Old 12-15-2010, 09:38 AM   #1276
mosc
Member#: 177401
2015 STi White
impossible to answer without the offset.
mosc is offline   Reply With Quote
Old 12-15-2010, 11:00 AM   #1277
xtremesk8er21
Member#: 180547
2007 VF39 WRX
STi Mikey tuned
17x9 rota grids offset 30mm hub bore 73mm
xtremesk8er21 is offline   Reply With Quote
Old 12-18-2010, 02:47 PM   #1278
argyle409
Member#: 264130
2007 Outback XT
Newport Pearl Blue
The stock wheels on my '03 Outback are: 16x6.5 JJ alloy, offset 48mm
I want to upgrade to '04 oem wrx sti bbs 17x7.5 53mm offset
From what I read online typically anything in the 6.5"-8.0" width and approx +45mm offset +/-5mm will work great. Since, there is only 5mm difference between what I have now and what I would buy they should just bolt right on no problem since both are hubcentric rings. Maybe need some new lug nuts or is there something key that I am missing? Thanks
argyle409 is offline   Reply With Quote
Old 12-18-2010, 04:36 PM   #1279
mosc
Member#: 177401
2015 STi White
those work fine.
Old 12-18-2010, 04:56 PM   #1280
argyle409
Member#: 264130
2007 Outback XT
Newport Pearl Blue
Originally Posted by mosc View Post
those work fine.
Thanks
Old 12-19-2010, 05:18 PM   #1281
Pocono Legacy GT
Member#: 267155
2005 Legacy GT Lim
Obsidisan Black
Go for 20's! Dubz son
Pocono Legacy GT is offline   Reply With Quote
Old 12-19-2010, 06:48 PM   #1282
xtremesk8er21
Member#: 180547
2007 VF39 WRX
STi Mikey tuned
Once again I hate u
Old 12-19-2010, 07:34 PM   #1283
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by xtremesk8er21 View Post
my girl just bought me rota grids 17x9 any tire size suggestions? also wanna run a good coilover setup thinking about the BC br series
guess i should say that i want to know what width tires would be ideal
what look are you going for? super low with stretched tires? or a little higher with more tire?
+30 is gonna require front and camber adjustment and a good amount of fender work.
Old 12-19-2010, 09:56 PM   #1284
xtremesk8er21
Member#: 180547
2007 VF39 WRX
STi Mikey tuned
I don't want to be crazy low, just to eliminate the wheel gap.
Old 12-19-2010, 10:10 PM   #1285
nhat
Member#: 140163
03 STi
hellaflunctional
at least a 235/40/17. personally i'd be running a 245 or 255, but doubt you're tryin to do that much fender work and/or run that much negative camber.
Old 12-20-2010, 12:15 AM   #1286
rkjunior
Member#: 112220
2011 WRX 5DR Premium
How wide should I go with a Rota Gravel 18x8 +48.. I'm installing d-specs with black STI springs and don't want it to rub. 235/40/18?
rkjunior is offline   Reply With Quote
Old 12-20-2010, 12:55 AM   #1287
nhat
Member#: 140163
03 STi
hellaflunctional
that'd be my choice...and what do you mean black sti springs? oem sti springs? or rce blacks?
Old 12-20-2010, 02:13 PM   #1288
sc00by4life
Member#: 97135
255/35/18.
Old 12-20-2010, 05:45 PM   #1289
rkjunior
Member#: 112220
yeah, just the stock black STI springs. I'm not looking to slam it - i just want to lessen the gap a little. It's just a daily driver.
255/35/18s seems a bit ridiculous for a daily driver? lol
Old 12-20-2010, 09:32 PM   #1290
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Plus that's too wide for an 8" wheel. Yes you can get them on there and drive with them, but it's not right. 245/35R18 is really the max size for an 18x8.
Breezio is offline   Reply With Quote
Old 12-20-2010, 09:43 PM   #1291
nhat
Member#: 140163
03 STi
hellaflunctional
255/35/18s would be better for wrx gearing which is why sc00by4life for life recommended that size. 245/35/18 would be a better size due to the 8" wide wheel, but tire selection is very limited in that size.
thus why i recommended a 235/40/18.
Old 12-20-2010, 10:10 PM   #1292
sc00by4life
Member#: 97135
255 is pushing it, but it is not too wide for an 8" wheel. I think its probably the widest recommended section width though. But like nHat mentioned, as I said, it would be better for wrx gearing.
Old 12-20-2010, 11:15 PM   #1293
rkjunior
Member#: 112220
I guess I don't understand how wide a wheel affects gearing. I thought it was the diameter.
Old 12-21-2010, 10:23 AM   #1294
Breezio
Member#: 234357
2009 WRX
Width doesn't.
However, when you are talking tire sizes, a 245/35 is slightly smaller in diameter then a 255/35
P.S. Tirerack puts the minimum recommended rim width for a 255/35/18 at 8.5" .
I was just going with that.
Old 12-21-2010, 01:37 PM   #1295
sc00by4life
Member#: 97135
changes in width result in changes of sidewall height, which result in changes of overall diameter.
the first number is section width (in mm), the second number is the percentage of section width used to calculate out sidewall height.
Old 12-21-2010, 04:59 PM   #1296
rkjunior
Member#: 112220
Gotcha. I thought it was just a static sidewall number. Learn something new every day!
Old 12-21-2010, 10:36 PM   #1297
Breezio
Member#: 234357
2009 WRX
Thanks for the better explanation sc00by4life.
Old 12-22-2010, 03:01 PM   #1298
dub c
Member#: 145069
Keep It Sleazy
Hey NASIOC,
Quick question... Making sure I understand offsets correctly.
Will a 10" 0 offset wheel stick out the same amount as a 9" -25 offset wheel?(I don't care about the .4mm's)
Thanks in advance.
dub c is offline   Reply With Quote
Old 12-22-2010, 09:04 PM   #1299
Breezio
Member#: 234357
2009 WRX
Originally Posted by dub c View Post
Hey NASIOC,
Thanks in advance.
No.
Half the width change is happening to the inside of the wheel, the other have to the outside.
To make your example equal in 'sticking out'. Your 9" wide wheel would need a -13mm offset (give or take some tenths) to 'equal' the 10" wide 0mm offset wheel.
Old 12-22-2010, 09:16 PM   #1300
sc00by4life
Member#: 97135
No, the 9" wheel will sit 12mm further out than the 10" wheel. You'll also lose 38mm of inner clearance on the 10" wheel.
and neither of those will fit stock body. Widebody time!
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
