Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 02-20-2013, 09:24 PM   #2126
army21b
Member#: 228116
1998 Forester
I've searched and havent found an exact answer.
18x9.5 +40 Enkei NT03's
what is the minimum spacer to clear brembo's? I know a 10mm will work but i want as much inboard clearance as possible
army21b is offline   Reply With Quote
Old 02-21-2013, 03:06 AM   #2127
sc00by4life
Member#: 97135
18x9.5 +40 NT03's require 10mm at minimum.
You'll already have a bunch of inboard room, not sure why you would be concerned with that.
Old 02-23-2013, 08:23 PM   #2128
lite
Member#: 98582
Hi, tried searching these specs but couldn't find much info.
I'm thinking about getting a set of Advan RG in 17x8.5 +31 that was previously on a DC5 Integra.
Would that offset screw up the bearings on a '05 STi?
lite is offline   Reply With Quote
Old 02-26-2013, 12:32 PM   #2129
nhat
Member#: 140163
03 STi
hellaflunctional
No. You'll rub without modifying fenders.
Old 03-05-2013, 06:18 AM   #2130
98stimenace
Member#: 289023
Metalic silver pearl
Default new to the aftermarket rim deal
I really don't want to sound like a noob, but I am when it comes to rims so I'll keep the questions and details simple. I own a 2002 wrx, stock suspension and stock 16" rims. I plan on buying a set of used ASA Ka3 rims, 5x100 with kumho Ecsta 215/45/17x7.5 i do not know the offset. Will or should these fit my car? will i need spacers or hubcentric rings(i know they are essentially the same)?
Any info regarding this will greatly be appreciated and I thank you in advance. Again sorry for the noob question... And in case anyone is wondering, I chose these because they are what I can afford and I think they will look decent for my car. I'm not worried about keeping them clean because i have been known to "play" in the fields around where I live. Thanks for the help!!!
98stimenace is offline   Reply With Quote
Old 03-05-2013, 06:19 AM   #2131
98stimenace
Member#: 289023
oh and i also forgot to mention, I have the stock calipers for now and no modifications to the fenders...Thanks
Old 03-05-2013, 12:58 PM   #2132
nhat
Member#: 140163
03 STi
hellaflunctional
Have you tried searching for the wheel specs? They'll fit your car but nobody can tell you if they'll run without offset.
Old 03-05-2013, 02:52 PM   #2133
98stimenace
Member#: 289023
i contacted the seller and still haven't heard back from him yet. i'm gonna go put google to some use right now
Old 03-05-2013, 02:56 PM   #2134
98stimenace
Member#: 289023
i'm finding an et48, assuming thats a +48 offset?
Old 03-05-2013, 09:19 PM   #2135
nhat
Member#: 140163
03 STi
hellaflunctional
Yup. Those will fit without issue.
Old 03-07-2013, 10:16 PM   #2136
Scoobsdoh
Member#: 349348
13 Scoob
Plasma blue pearl
Super informative post I'm just getting in on the forum world but I'm learning so much
Scoobsdoh is offline   Reply With Quote
Old 03-09-2013, 09:45 AM   #2137
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Going to require a pull or at least -2.5* camber in the rear.
Thank you for an answer. I have found a wheel with a et42 that I like. 4mm isn't much, but I hope it will help.
svynx is offline   Reply With Quote
Old 03-17-2013, 04:34 PM   #2138
Antiharper
Member#: 350489
09 Impreza 2.5i
Has anyone had fitment issues with 17x7.5 5x100 +45 offset on 09 impreza 2.5i 4dr? And a solution would be nice too!
Antiharper is offline   Reply With Quote
Old 04-10-2013, 11:29 AM   #2139
NewportSooob
Member#: 333403
I'll be putting Focal 428 F04's on my 09 Impreza 2.5i tomorrow. At 16x7, will there be any problems with an offset of 42?
NewportSooob is offline   Reply With Quote
Old 04-10-2013, 05:33 PM   #2140
Isthatjon
Member#: 352978
Varrstoen es111 18x9.5 +34 on a 2004 sti?
Isthatjon is offline   Reply With Quote
Old 04-10-2013, 06:09 PM   #2141
sc00by4life
Member#: 97135
you only need to post once in one place. stop.
Old 04-11-2013, 12:28 AM   #2142
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
There should be no issues with a wheel that size on that car given any reasonable tire size mounted too it, such as 225/45R17
Breezio is offline   Reply With Quote
Old 04-13-2013, 12:42 AM   #2143
blackdout
Member#: 49066
97 Toyota Supra
i will add this question in this thread as well since its offset related. So here goes
So ive been told different opinions on this and wanted to get more input.
What is the possiblity to fit a 18x9.5 +45 on a 2003 subaru wagon.
My intentions on suspension is BC coilovers and camber bolts rolled fenders
Tire would be 235 or 245
Now some have said it will work and some have said that due to the higher offset the inner clearance is the issue hitting the strut.
My question is if this setup does not work what is the minimum offset that is needed on a 18x9.5 wheel?
blackdout is offline   Reply With Quote
Old 04-18-2013, 02:26 AM   #2144
rbbeauchemin1
Member#: 353355
2002 Impreza WRX
I've been in the market for new wheels and tires for my 06 wagon, and I found "Master thread of OEM Subaru Wheel Specs" to be helpful...
http://forums.nasioc.com/forums/show....php?t=2239019
Last edited by rbbeauchemin1; 04-21-2013 at 09:26 AM. Reason: Incorrect data on previous post
rbbeauchemin1 is offline   Reply With Quote
Old 04-18-2013, 03:10 AM   #2145
Breezio
Member#: 234357
2009 WRX
It seems to me you are over complicating the situation.
Wheel width isn't nearly as important as the tire width (concerning fender clearance), unless you are stretching the tire. And it's not really a stacking measurement (wheel width and tire width).
What matters in your situation is that you are keeping with the same offset and adding ~20mm of total tire width.
All that is going to do is 'use up' about 10mm of clearance on each side of the tire.
Old 04-18-2013, 04:13 AM   #2146
rbbeauchemin1
Member#: 353355
2002 Impreza WRX
So if I am understanding you correctly... If I keep the same offset, any change in wheel width is directed outward, and the distance from the inside end of the wheel to internal suspension components/obstructions remains constant?
Old 04-18-2013, 04:17 AM   #2147
sc00by4life
Member#: 97135
Originally Posted by rbbeauchemin1 View Post
Now that I have given some background information, MY QUESTION IS: Consider that I purchase the aforementioned wheel (18x7.5) with an offset to match my factory wheel (+55mm), does this effectively move my wheel IN or OUT 1.67 inches, or is the 1.67 inches shared on either side of the wheel? (.83 inch)? Also, to account for any inward tire/wheel movement, am I able to just purchase a wheel with a counteracting offset, or will I run into wheel bearing damage problems? Still very confused despite my attempts to configure it all...
**I understand that not all tires are the same, and that my math may be wrong, and that wheel widths can vary (it's 2am I don't really care anymore)**
Thanks
jesus ****ing christ dude. you over complicated it and confused yourself.
there isn't ANY 1.6whatever inches you are pulling out of your ass.
stop thinking about tire dimensions, as those only skew and **** up your calculations. figure out where the wheel sits within the fender FIRST then that can help you figure out how much tire you can get away with.
in terms of a 6.5" +55 wheel vs 7.5" +55.....look at the friggin width. there is only 1" difference between them. that should've been the biggest hint. I got side tracked again by your retarded thinking. THE DIFFERENCE BETWEEN where the wheel sits is 12mm outboard at the outter face, and 14mm inboard on the inner face. Meaning you'll have 12mm less outer clearance than stock, and 14mm less inner clearance than stock.
realistically you need to be shooting for a mid to high 40's offset on a 7.5" wheel.
not even close. as you can see above....a 6.5" +55 and 7.5" +55 are very different in terms of how they sit within the fenders.
just stop thinking.
Old 04-19-2013, 11:04 AM   #2148
Breezio
Member#: 234357
2009 WRX
No. If the offset of the wheel remains the same, any extra width you are adding (wider tires, etc..) will be added equally (essentially) to inside and outside. Example: 20mm wider tires, half the width (10mm) to the inside, and other half (10mm) going to the outside.
Old 05-18-2013, 05:19 PM   #2149
Kavanaghcr
Member#: 356804
2005 Subaru 2.5RS
Matt Grey
I just bought a 2005 2.5 RS. I had a toyota celica that i totalled and i still have my rims that are 18x9+35 (5x100 obvs) running on 225/40/18. Can someone confirm if these will fit without problem or will i need to work on fenders?
I tried searching but didnt find anything useful
Kavanaghcr is offline   Reply With Quote
Old 05-18-2013, 09:57 PM   #2150
sc00by4life
Member#: 97135
You'll need to roll fenders for sure.
You need to find out the center bore of the weeks though....Toyota uses a narrower hub bore than Subaru, so there's a high chance the wheels still won't fit.
That fitment and stretch will look pretty stupid at stock height.
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
