Old 03-26-2003, 12:06 AM   #1
skyhon
Member#: 13925
2002 Impreza 2.5RS
Default Installing Whiteline Front Strut Tower Bar in a 2002 2.5rs
Does anyone who owns a 2002 2.5rs tried to install a wrx whiteline front strutbar? I am having problem because the strut bar is interfering with the a/c hose. I tried to put the bar above and below the hose, but didn't have any luck. Please help.
I tried to do a search, but I was unable to find any info about this. thanks.
skyhon is offline   Reply With Quote
Old 03-26-2003, 08:45 AM   #2
Pat L.I.
Member#: 20498
2006 WRX TR
dont have a whiteline but i installed a cusco. My cusco came with extra hardware to lower the ac line but this can still be done with out it.
you need to unbolt the bracked that holds it to the car near the drivers side. it should be bolted on there with two screws, (it might help to take off the clamp that holds the hose first)
unbolt these two screws and move the line down gently (you wont break it at all, just dont be to rough on it) bolt the bracket back in using one bolt placing the top of the braket in the bottom hole. Reconnect the hose to the clamp so the hose is secure. Now you may just have to pull the ac line towards the front of the car and down slightly, this should give you enough clearance.
good luck.
Pat
Pat L.I. is offline   Reply With Quote
Old 03-26-2003, 10:59 AM   #3
spt_impreza
Member#: 3004
http://www.scoobymods.com/forums/sho...p?threadid=217
follow this first.....
I did it to my 02 OBS the other day...PITA!!!!
you can slowly and and gentley move the ca lines to fit around everything. I also removed that one bracket that holds the AC line.....I trimmed it (see filed) so that it would not rub anywhere....just keep at it and move things around unitl you fit it.
also when installing teh bar twist/lift the bar up slightly when you are tightening the allen bolts so that you wont hit your airbox and it wont come in contact with the AC or other lines running along the firewall.
spt
spt_impreza is offline   Reply With Quote
STL:IN: Whiteline Front Strut Tower Bar T3/T4 WRX Mid West Subaru Owners Club Forum -- MWSOC 0 09-28-2003 12:46 AM
STL: IN: Gauging interest Whiteline Front Strut tower bar T3/T4 WRX Private 'For Sale' Classifieds 0 09-03-2003 05:32 PM
FS local Whiteline front strut tower bar Davenow New England Impreza Club Forum -- NESIC 6 06-02-2003 07:06 AM
Whiteline front strut tower bar SilverSubi Brakes, Steering & Suspension 3 02-11-2002 01:48 AM
Best place to buy the Whiteline front strut tower bar? HIHO Legacy Forum 8 02-06-2002 01:38 AM
