Old 11-20-2008, 03:27 AM   #851
fc3sna
Member#: 186592
2008 Subaru WRX
Pearl White
Default hella flush questions
i have a 2008 wrx hatch, and i am looking to get a nice wheel set up. i am looking at a set of rota g force, in cosmic blue.
18x9 35+ offset
currently i am running stock struts with sti pink springs.
how much camber would i need to run to clear the fenders,( i am planning on rolling them)
i think i heard someone state the 08 wrx's are a little bigger in the wheel clearance area.
i have a lot of wheel gap but will eventually get coil overs just not yet.
just looking for some help.
thanks
fc3sna is offline   Reply With Quote
Old 11-24-2008, 05:37 PM   #852
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
I'm running the 06 sti bbs on my 04 wrx, 17x8, I think the wheel offset is 55mm and I'm running a 25.9mm hub adaptor to fit the 5x114.3 bolt pattern. I like the aggressive look of this with the wheels spaced out flush with the fenders, but should I be concerned about running too much offset?
OUScooby is offline   Reply With Quote
Old 11-27-2008, 09:11 PM   #853
MidLifeRally
Member#: 131322
Default Sizing Help
I am building a track only 01 RS with a complete 05 STi driveline. The car will have Racecomp T2 coilovers. I'm thinking of 18x9 or 18x9.5 size rims
and have no idea of offsets and what will fit. Fenders will be rolled or cut as
needed. Anyone with any helpful info or contact with someone with a similar
setup would be appreciated. Thanks!
MidLifeRally is offline   Reply With Quote
Old 12-21-2008, 01:23 PM   #854
bigstrusk
Member#: 118856
2000 GM6 STM
'07 S2K, '01 Ninja 250R
Okay I'm tryin to determine the root cause of my damn rear wheel bearings failing... just did #3 on MY00 RS. I've got 17x8 ET48 5Zigen FN01R-C's, and I ran them for about 1.5 years sans snow season. Like I said, the bearings are going still. I know this config is nearly within the specs listed on the first page, but just wanted to hear others' opinions? Could be the deciding factor in if I sell them...
Also, which might be pertinent, running -0.3 rear camber w/ 0 toe, and have less than 2 seasons of autoX on the last 2 rear bearings. Forgive me if this is in the wrong thread, but I'm mainly wondering if the offset/wheels are the killers or not. Thanks guys.
bigstrusk is offline   Reply With Quote
Old 01-13-2009, 09:46 PM   #855
STIckySTIfee
Member#: 162812
2004 STI
What about a 18x9.5 with a +38 offset and 5mm spacers in front on my 2004 STI with stock struts and prodrive lowering springs?
STIckySTIfee is offline   Reply With Quote
Old 01-19-2009, 12:09 PM   #856
tprokop
Member#: 200607
2006 Subaru WRX Wgn.
Steel Gray
Thanks so much for the info... very informative when I was shopping for winter wheels.
tprokop is offline   Reply With Quote
Old 01-28-2009, 07:50 PM   #857
sublimeplaid
Member#: 106044
2011 Tacoma
I want to get some wheels from my buddy who has an EVO, they are 18x9.5 +22, obviously they will fit with rolled fenders, springs, and camber, but is that just a retarded offset to have on an '08 STI? I'm going for function, not looks. They are Volk TE37's.
Thanks in advance, I know this is a broad question.
sublimeplaid is offline   Reply With Quote
Old 02-01-2009, 09:18 AM   #858
JORSH
Member#: 168046
2006 WRX TR
RED
edit. saw reply above
JORSH is offline   Reply With Quote
Old 02-03-2009, 12:24 PM   #859
ginsta
Member#: 158442
2003 wrx 07 STIFront
blue
will 17x8 +35 offset with 225/45/17 work on a 2003 wrx? I was running the same tire wire 17x7 +40 offset with no problem
ginsta is offline   Reply With Quote
Old 02-05-2009, 09:08 PM   #860
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
Ok, i tried searching through the thread, i tried to make sense, yet i still find myself not being able to tell my ass from a hole in the ground.
I have an 03 Wagon...
I am looking at getting some 18x7 5 spoke centerlines, and yes, i realize that its a skinny ass wheel. The wheels have a +42mm offset, now it is out of the range listed, but it seems that although it'd be pushed outward a bit, it won't exceed the edge of the fenders judged on other posts. But i am worried about potential wheel bearing death with that setup. Can anyone help me out here?
Cliffs Notes:
18x7 +42mm, will it work without worrying about wheel bearings?
I know its a skinny wheel
~Alex
Xcelr8to1320 is offline   Reply With Quote
Old 02-12-2009, 12:44 AM   #861
subarunation24
Member#: 202717
2004 WRX STi
Black with gold flake
I am fairly new to the game, and i was wondering how offsets work? Like for instance the larger the number the ______ the offset. and i am also just currious to know if you know what the biggest offset i could go on my 04 sti
subarunation24 is offline   Reply With Quote
Old 02-12-2009, 09:26 AM   #862
waktasz
Member#: 86356
2015 s1000r
wheelie monster
The lower the number, the farther the wheels stick out.
waktasz is offline   Reply With Quote
Old 02-13-2009, 03:51 AM   #863
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Try reading the 34 pages before this one, loads of info there.....
Micky is offline   Reply With Quote
Old 02-17-2009, 11:22 PM   #864
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
i dont really want to ask this since nobody will probably answer it anyways but i have an 05 wrx with tein s tech coilovers on it. will these fit my car
Rota Grids Hyper Black 5x100 18x9.5 +35
Nexen N3000 255/35/18
i was wondering cause there is no offset posted for 18x9.5 willl i rub at all?
under0athh51189 is offline   Reply With Quote
Old 02-18-2009, 01:58 AM   #865
n2oiroc
Member#: 141952
15 legacy 16 wrx
you will rub the fenders for sure. inside you should have plenty of room though, but that really doesnt help.
n2oiroc is offline   Reply With Quote
Old 02-18-2009, 01:59 AM   #866
n2oiroc
Member#: 141952
15 legacy 16 wrx
Cliffs Notes:
~Alex
that narrow of a wheel and that offset are fine, dont worry about wear. just a heads up though. centerline wheels spin about as round as eggs. dont blame the tire guy if you have a vibration. he can balance down to all 0's but it wont help when the wheel isnt round.
Old 02-18-2009, 09:05 AM   #867
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
I'll keep that in mind, I haven't had any problems with centerlines before. Odds are that i'm gunna go to a wider wheel in the future anyways, i can't fit enough tire on a 7" wheel, but these we're too cheap to pass on. I want to go to a 235 at minimum, but on a 7" wheel the contact patch is somewhat sacrificed, so a wider tire tire won't help on the 7" wheel.
Old 02-18-2009, 05:14 PM   #868
STi_Man
Member#: 79096
2004 Impreza WRX STi
Hi Guys,
What are the specs need to install Bogart wheels, 15 x 8 with Wilwood smaill break kit. This is for a 2004 USDM STI?
Thanks,
Aldo
STi_Man is offline   Reply With Quote
Old 02-19-2009, 01:56 PM   #869
under0athh51189
Member#: 193959
2001 Lexus IS300
just wondering i have tein s tech coilovers on my 05 wrx and im looking at rims that are 18 x 7.5 with a +40 offset . is this going to rub?
Old 02-23-2009, 10:33 PM   #870
BlobeyeSTi
Member#: 187877
04 WRX STi
Nice thread..helped a lot when picking out new summer wheels
BlobeyeSTi is offline   Reply With Quote
Old 02-28-2009, 12:21 AM   #871
STepeci
Member#: 191479
2008 E92 M3
Alpine White
what about for us widebody guys? =]
STepeci is offline   Reply With Quote
Old 03-01-2009, 03:20 PM   #872
Himynameisgreg
Member#: 200420
'15 LR WRX
'05 AW STI Track Car
will 18x8 with + 48 rota p45fs wrapped in nexen n3000 225/40r/18 fit my 08 impreza 2.5i. or would i be better off going with 17's?
Himynameisgreg is offline   Reply With Quote
Old 03-05-2009, 11:51 AM   #873
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
Looking to put on some 17x9 +35 on a 245/40 tire for a 08 WRX sedan. Will I run into problems??
lateralus1082 is offline   Reply With Quote
Old 03-06-2009, 08:31 AM   #874
MrBlue
Member#: 34978
2006 WRX
Gray
You guys have crushed my hopes and dreams. I found the perfect set of rims but they will not fit at 17"x7" +38. I hate you all.
How nice would these look on a dark gray 06 WRX
MrBlue is offline   Reply With Quote
Old 03-07-2009, 11:27 AM   #875
Chacha
Member#: 183065
2001 2.5 RSTi
BRP
Ordered Bronze Volk RE30's 18x8 +45
Cars in the body shop next weekend getting paint, should i get the fenders rolled?
Cars lowered on eibachs and KYB's right now, but im swapping those out for either Teins, or tarmac zeals...
Ive skimmed most of the entire thread, havent really found a concrete answer except that the original post was wrong?
Theres a few people asking about 17x8 +45, getting mixed answers.
So i guess what im looking for is... Do i roll? Will it rub if i dont... and is Tirerack wrong? I ask because 215/40/18 is apparently the recommended size for my 2.5RS coupe on an 8" wide shoe, i thought it would have been 225 min.
Chacha is offline   Reply With Quote
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
