Old 03-25-2003, 10:54 PM   #1
Stevins
Member#: 33931
2001 Impreza RS
Question Rough Idle in Park
Hey all! Last week my dream came true when I bought a 2001 Impreza RS sedan. But there is someone thing that I question about the car when it idles. It seems kinda rough when the car sits in park. Its kinda a choppy, inconsistent idle. As soon as i put it in drive, its fine. The car only has 12,000 miles on it, i just did an oil change, and added fuel injector cleaner. Is this normal? Should I check the Plugs? If anyone has any suggestions or thinks this is normal, please let me know. If you live in the Philly area let me know, Im looking to get together and show off our rides.
Peace,
Matty S.
Stevins is offline   Reply With Quote
Old 03-26-2003, 02:15 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Boxer engines have inherently rough idles. What rpm level is it idling at?
Old 03-26-2003, 02:59 PM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
My girlfriend's Nissan was idling rough and low at around 400 rpms, and would stall the car if I turned the A/C on. I removed the throttle body boot and cleaned the throttle bottle, plate, and inside the TB with Throttle body cleaner. Itís critical that you use an approved Throttle body cleaner and not just a carburetor cleaner. The throttle body has parts that are Teflon coated and pure carb cleaner will eat this coating off. I used Valvoline SynPower Throttle Body and Carburetor Cleaner for $2. I wouldn't think that after 12,000 miles you would need to do this, but usually rough idling is a result of a dirty throttle body, fuel filter, air filter, or faulty injector. If all these check out o.k., check your distributor cap and rotor. You can check your injector(s) by using a long screwdriver and putting the tip against the injector. Put your ear against the handle while touching the injector with other end of the screwdriver and you should hear swishing and clicking if the injector is working. Or you could get a stethoscope. With only 12,000 miles on your car this is kind of mysterious. Most cars have a idle screw that can be adjusted but this would be my last resort. I'm not a mechanic but this is what I would do to troubleshoot if it were my car.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 03-26-2003, 07:22 PM   #4
Stevins
Member#: 33931
2001 Impreza RS
I think im idling round 800, ill have to double check.
Old 03-27-2003, 02:27 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
ok, ~700 is what it should idle at. Dont see any problems there...
Old 03-27-2003, 02:50 AM   #6
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Not go against the guru... but my 00RS has idled oh so smoothly since the day i got it with 20k miles on it. Now with over 82k its is just as smooth as it was when i bought it. A fluid job did quiet it a little though.
moogoob is offline   Reply With Quote
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-22-2009 11:28 PM
Slightly Rough Idle in New XT XT_Mike Forester Forum 12 04-12-2004 09:57 AM
99 outback rough idle when in drive limey60 Newbies & FAQs 1 03-01-2004 10:29 PM
Sputtering and rough idle in the cold? EEK! GooseMan Normally Aspirated Powertrain 6 02-15-2002 11:50 AM
