Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 11-21-2013, 09:02 PM   #2226
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Holy crap. I just tried to read this last page of this thread. Is this seriously 45 pages of people asking "will this wheel and/or tire combo fit my car"? Do some research people, damn.
02BlueSuperRoo is offline   Reply With Quote
Old 11-22-2013, 01:17 AM   #2227
05spyvsspy
Member#: 360360
I just picked up some 2010 Oem wrx wheels for my 2005 Wrx wagon. Specs are 17x7 with a +55 offset. Based on the guide on the first post is it a good idea to run these wheels due to offset being a bit more...
05spyvsspy is offline   Reply With Quote
Old 12-08-2013, 11:09 PM   #2228
mike06tr
Member#: 136810
2002 Impreza
Midnight Blue??
I want to get a set of diamond Racing Wheels in a 16x8 maybe 16x9 with a 245/50/16.
am I on the right track with a +45 offset??
mike06tr is offline   Reply With Quote
Old 01-02-2014, 09:09 AM   #2229
Vt_rdr
Member#: 363640
2010 WRX
I just picked up a set of rota grids for my 2010 wrx the wheels are 17x7.5 with a +48 offset, judging by the first post in this sticky I should be good to go, I was just hoping someone could confirm for me?
Vt_rdr is offline   Reply With Quote
Old 01-06-2014, 10:51 PM   #2230
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Yes you will be fine. Assuming you are going to be running stock size tires? (225/45R17)
Even if you bumped up to a 235/45R17 you will still be fine.
Breezio is offline   Reply With Quote
Old 01-14-2014, 03:04 AM   #2231
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Default 2011 wrx rim on 02 wrx
02 WRX
Whiteline coilovers 35mm drop, plus whiteline rear camber bolts.
Camber rear -1 , front -1.5, zero toe
Tire size 215/45/17 Bridgestone Adrenalin
I want to put on a set of OEM 2011 rims. Will they clear the spring perch? I test fitted them and there appears to be a few mm clearance between the rim and the perch on the rear. What is the min recommended clearance between the rim and spring perch at the rear?
OEM 2011 rim info from Master thread on OEM wheels
2011 WRX
Offset: +53
Bolt pattern: 5x100
runner19 is offline   Reply With Quote
Old 02-10-2014, 06:41 AM   #2232
Jeandre
Member#: 381262
03 Impreza wagon
Would 17x8.25 +35 rub on a 03 impreza wagon? ill be running 215/45/17 tires on them
Any info will be greatly appreciated!
Jeandre is offline   Reply With Quote
Old 02-13-2014, 12:56 AM   #2233
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
Do spacers help to increase or decrease a wheels offset? Example: taking a wheel with a +50 offest and adding a 5mm spacer. Did that just change the offset and if so which direction (up to +55 or down to +45)?
Preludicrous is offline   Reply With Quote
Old 02-13-2014, 01:08 AM   #2234
sc00by4life
Member#: 97135
so....if a +30 wheel sits closer to the fender than a +50 wheel.......
sc00by4life is online now   Reply With Quote
Old 03-02-2014, 05:43 PM   #2235
not2far
Member#: 382858
I found the best way to learn about fitment and how things work is to punch in sizes on a wheel/tire calculator and stare at it.
not2far is offline   Reply With Quote
Old 03-03-2014, 08:06 PM   #2236
GarethLawton
Member#: 377678
2006 WRX STI
so you didnt mention 8.5's as far as i can see. im looking at some 18x8.5's with a +55 offset they are off a newer subaru... by the looks of this thread that probably wont work... but i still gotta ask because they are so damn cheap!
GarethLawton is offline   Reply With Quote
Old 03-03-2014, 09:19 PM   #2237
sc00by4life
Member#: 97135
What wheels.
And what car do you have.
Old 03-04-2014, 02:30 AM   #2238
YouRock22
Member#: 373897
07 Impreza
newport blue
Is a +42 offset on 16x7 wheels too bad for 07 2.5i wagon?
Following the first post it's quite off the "Nirvana"...can anyone confirm?
Thanks.
YouRock22 is offline   Reply With Quote
Old 03-08-2014, 03:08 PM   #2239
Larkinnn
Member#: 382877
I have a 95 jdm wrx looking to get fender flares and 17s or 18s and thinking 9 or 10 wide. What would I need for a offset and will this fit my stock breaks wit no rubbing?
Thanks in advance!
Larkinnn is offline   Reply With Quote
Old 03-21-2014, 01:06 PM   #2240
10wrx89
Member#: 348974
2010 WRX Premium 5D
I have a 2010 wrx hatch, narrow body. I'm currently running OZ Supperleggera 17x7 et48. I'm on stock suspension. I'm going to get some 17x8 soon, but am wondering on what the lowest offset i can get before having to roll my fenders. Also, if i roll my fenders how much lower can i go?
10wrx89 is offline   Reply With Quote
Old 04-01-2014, 04:42 PM   #2241
schacal06
Member#: 339093
2013 SUBARU
RALLY BLUE
6.5" ....... +53 to +55
7.0" ....... +50 to +53
7.5" ....... +47 to +50
8.0" ....... +43 to +47
quick question so is the next fitment for ( 9.0" ...... +43 to +40 ) ????
been looking for wheels and trying to get some 18x9.0 or 9.5 for my 2013 STI.
not sure if im reading it right....
sorry if someone already asked this.
schacal06 is offline   Reply With Quote
Old 04-01-2014, 11:28 PM   #2242
sc00by4life
Member#: 97135
on the 08-14 sti and 11+ wrx - anywhere between 40-45 for an 18x9.5 is a perfect fitment as far as style and function.
Old 04-04-2014, 08:36 PM   #2243
schacal06
Member#: 339093
2013 SUBARU
RALLY BLUE
thanks
and what tire size you recommend ?
i seen on another thread some run 265/35 and 275/35.
i want that meaty look.
thanks!
Old 05-21-2014, 02:52 AM   #2244
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
Varrstoen 18x9.5 es6 with a +35 offset with a 235/40 18 tires. Will they work with just fender rolling or do I have to get rear camber adjustment. If so which would anyone recommend?? I have Tein basis coilovers. Thanx
tyrel.boyce is offline   Reply With Quote
Old 05-21-2014, 03:30 AM   #2245
sc00by4life
Member#: 97135
You haven't even told us what car you drive.
What year? Sedan? Wagon? What brand tires? You need to help us help you.
But in general if you have a GD you WILL need some from of rear camber control (ideally camber plates), and depending on how much you're lowered you'll need to do a bit more than just a roll.
Old 05-22-2014, 07:54 PM   #2246
fujigd9
Member#: 239274
99 Busted RS
Im sorry to do this but i really cant find if these wheels will fit or not and i figured this is the best place to ask.
I have a 99 rs with subaru red pots and i was looking to put 16x8 rpf1s on it but the only offset they come in is +35, does anyone know if they will clear the red pots or not, thanks in advance for any kind of info
fujigd9 is offline   Reply With Quote
Old 05-22-2014, 09:56 PM   #2247
SonicCasey
Member#: 377174
2003 Impreza WRX
Sonic Yellow
I have a 18x9.5 with a +30 offset wheel the way it's fitted is perfect. I found a new wheel I want but no +30 they only have +2... Would I need a wider wheel or more narrow wheel to keep my fitment the sAme. Iwhat size would be a near perfect match to the +30 wheel?
SonicCasey is offline   Reply With Quote
Old 05-23-2014, 04:01 AM   #2248
sc00by4life
Member#: 97135
I'm not trying to be a dick, but this is way over your head.
You need to find either the same exact wheel (make, model, size), or buy a brand new full set.
Old 05-23-2014, 10:42 AM   #2249
Breezio
Member#: 234357
2009 WRX
Pretty certain he's talking about a whole new set, just didn't pluralize the word structure.
However, running those kinds of setups, you really should already know what you need to do with the wheel width to maintain similar fender clearances....
Old 05-23-2014, 10:59 AM   #2250
BLkdubRX
Member#: 229971
2009 WRX
w/ SF hotbox
this.
BLkdubRX is offline   Reply With Quote
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 15 02-25-2006 06:48 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
