Old 03-25-2003, 01:49 PM   #1
Jduke
Member#: 29699
2005 Legacy GT Wagon
Red
Default UTEC compatible with Macintosh?
Hey all, I was wondering if the UTEC software is compatible with the Macintosh computers. Any info would be great!
Thanks,
John D.
Jduke is offline   Reply With Quote
Old 03-25-2003, 05:50 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
This might not be correct, but if the Mac has a HyperTerm emulator, it should work fine. But I have neither, so what do I know.
zaxrex is offline   Reply With Quote
Old 03-25-2003, 05:55 PM   #3
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Yes, you can use it with a Mac but you need a VT100 emulator (terminal software).
I don't have any specific recommendations but try a search.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 03-25-2003, 06:00 PM   #4
TurboXS (Pete)
Member#: 16704
Have a look at this thread.
http://www.wrxhackers.com/modules.ph...er=asc&start=0
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 03-25-2003, 06:06 PM   #5
BOFslime
Member#: 23845
2015 FLAT SIX
I assumed connections to the UTEC were using the serial port (RS232 or db9) connector.
mac is legacy free and thus doesn't have this port
vt100 is just a 'type' of terminal session, and telnet is defaulted to this, OS X is for the most part BSD, so i do not belive this is an os limitation but a hardware limitation. on os9 your out of luck compleatly. buy a cheap pc laptop and be done with it.
BOFslime is offline   Reply With Quote
Old 03-25-2003, 06:23 PM   #6
Fat Tits
Member#: 27046
Good Question!
_b
Fat Tits is offline   Reply With Quote
Old 03-25-2003, 07:01 PM   #7
Jduke
Member#: 29699
Red
Right on, yea thats what the unit uses. I have actually been looking at the cheap PC laptop direction. I looked around and basically what I found was what your saying. I am running OS 9 at home an OS X a work, but seems silly to switch, so I will be looking around (...ebay) for a used cheap PC.
Thanks,
john D.
Old 03-25-2003, 07:02 PM   #8
Jduke
Member#: 29699
Red
Right on, yea thats what the unit uses. I have actually been looking at the cheap ps laptop direction. I looked around and basically what I found was what your saying. I am running OS 9 at home an OS X a work, but seems silly to switch, so I will be looking around (...ebay) for a used cheap PC.
Thanks,
john D.
Old 03-25-2003, 07:21 PM   #9
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Here's a thread that talks about USB to serial connectors. I'd think that they'd work on a Mac.
http://forums.nasioc.com/forums/show...&highlight=usb
driggity is offline   Reply With Quote
Old 03-25-2003, 07:35 PM   #10
Jduke
Member#: 29699
Red
MacWise. thanks TurboXS (Pete).
WB compatibility with UTEC xcntrk75 Engine Management & Tuning 2 06-16-2005 07:57 AM
UTEC version 4 with 4.2 software compatable with 02 wrx? kx02wr Engine Management & Tuning 4 06-05-2005 10:31 PM
UTEC version 4 with 4.2 software compatible with 02 wrx? kx02wr Tri-State Area Forum 3 06-05-2005 12:06 AM
Newest Utec compatable with jdm ver.8 eng? serious Engine Management & Tuning 18 08-27-2004 12:25 PM
UTEC compatability Maulzar Private 'For Sale' Classifieds 3 03-01-2004 05:02 AM
