Old 10-04-2012, 03:07 PM   #2051
sc00by4life
Member#: 97135
17x8 +45 would probably be the ideal setup.
Old 10-11-2012, 02:47 AM   #2052
Frey Bone
Member#: 6252
2000 GC8 w/STI
Default Very straight forward question.
Could this thread be more confusing?
If nirvana is:
8.0" ....... +43 to +47 (assuming for a stock suspension set-up)
...and stock STI wheels (05-07) are 8" wide--
Why are the stock wheels +53 offset?
Did I read through ALL 53 odd pages. NO. Did I read through a bunch?
YES.
Did I do a bunch of searches?
YES
Frey Bone is offline   Reply With Quote
Old 10-11-2012, 03:16 AM   #2053
sc00by4life
Member#: 97135
If nirvana is:
YES.
YES
why don't our cars have all forged internals? why aren't the EJ255/7 tunes better? why do USDM sti seats suck? hell, why are upgrades even available for cars?
Things aren't always the "best" from the factory.
Old 10-11-2012, 03:25 AM   #2054
Frey Bone
Member#: 6252
2000 GC8 w/STI
Damn, the USDM seats sure do suck, thanks for reminding me.
...so, is it the case the consensus is that +43 - +47 is a "better" offset.
When it comes to offset- (which really isn't explained here btw):
Clear the brakes
Clear the suspension
Doesn't rub on the fender
Isn't hard on the wheel bearings
I'm guessing by better- the 43-47 measure beats the +53 in these facets of fit?
Are there any other aspects I'm missing?
Thank you by the way.
Old 10-11-2012, 04:00 AM   #2055
sc00by4life
Member#: 97135
offset doesn't really mean much in terms of brake clearance, that is almost purely based on wheel design.
lower offsets also widen the track of the car, reducing weight transfer.
going too low results in an increased scrub radius and moves the "dave point" away from the center of the contact patch, reducing steering feel and kickback.
Old 10-11-2012, 04:24 AM   #2056
Frey Bone
Member#: 6252
2000 GC8 w/STI
...ok, good, I like where this is going.
So- you go too low, and the tire rubs on the fender? -is also harder on wheel bearings?
Old 10-11-2012, 04:35 AM   #2057
Frey Bone
Member#: 6252
2000 GC8 w/STI
...is there any formula that correlates offset (in mm) to change in scrub radius?
Most of the information I found on scrub radius talked mostly in terms of ease when parking, or what happens in the event of a braking circuit failure- not in terms of changes in handling while driving + or -
Old 10-11-2012, 04:39 AM   #2058
Frey Bone
Member#: 6252
2000 GC8 w/STI
...or better yet- do you know where the Dave point would be on a stock '05 sti relitave to a wheel with say +47 offset?
That is, do you know if the Dave point is inside the center of the tire on the stock +53 wheel/suspension set up?
THANKS!
Old 10-11-2012, 02:14 PM   #2059
sc00by4life
Member#: 97135
Whether something rubs on the fender has a few different contributing factors. The combination of wheel width + offset being one of them, the second being tire size.
The change in scrub radius is mostly only noticed at low speed tight cornering. . As far as a formula that directly correlates to track width to how much scrub radius is increased, I'm not exactly sure off the top of my head, but I don't doubt thats it exists somewhere on the internet.
THANKS!
A change in 5mm would effectively move the dave point a fraction of that length rearward. Its definitely a subtle difference, but not nearly enough of to outweigh the benefits of the *slightly* wider track. Idealy, the dave point should be just be centered on the tires contact patch. Obviously....there are plenty of ways to adjust the dave point in relation to relative offset, but that is far beyond the average enthusiests understanding of steering and suspension.
Again though.......this is mostly relevant for track cars. Will the average driver notice these things under normal conditions? no.
Old 10-11-2012, 08:58 PM   #2060
DoogieSTi
Member#: 247023
2007 STi
07 STi
Coilovers
245/40/17
17X9 et 30 or 42?
Will be rolling front and rears.
Thanks for opinions.
DoogieSTi is offline   Reply With Quote
Old 10-11-2012, 09:26 PM   #2061
DoogieSTi
Member#: 247023
2007 STi
^^ Disregard. I read the details wrong. It was +25 not +30. I'm definitely not going that low... Guess I'll stick with +42
Old 10-11-2012, 10:42 PM   #2062
S1CkWrx
Member#: 325249
2012 wrx
dgm
2012 wrx here. looking at some 18x9.5s or 18x10s will be soon lowered on BC coilovers. just wondering il stay within the 30-40offset range. lower being it will poke more. i just want it inside the fenderwells. im looking at either 235/45/ or a little more beef 245 or 255...
S1CkWrx is offline   Reply With Quote
Old 10-11-2012, 11:26 PM   #2063
sc00by4life
Member#: 97135
Run an 18x9.5, roll all around and have fun going low with a 265.
Still at a loss as why people buy a brand new car and put the cheapest coilovers possible on it.
Old 10-11-2012, 11:47 PM   #2064
S1CkWrx
Member#: 325249
2012 wrx
dgm
car will be on air by the end of winter. just need something to hold me over
Old 10-16-2012, 06:30 PM   #2065
04reddragon
Member#: 216553
2006 wrx sti
gray
i have 04 wrx with 17x8 running 235/35/17 and no issues future i would like to have 17 8.5 since most have issues with 17 9 and run 245/40 or 45/17 for better handling???
04reddragon is offline   Reply With Quote
Old 10-16-2012, 07:54 PM   #2066
RobNJ36
Member#: 326442
2010 Sti
I searched and I read...........would appreciate a quick answer. Whats great about this site is all the different opinions it also drives you crazy sometimes. My 2010 Sti stock wheels are 18X8.5 55 offset........I'm getting ready to buy a winter setup. Rim size would be 17x7-17X7.5-or 17X8 depending on which wheel I choose. If I stay with an offset of 45 or higher I should have no issues with brake clearance ???.....The last thing I want to do is ship back 4 wheels. Thank you in advance !!
RobNJ36 is offline   Reply With Quote
Old 10-16-2012, 10:13 PM   #2067
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
It's going to be an individual wheel basis. In a totally generic standpoint, a lower offset will be more likely to clear the brakes. But really, individual wheel design matters infinitely more.
Breezio is offline   Reply With Quote
Old 10-17-2012, 01:10 AM   #2068
sc00by4life
Member#: 97135
Offset means literally nothing in terms of brake clearance.
It's ALL based on the wheel design.
Old 10-17-2012, 06:05 PM   #2069
RobNJ36
Member#: 326442
2010 Sti
Guys..........understood thank you.......So if I order from Tire Rack or Discount Tire the wheels they have in stock specified for my vehicle all should fit with no clearance problems then. I assume they did their homework? 17x7 or 17X8 with a 45 or 47 offset all good ?
Old 10-17-2012, 09:18 PM   #2070
sc00by4life
Member#: 97135
why don't you pm [email protected] and have him help you out if you are unsure .
Old 10-18-2012, 08:08 PM   #2071
RobNJ36
Member#: 326442
2010 Sti
All good...got it sorted out thank you
Old 10-29-2012, 03:43 PM   #2072
11stikmd
Member#: 324246
2011 STi
Default Rota Grid Fitment
Disregard post
Last edited by 11stikmd; 10-29-2012 at 09:00 PM. Reason: Will keep searching threads
11stikmd is offline   Reply With Quote
Old 11-06-2012, 06:19 PM   #2073
Bryan_15
Member#: 337192
2010 Subaru Wrx
Helped a lot
Bryan_15 is offline   Reply With Quote
Old 11-07-2012, 07:38 PM   #2074
bicho_ojo
Member#: 268847
2005 35r'd STI
I'm looking to purchase enkei RPF1 in an 18 inch wheel what is a good size to where is clears brembos and me not having to rolls fenders also same for a set of NTO3's as well.
Thanks,
Grant
bicho_ojo is offline   Reply With Quote
Old 11-09-2012, 12:33 PM   #2075
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
What kind of fender mods will I be looking at with a 17x9 +25 or +35 offset wheel? On a 08-10 body style sedan With a 235/45 tire. EDIT forgot to mention im on coilovers.
Slow Scoobie is offline   Reply With Quote
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
