Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 03-26-2003, 08:32 PM   #1
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Default 2004 Impreza TS/RS/WRX/STi headlight bulb sizes
For those of you who want to order your rice fake hid bulbs in advance!
2004 Impreza TS/RS/WRX:
Low Beam is H1
High Beam is 9005
Fog H3
2004 STi
Low Beam D2R HID
High Beam 9005
Parking light 168
Samirr76 is offline
Old 03-26-2003, 08:41 PM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
By my reading this means STI high beam is halogen....
ANZAC_1915 is offline
Old 03-26-2003, 09:10 PM   #3
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
of course, only BMW so far has HID high beams. I will also swap the D2R 4800k for a set of D2R 5400k for the slight blue/ice white beam. I think anything above 5400 in the HID range makes the light too blue/purple which sucks in lumens output.
zacek is offline
Old 03-26-2003, 11:01 PM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
hid high beams are probably not a good idea....u cant flash them quickly.
Samirr76 is offline
Old 03-27-2003, 09:43 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Not true, my wife's Saab has HID high beams and they do operate quickly.
It is the same main bulb as the headlights and switching on high beam lifts the auto levelling shutter right up exposing the entire beam pattern!!!
Very fast but also noisy (THUNK!)
I swear I said the STi didn't have HID high beam and someone said it did. I wonder where they got that from, the press releases? (ie is there a typo/error in them?)
Old 03-27-2003, 10:22 AM   #6
bluesubie
Member#: 767
04 FXT
Sam showing off with his inside info.
They probably couldn't get high-beam HID's past the Legal Department.
-Dennis
bluesubie is offline
Old 03-27-2003, 11:38 AM   #7
jsemmler
Member#: 16379
2004 STi WRB/Gold
from the press release at http://impreza.subaru.com
"The front fascia features four high-intensity discharge (HID) headlamps with smoke tinted lenses and distinctive STi fog light insert covers for a no-nonsense look."
four HID lamps would mean high and low beams, correct?
i sure hope so..
jsemmler is offline
Old 03-27-2003, 11:52 AM   #8
Nolift911
Member#: 33093
Nolift911 is offline
Old 03-27-2003, 02:30 PM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Why do people think high beam is used for DRL?
In any event, my wife's Saab has DRL which is the HID main beam switched on all the time. Same output.
Old 03-27-2003, 04:15 PM   #10
Nolift911
Member#: 33093
Well, on most cars becuase that is the case... hence the thought reasoning.
For most HID's systems they do not operate well or at all with the reduced voltage so how does the system work on your Saab?
From my rather basic understanding of Saabs and correct me if I am wrong here.... I thought that when the first bi-xenon lights were made commercially available, with a projector module featuring a shutter which rises to reveal the whole lamp on high beam.
However, the bi-xenon headlamp unit still retains halogen bulbs with separate, larger reflectors for the headlight flash function, which in Europ is an important safety feature. That Autobahn thingie and all...
Bi-Xenon systems are rather new to the HID arena and...correct me if I am wrong here the Saab system still uses a halogen bulb for flash to pass???
In any event it is a preference, they can be wired anyway you prefer, low beam, high beam etc. On my Jeep I wired the high beams...when HID's first emerged in the market DRL's had to find a new home due to low wattage.
Jeff
[email protected]
Old 03-27-2003, 04:30 PM   #11
JT-KGY
Member#: 7852
03 White Lan EVO 8
97 Techno-Violet BMW M3/2
only wish that the HID is projector type like the EVOs..
JT-KGY is offline
Old 03-27-2003, 05:51 PM   #12
Samirr76
Member#: 4835
2003 Baja 5MT
-Dennis
I dont think enough people would care about HID high beams to justify the added cost. I think most of us are thankful highbeams are available at all. Just put some overwatt Hella bulbs in the highs.
Samirr76 is offline
Old 03-27-2003, 05:53 PM   #13
Samirr76
Member#: 4835
2003 Baja 5MT
i sure hope so..
Thats not what they meant. There's so much new information and new equipment even the execs are bound to be confused at times. I looked up these specs on paper. Theres no HID high beam.
Hey....concentrate more on that 300hp 300 lb/ft dude!
Samirr76 is offline
Old 03-27-2003, 08:37 PM   #14
HOKWRX
Member#: 5469
2004 Impreza
High beam is NOT HID, we already saw the pic from the Detroit auto show.
HOKWRX is offline
Old 03-28-2003, 09:36 AM   #15
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Well, I've never seen any car with high beams as DRL, and it is a frequent complaint of senior citizens which has seemed unfounded to me.
My prior 3 Saabs had DRLs which were effectively "headlights on main beam" and the MY02 Imprezas use a resistor and main beam, not high beam. I've also had many rental cars with DRL, none using high beam/
For most HID's systems they do not operate well or at all with the reduced voltage so how does the system work on your Saab? From my rather basic understanding of Saabs and correct me if I am wrong here.... I thought that when the first bi-xenon lights were made commercially available, with a projector module featuring a shutter which rises to reveal the whole lamp on high beam.
Correct. And there is no difference in the beam, output or shutter height between DRL and "headlights on". In fact the only difference is that high beam will stay on rather than flash on, and fog lights are available in the "headlights on" mode, as in all previous Saabs. In "DRL" mode (headlights off) the headlights are on main beam (shutter down, level), and foglights are inop, and high beam will flash only, by raising the shutters (CLUNK!).
I recall reading in the Saab owners manual there was no high beam bulb. I could be wrong.
In any event, since the STi headlights are not auto levelling (no shutter) they need a halogen high beam.
Glenn
Old 03-28-2003, 10:04 AM   #16
Nolift911
Member#: 33093
Old 03-28-2003, 11:37 AM   #17
cboggess
Member#: 30804
87 Yugo
Red
My Saturn uses the highs as DRLs, but at a lower voltage than normal hi-beam operation. Man, I hate my saturn. I can hardly wait to trade up to the STi. Talk about a change in driving environment...
cboggess is offline
Old 03-28-2003, 11:52 AM   #18
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
What, you're not going to hold out for the Turbo Ion???
ha-evolution is offline
Old 03-28-2003, 01:52 PM   #19
HOKWRX
Member#: 5469
2004 Impreza
Most car use highbeam as DRL, but is a low powered highbeam. For example :WRX
HOKWRX is offline
Old 03-28-2003, 03:42 PM   #20
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I believe the WRX uses the low (main) beam, with a resistor.
I'm sure Jon will confirm/deny (I am away from my manuals).
06 wrx headlight bulb size BadNews06wrx Newbies & FAQs 6 09-08-2009 03:53 PM
FS: 2004 - 2005 2.5rs/wrx/sti headlights Harnicka Exterior/Styling 0 05-06-2009 04:18 AM
TS,RS,WRX,STI chassis-->The same? Mohammadov Newbies & FAQs 6 07-10-2007 09:43 PM
wtb:'04-'05 impreza rs/wrx/wrx STi headlights... obake_SARU81 Private 'Wanted' Classifieds 2 10-18-2006 07:56 AM
FS: 2004 Impreza RS/WRX/STi headlight protectors bluestone Tri-State Area Forum 3 02-29-2004 08:40 PM
