![]() Tire & Wheel Forum sponsored by The Tire Rack |
#2026 |
Member#: 328703
Vehicle:2010 Impreza 2.5i Dark Grey Metallic |
Hey Sc00by,
Thanks for the input... I wanted to run a wheel and tire that would put more rubber on the ground and give me a close to edge look without rolling the fenders. This is the look I want to accomplish. I really like the look of the rota grid or xxr522, so any suggestions of size and tires would be appreciated.
#2027 | |
Member#: 328703
#2028 |
Member#: 33137
Vehicle:03 wrx sedan wrb |
So, Rota Grids +42 offset with 17x9 and 225/45/17 tires will not require fender rolling?
Thanks again.. |
#2029 | |
Member#: 97135
NWIC
That kind of stretch isn't needed on a +42, and will look goofy. Try going up to a 235/40 or 245/40 |
#2030 |
Member#: 328703
Ok, so I should run with a set of 17x9 +42 with a 235/40 tire....or could I run a 17x7.5 +48 with the 225/45 and get the desired effect and feel without needing to roll the fenders?
#2031 | |
Member#: 97135
NWIC
#2032 |
Member#: 328703
Cool, thanks for your help Sc00by... I appreciate it.
#2033 |
Member#: 301348
NESIC
Vehicle:2012 WRX DGM |
so I have a set of steel wheels that came off of a VW. They are 16x6.5 and I believe 42 offset. I was going to sell them to a guy but he doesn't think they will fit on his 2008 outback sport. I told him I was almost positive they would since I've see them on the new WRX's, but I just wanted to double check.
#2034 | |
Member#: 97135
NWIC
#2035 |
Member#: 301348
NESIC
#2036 | |
Member#: 97135
NWIC
#2037 |
Member#: 301348
NESIC
#2038 | |
Member#: 97135
NWIC
#2039 | |
Member#: 25262
South East
Vehicle:2006 LGT BSM |
#2040 |
Member#: 152400
TXIC
Vehicle:2002 WRX / RC 51 Midnight Black Pearl |
What do you guys and girls think about this?
bugeye on 04 sti struts and sti tein s-tech springs: 17x9" with +38 offset on 275 40 17 tires? I'm thinking fender rolling would be necessary, but with the +38 think I can fit all that tire in there without rubbing somewhere other than the fender? |
#2041 | |
Member#: 97135
NWIC
no fender clearance will be the hardest part to fit that much tire. |
#2042 | |
Member#: 152400
TXIC
Should I just make it easier on myself and go with a smaller width tire? The roads around here suck so I need enough tire to protect the rim. If I have 225's on my car and it fits fine, would a 225 on a 9" rim be fine or would the rim rub? And I'm not saying I will go with a 225 because I'm not a fan of stretching tires. I still want performance. |
#2043 |
Member#: 97135
NWIC
lol from 275 down to 225.
225 will stretch quite a bit. with a roll all around and aggressive camber you could fit a 255 fairly easily. |
#2044 |
Member#: 319022
Vehicle:2002 Subaru WRX |
I have a quick question about offset. I'm going from my stock 02 wrx rims which are 16x6.5 I believe with a +55mm offset to a set of enkei's which are 17x7 with a +39mm offset, I just want to double check and make sure that this would be okay and safe? Any help/advice is appreciated. Thanks
#2045 | |
Member#: 323869
W. Canada
Vehicle:2000 ST-outback White/Grey |
Never ever ever run Conical (taper) lug nuts on a ball seat lug hole. The contact patch of the lug is extremely small and WILL FAIL. Running ball seat lugs in a cone seat hole isn't as big of an issue because there's a larger contact patch between the two surfaces, but it's still not ideal. They make ball seat to cone seat washer inserts that go between your lug and the wheel. I'm running these because the wheels I bought came with a ball seat (even though I asked for cone seat) and have not had any issues yet. They're super cheap as well. |
#2046 |
Member#: 329136
i know this have nothing to do with the thread, but it would not let me ask a question, i bought these wheels today which are universal will fit 4x100, 5x100 and and 4x114 my car is 05 wrx 5x100 and the wheels will not fit the holes almost line up but they dont anyone have any suggestions?
#2047 |
Member#: 97135
NWIC
because you can't have a wheel that has 3 different bolt patterns.
my guess is yours aint one of them. |
#2048 |
Member#: 291430
International
Vehicle:2006 WRX wagon Black |
hi guys, please one question!
is 17x7,5 +35 offset too wrong to a 2006 wrx wagon? I found a good price here for this set, first page recommends 7.5" ...+47 to +50, but...who knows? maybe +35 fits...? thanks! |
#2049 |
Member#: 97135
NWIC
on a wagon, thats a bit low. You might need to roll the rear depending on ride height and camber settings.
#2050 | |
Member#: 291430
International
read some pages back, and saw someone warning about bearings and things...maybe is more safe to use the offset values in the table of the first page... wagon fitment looks to be specific. 17x8 +45 will be ok? stock height, maximum of -1.5 camber on front, rear is stock... thanks! |
| Thread Tools | |
| Display Modes | |
| So I read the Offset thread... | Dracon | Tire & Wheel | 6 | 11-18-2012 04:39 AM |
| The Hella Flush Information Thread | Impreza2.5i-Kid | Tire & Wheel | 16 | 08-23-2010 08:33 AM |
| The end all 6 speed swap information thread | DS1 | Transmission (AT/MT) & Driveline | 156 | 11-14-2009 08:21 PM |
| Can we correct "The Offset Information Thread"? | Portly | Tire & Wheel | 15 | 02-25-2006 06:48 PM |
| The Header Information Thread | imposter | Normally Aspirated Powertrain | 315 | 04-25-2003 02:59 PM |
