answer:
The 04 STi stock wheels, 7.5 ET53, don't follow the guidelines in the first post and the newer 05 STi wheels, 8 ET53, are even further away from the guide lines.
ah well
If you look at the STi wheels on the Gruppe-s site you see most are 53mm and a couple 50mm offsets:
http://www.gruppe-s.com/Sti/sti_sub.htm
silentbob343 is offline   Reply With Quote
Old 12-02-2005, 02:32 PM   #296
Silverex04
Member#: 97141
2004 WRX
Motegi MR4's PART #=2147-8817 SIZE=18x8 OFFSET=+42 BACKSIDE=6 BOLT PATTERN=5x100 & 5x4.5 WEIGHT=28.5 lbs with Wanli S 1088 225/40/ZR18 tires, will these fit on a 2004 WRX with a stock suspension? I read this whole thread and I am still confused. I understand that Subaru designed the car to work with the stock rim, and I understand that if you change the rim size you need to change the offset to counter the damage to the vehicle. I think I read that with a 18X8 the offset needs to be 43 to 47. so will this wheel damage my car seeing how the rim is a 42?
Silverex04 is offline   Reply With Quote
Old 12-02-2005, 03:01 PM   #297
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....this is wrong. "Ideally", you don't want to deviate from the stock offset regardless of wheel width. Obviously, with width comes clearance issues and sticking with oem offset may not be possible at some point. .......hence the suggested offsets at the beginning of this thread. Other factors can include wheel availability, lowering, aftermarket calipers, etc.
The wheel you're inquiring about is a 42 offset. I have a 40 offset and I can tell you that there's plenty of clearance "inboard" and very little "outboard" (toward the fender). Personally, I would suggest sticking with as high an offset as clearance will allow. ......that may be around 48 or so. I'm sure there are several members running 18x8's that you can check with or perhaps contact a vendor who is in tune with Subaru offsets/fitment so you know what will work best. You will also want to consider any future modifications you may be thinking about so you are sure the set-up you choose now will still work as you make changes down the road.
Kean is offline   Reply With Quote
Old 12-17-2005, 01:29 PM   #298
moforose3.0
Member#: 38443
2002 WRX, 300zx TT
blue
I am looking at some OZ superleggas from the tirerack. They have 18X8 +51, and 18X8 +48. The +51 offset is $100 cheaper. Will these work, they are more than a couple of mm outside of your +43-+47 offset specs. Thanks
moforose3.0 is offline   Reply With Quote
Old 12-17-2005, 02:14 PM   #299
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I'd be more worried about the 'damage' a big heavy wheel would do to our terrible power curve cars.
waktasz is offline   Reply With Quote
Old 12-17-2005, 03:15 PM   #300
redeemedsoul
Member#: 75067
2005 WRX
Will 16x6.5 black steel wheels at 41 offset fit my05 WRX ? Thanks!
redeemedsoul is offline   Reply With Quote
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 07:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 05:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 09:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 09:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 03:59 PM
