Old 06-01-2006, 09:08 PM   #376
dnaL0R
Member#: 109472
2006 shirokuro_STI
Default too bad~~~
i really want these for my sti but according to the offset guide, it is not going to clear the brembos...
17"x8" +42
dnaL0R is offline   Reply With Quote
Old 06-01-2006, 09:09 PM   #377
dnaL0R
Member#: 109472
2006 shirokuro_STI
gayness...
Old 06-01-2006, 09:54 PM   #378
waktasz
Member#: 86356
2015 s1000r
wheelie monster
17"x8" +42
You have an sti and you want to put those ghetto wheels on
I have rotas so don't think I'm acting all high and mighty, but my car didn't come stock with BBS's.
waktasz is offline   Reply With Quote
Old 06-02-2006, 10:46 AM   #379
chapstien
Member#: 68284
1988 Corolla SR5
0-points
17"x8" +42
It is not the offset, it is the design of the spokes.
chapstien is online now   Reply With Quote
Old 06-03-2006, 10:11 AM   #380
aspera
Member#: 7879
What's wrong with A-Techs? Those things are a real JDM bargain, or didn't you know?
aspera is offline   Reply With Quote
Old 06-07-2006, 05:21 AM   #381
Seamless_Linc
Member#: 109240
788 of 800
Barcelona Red Metallic
i'm buying a second hand set of rims however, the owner doesn't know what the offset is on his rims nor the what model and brand. will it say inside the rim? or on the side? it came from a 98 integra type R.
Seamless_Linc is offline   Reply With Quote
Old 06-07-2006, 07:27 AM   #382
ScoobyTodd
Member#: 19186
2005 STi
It will say on the wheel.
ScoobyTodd is offline   Reply With Quote
Old 06-07-2006, 09:39 AM   #383
tough13579
Member#: 116958
does anyone know if BSA rims model # 304 will fit my 2005 STi? they are 17x8 with a 5x114.3 bolt pattern and a +40mm offset. I am pretty sure that the rims I have on now are 48mm offset. Can I get 8mm spacers to make the rims fit correctly if they don't fit with the 40mm offset
tough13579 is offline   Reply With Quote
Old 06-07-2006, 10:03 AM   #384
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
ET40 = 8mm further out from the hub than ET48
UkNuck is offline   Reply With Quote
Old 06-07-2006, 10:13 AM   #385
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....an 8mm spacer would give you an offset of +32mm on a +40mm wheel (not 48). .....as UkNuck mentioned, the further out you push the wheel, the lower the offset.
I have 17x8 +40 wheels, Prodrive springs and 225/45 Pirelli PZero Neros on my '03 WRX without rubbing issues (camber = -1.1 front & -1.4 rear). However, this offset puts the tires quite close to the fenders. Tire choice becomes an important consideration. ......I don't know what differences there would be on your STi in regard to fitment.
Kean is offline   Reply With Quote
Old 06-07-2006, 10:43 AM   #386
Z1 Performance
Member#: 9327
Semaless Link - they won't work at all as the WRX is a 5-100 bolt pattern, the Integra is 5-114
Z1 Performance is offline   Reply With Quote
Old 06-07-2006, 11:51 AM   #387
tough13579
Member#: 116958
the biggest problem I have encountered in finding rims is that they don't fit over the brembo brakes. The sti is a 5x114.3 bolt pattern
Old 06-14-2006, 02:56 PM   #388
Xtant
Member#: 105710
2006 WRX Wagon
WR Blue Pearl
ANyone have any input on Work Emotion's in 18x7.5 +42 on an 06 Wagon. I've heard people say "hell those will rub like mad" and "should be no problem at all" Anyone have a better view on this?
Xtant is offline   Reply With Quote
Old 06-20-2006, 09:31 PM   #389
joneblaze
Member#: 98026
Hi all - need some advice.
I run a 2004 WRX. Looking to purchase a set of rims with a +38. Is this going too far? Will it scrub?
Car is stockish atm, stock shocks with H&R springs.
cheers
J
joneblaze is offline   Reply With Quote
Old 06-20-2006, 09:36 PM   #390
stidailydriver
Member#: 69650
06 sti
black w/gold
cheers
J
what size? 17x8, 17x7.5? more info....
stidailydriver is offline   Reply With Quote
Old 06-20-2006, 10:02 PM   #391
joneblaze
Member#: 98026
Sorry guys - 17 x 7". They are CE28N replicas.... something you don't come across in Sydney everyday....
Old 06-21-2006, 09:40 AM   #392
stidailydriver
Member#: 69650
06 sti
black w/gold
the offset is low, if you can deal with that they might "fit" (not correctly, but they will) might have a little bit of rubbing in the rear.
Old 06-23-2006, 02:23 PM   #393
ryankenn
Member#: 118323
Default So
If I find a wheel in 18x8 with a +38mm offset, can I use a 5mm spacer to get within the recommend zone of 43-47? ( 43 obviously ).
Thanks,
Ryan
ryankenn is offline   Reply With Quote
Old 06-23-2006, 02:37 PM   #394
waktasz
Member#: 86356
2015 s1000r
wheelie monster
No, because a spacer reduces your offest. You'd be running a +33
Old 06-23-2006, 10:10 PM   #395
aspera
Member#: 7879
...unless you have a spacer made out of antimatter and are moving faster than the speed of light while using the dark side of the Force. Use the Force. You must use the Force, I can't stress that enough.
Old 06-24-2006, 01:27 AM   #396
ryankenn
Member#: 118323
Default Thanks
Its all so clear now. So I'd have to machine 5mm off the hub, which manufacturers tend to frown on.
Would a 5mm greater offset just be a simple as rolling the fenders to clear?
The guide at the beginning it great, but doesn't include tire or wheel diameter/sizes, is there a guide like that ie. 18x8 with 215/40/18 with fit with 43-47 etc etc.
Old 08-12-2006, 03:22 PM   #397
jkass85
Member#: 106405
2004 WRX
So I can't put 17x8 wheels with a +35 offset on a 2004 wrx? I know a few people that have that size on their 2004 sti's.
jkass85 is offline   Reply With Quote
Old 08-12-2006, 03:24 PM   #398
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Depends what tire size you want and how much you want to work on your fenders and what suspension you have and how much you like your wheel bearings.
Old 08-12-2006, 07:58 PM   #399
jkass85
Member#: 106405
2004 WRX
LOL, How fast would the wheel bearings go bad? My car is lowered about an inch and a half all round, but i wasn't planning on doing anything to the fenders. I'm just looking for new wheels and 17x8 +35 seem to be popping everywhere.
Old 08-12-2006, 08:19 PM   #400
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I run 235/40s on 17x8 +48 and they fit..but that same tire on a +35 would most likely rub the fender.
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
