Notices
Old 03-27-2003, 08:43 AM   #1
Jejunum
Member#: 15773
2011 Impreza WRX
Default problem - fluctuating rpm at idle
So yesterday afternoon when I turned on my car my idle speed started fluctuating like crazy; from 1.7 K-> .8 -1.7. It did this once in the winter and stalled. Btw this is an automatic 02 RS - only modifications are ganzflow intake and eibach prokit springs
any ideas why? is this something I should be worried about?
Thanks all
Jejunum is offline   Reply With Quote
Old 03-27-2003, 08:50 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Possibly could be the IAC valve. They like to get gunked up on those models.
You can take them apart, see if there is a bunch of carbon and such in there, and if there is you can clean things up, and put it back together.
Legacy777 is offline   Reply With Quote
Old 03-27-2003, 08:53 AM   #3
Jejunum
Member#: 15773
2011 Impreza WRX
ok i have no idea what that means
if i take it to the dealership would they fix this? or know whats wrong?
or if this is something i could do myself give me instructions ?
hehe
Old 03-27-2003, 02:20 PM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
There are so many things that could contribute to a rough idle. Dirty Throttle Body, clogged PCV (it should rattle when you shake it and feel vacuum on it when running and out of valve cover), faulty injectors, as well as an assortment of ignition areas. I'm sure there are some I missed, but I hope you get it fixed.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 03-27-2003, 03:29 PM   #5
Jejunum
Member#: 15773
2011 Impreza WRX
There are so many things that could contribute to a rough idle. Dirty Throttle Body, clogged PVC (it should rattle when you shake it and feel vacuum on it when running and out of valve cover), faulty injectors, as well as an assortment of ignition areas. I'm sure there are some I missed, but I hope you get it fixed.
should i call the dealership up and tell them?
is the ganzflow gonna be an issue with them...freaking dealers
my problem with calling them up is the fact that the fluctuation doesnt happen consistenly
Old 03-27-2003, 03:41 PM   #6
Legacy777
Member#: 4800
hehe
It is something you can do yourself. Take a look at this thread.
http://forums.nasioc.com/forums/show...ight=IAC+valve
If you can find a picture of the same MY engine, I can point out which gadget is the Idle Air Control valve.
It's on the top of your throttle body.
Josh
Old 03-27-2003, 03:53 PM   #7
Jejunum
Member#: 15773
2011 Impreza WRX
would hte iac have gotten gunked up in only 1 yr of of driving?
oh and most importantly will the dealer fix this or say no u have a non stock intake...?
Old 03-27-2003, 06:28 PM   #8
Legacy777
Member#: 4800
It's possible and probable the dealer would give you hell since you have an intake.
I'd just take the little thing off and look and see if it's gummed up. If it is....clean it....if it's not....there's possibly some other issue.
It doesn't do the idle weirdness all the time does it?
I've got a buddy with a 99 RS that does something similar to yours.....we're pretty sure it's the IAC valve. We've been meaning to take it off and clean it, but just haven't got around to it.
Old 03-27-2003, 11:30 PM   #9
Jejunum
Member#: 15773
2011 Impreza WRX
nope not all the time; just randomly grr...
now to find a picture so u can give me explicit instructions (think instructions for the ... short bus)
Old 03-29-2003, 08:21 AM   #10
Jejunum
Member#: 15773
2011 Impreza WRX
bump; anyone got pics and instructions for me?
Old 03-29-2003, 11:21 PM   #11
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
my 99rs did that rough idel problem too but it ended up that it was becuase my intake was allowing it to much air and also one of the breather hoses had come undone and i didnt know it.. it was suckin it way to much air and the car was runnin like crap . i got a new intake and fixed all the breather hoses how the were supposed to be connected and the problem disapeard. good luck
PumpsGOTAWD is offline   Reply With Quote
Old 03-30-2003, 07:03 AM   #12
Jejunum
Member#: 15773
2011 Impreza WRX
breather hose?
i thoguht it was impossible to have an intake allow to much air in; one is always below the theoretical maximum
Old 03-30-2003, 01:09 PM   #13
Legacy777
Member#: 4800
breather hose?
The 99's are MAF based engines....so any air coming into the system after the MAF is unmetered, and will make the engine run worse.
Your RS is MAP based which has the sensor around the throttle body area.
Fluctuating RPM at a steady cruise thepigsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 02-17-2010 08:21 PM
Low RPM at idle dpk777 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-26-2007 12:43 PM
Bouncing RPM at Idle...? Chigae Normally Aspirated Powertrain 10 08-02-2006 10:28 AM
Fluctuating RPM at STEADY THROTTLE any RPM mnavarro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-21-2005 07:46 PM
RPMs at idle acting funny..? SjpWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2004 01:06 AM
