Old 03-01-2011, 11:02 AM   #1376
jackthisnot
Member#: 223243
What kind of offset should you have on an 8.5" wheel? sorry if it is some were in the 50+ pages of this thread but i just dont have time to sit and read every post. thanks in advance for any helpful info.
jackthisnot is offline   Reply With Quote
Old 03-01-2011, 12:56 PM   #1377
sc00by4life
Member#: 97135
then you should stop trying to modify your car. seriously.
sc00by4life is online now   Reply With Quote
Old 03-01-2011, 02:42 PM   #1378
My Silver Wagon
Member#: 268839
2002 WRX Wagon
Boring SILVER
Originally Posted by sc00by4life View Post
With any spacer with pressed in studs (conversion or not), I would never go narrower than 25mm.
Any specific reason??? How much would the 25mm Conversion Spacers and the +40 offset on the TE37 Super Lap Wheels(17x8.5) affect the difficultly factor of fittment on my car??? Without screwing up my Wheel Bearings and other suspension stuff too badly? Thanks guys for all your advice. Me Stupid Newbie;-(
My Silver Wagon is offline   Reply With Quote
Old 03-01-2011, 05:37 PM   #1379
sc00by4life
Member#: 97135
Its a strength issue. When you bolt on conversion spacers, you will need to cut your stock studs just about in half. With the larger spacers (the 25mm's that I SUGGEST IF YOU GO THAT ROUTE), you won't need to cut as much as you would with say a 10mm or 15mm. This allows for more contact between the lug and the original stud.
You'll also need to worry about stretching tires with the 25mm spacers though....
or you can find 5x100 wheels.
Old 03-01-2011, 07:56 PM   #1380
My Silver Wagon
Member#: 268839
2002 WRX Wagon
Boring SILVER
Thanks for the input,will consider all op's thanks
Old 03-06-2011, 11:52 AM   #1381
triscuitmg
Member#: 275956
OK reading all these posts and i am in the air still on fitment. I have a 02 WRX and am about to buy Konigs 18x7.5 45mm offset and runing 2254018s. from what i read it is about 2mm in the grey area i guess you can call it and would work ok. anyone else run that size and not have problems? car is stock height for the time being. any advice would be greatly appreciated.
triscuitmg is offline   Reply With Quote
Old 03-06-2011, 02:53 PM   #1382
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Seems to me that would fit easily and over all diameter would be close to stock..?
I can't remember what the factory tire size is on the bugeyes...
Breezio is offline   Reply With Quote
Old 03-07-2011, 10:42 AM   #1383
mosc
Member#: 177401
2015 STi White
Stock height on a bugeye is 25". 225/40R18 is fine.
mosc is offline   Reply With Quote
Old 03-07-2011, 05:47 PM   #1384
triscuitmg
Member#: 275956
OK my main concern was that there will be no premature wear on my wheel bearings and i won't have any rubbing issues, especially if i decide to lower it in the summer time. Hoped someone else on forum might be running a 18x7.5 with a 45mm offset that can reasure me i am safe running the wheel. thanks again.
Old 03-08-2011, 12:52 PM   #1385
nhat
Member#: 140163
03 STi
hellaflunctional
people really need to stop worrying about the 5x100 wheel bearings. i had 100k on mine and never had to replace them after numerous sets of wheels with varying offsets.
Old 03-10-2011, 03:45 PM   #1386
Touge Factory
Member#: 182232
2005 STi
Customer's GRB STi on STANCE GR+Plus w/ NT03M 18x10.5+30:
Touge Factory is offline   Reply With Quote
Old 03-10-2011, 05:04 PM   #1387
flat4doniz
Member#: 263475
tires spec pls and what kin of lip kit is that?
flat4doniz is offline   Reply With Quote
Old 03-10-2011, 05:23 PM   #1388
nhat
Member#: 140163
03 STi
hellaflunctional
i'm reposting this in the fitment thread. can you guys chime in with tire size, alignment specs, and fender mods in the other thread?
Old 03-11-2011, 11:21 AM   #1389
Touge Factory
Member#: 182232
2005 STi
245/40/18s with -2.5* camber on all four corners.
And I'm not sure what lip it is because the customer did not purchase through us. I'll see if I can find out.
Old 03-11-2011, 12:51 PM   #1390
sc00by4life
Member#: 97135
that lip looks like the new(er) JNA.
Old 03-11-2011, 03:20 PM   #1391
mosc
Member#: 177401
2015 STi White
245 on a 10.5" wheel is moronic and dangerous.
Old 03-11-2011, 03:25 PM   #1392
sc00by4life
Member#: 97135
^^ people stretch more than that, and have 0 problems.
Old 03-11-2011, 03:48 PM   #1393
mosc
Member#: 177401
2015 STi White
People eat McDonalds every day and say they have no health problems too. People, in general, are idiots.
Old 03-11-2011, 03:53 PM   #1394
sc00by4life
Member#: 97135
But its not our problem .
Old 03-12-2011, 12:36 PM   #1395
nhat
Member#: 140163
03 STi
hellaflunctional
you don't need to look any further than any car forum to realize that
Old 03-14-2011, 12:34 PM   #1396
Touge Factory
Member#: 182232
2005 STi
Admittedly not enough meat for any serious track driving, but for a daily it should suffice. It certainly accomplishes the goal of breaking necks as it drives by.
As far as fender work, it was only a roll in the rear and no pulling with no literally no rubbing at full-lock.
Old 03-14-2011, 12:59 PM   #1397
flat4doniz
Member#: 263475
thinking of doing this, how much do you guys charge for fender rolling?
Old 03-15-2011, 12:23 AM   #1398
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
ok, just want to confirm that these will fit properly or if i have to roll fenders, etc....
i'm looking to get a Rota SVN 18x8.5 +48 and it comes with 235/40/18 tires.
my car's suspension is stock, but will be getting Epic springs soon.
i've seen it on some wrx's but just wanted to make sure..
thanks guys!
thesniperz is offline   Reply With Quote
Old 03-15-2011, 12:02 PM   #1399
nhat
Member#: 140163
03 STi
hellaflunctional
thanks guys!
please don't double post. already answered your question in the other thread.
Old 03-15-2011, 02:03 PM   #1400
mosc
Member#: 177401
2015 STi White
thanks guys!
sidewall's wrong. You want <25" with a WRX 5-speed. 35 sidewall would be better gearing.
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
