Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 03-27-2003, 12:19 PM   #1
bhodson
Member#: 34437
00 Public Transit
Subway and Trams
Question STI No A/C?
My Dealer just called and said they got in the brochures for the STi's and had just sent one out to me. They asy that athe car doec not come with Fog lights, Floor matts, Moon roof, Stereo or Air conditioning. I had heard or knew of all of these except the A/C it doen't bother me too much except for the defrost factor. Has antone else out there heard about the no A/C thing. Nice weight saver and less load on the engine.
bhodson is offline
Old 03-27-2003, 12:38 PM   #2
WRXPRESS
Member#: 393
1986 944T & Outback
Yellow & 99 Ducati 900ss
If you look on the center console pic It shows that the center button is for Air Conditioning.
As far as I know everything that cannot be installed by the dealer will be on the car. For example AC..
WRXPRESS is offline
Old 03-27-2003, 12:53 PM   #3
kenzo
Member#: 6422
2015 A4 Quattro MT6
Monsoon-like
Default Re: STI No A/C?
Who's your dealer?
kenzo is offline
Old 03-27-2003, 12:53 PM   #4
robmarch
Member#: 18713
06 CRV
04 STi
Subaru's previously released info said AC is standard.
robmarch is offline
Old 03-27-2003, 01:13 PM   #5
ToddStratton
Member#: 8351
2002 WRX Wagon
Remember, everything is "subject to change" as far as the features and specs go. It would be great for lowering the weight (and cost).
Alas, I think it may just be that your dealer mis-spoke about the A/C. We'll have to wait and see if any other dealers mention it.
Also, are these new brochures? Or the same ones that were released in Detroit in January?
TRS
ToddStratton is offline
Old 03-27-2003, 01:41 PM   #6
srad711
Member#: 12282
2004 STi silver
I just recvd the 2004 impreza line up brochure
states all imprezas come with ac, sti comes with semi automatic
ac.
It 100% comes with ac
the weight was listed as 3260 the heaviest impreza.
lists radio option as pre wired only
also the only impreza with interior filtration system
only impreza w. super abs system vs. standard abs
towing capacity 2000lbs
lists wheels as bbs 17x7.5 gold or gun metal
any other info just ask
thats what i remember off the top of my head
srad711 is offline
Old 03-27-2003, 01:44 PM   #7
STi Boy
Member#: 3401
2013 BRZ
WORLD RALLY BLUE
is it like auto climate control?
STi Boy is offline
Old 03-27-2003, 02:00 PM   #8
HOKWRX
Member#: 5469
2004 Impreza
semi automatic, like the RSX
HOKWRX is offline
Old 03-27-2003, 02:31 PM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
semi automatic, like the JDM WRX & STi.
ANZAC_1915 is offline
Old 03-27-2003, 02:50 PM   #10
Janq
Member#: 33246
Speaking of 'Super ABS', what exactly is that system and how does it differ from the 'regular' ABS system of lesser Impreza's?
- Janq
Janq is offline
Old 03-27-2003, 03:09 PM   #11
ToddStratton
Member#: 8351
2002 WRX Wagon
ac.
Well, that sounds like the closest thing to an official weight we've heard as well. That makes it lighter than the EVO...well 3 lbs lighter than the no sunroof one.
TRS
Old 03-27-2003, 03:11 PM   #12
ToddStratton
Member#: 8351
2002 WRX Wagon
- Janq
Here is a quote from the STi v7 AUS Technical Description:
The ‘Brembo’ braking system also comes equipped
with Super Sports ABS with Electronic Brake force
Distribution (EBD). This improves ABS performance
during cornering and reduces stopping distances with
greater stability under heavy braking.
Super Sports ABS uses input from a lateral ‘G’
sensor to individually control brake pressures more
accurately when ABS operates during hard cornering
under brakes, leading to reduced understeer.
Normally ABS would jointly control both rear
brakes to the same braking force when the inside wheel
loses traction, with a resultant increase in stopping distance and
cornering understeer. Under these same conditions Super Sports
ABS controls rear braking force individually leading to a
reduction in stopping distance and cornering understeer.
EBD due to electronic control more accurately regulates
brake force distribution between front & rear wheels to the
ideal level, thus improving stopping distances and stability.
Conventional braking systems rely on a mechanical
proportioning valve to limit the braking force at the rear wheels,
to reduce the possibility of rear wheel lock under heavy braking
due to weight transfer. A mechanical proportioning valve
however restricts rear-braking force to a level well below the
ideal limit, requiring the front brakes to take more of the
braking load. This leads to increased understeer and under
utilisation of the rear brakes.
TRS
Old 03-27-2003, 03:11 PM   #13
srad711
Member#: 12282
2004 STi silver
There was no descriptions of how any sti systems work or the differences between systems all of this was listed in the specifications area in the rear of the brochure. The sti consisted of about one page in the brochure.
The weight is 100% official but it may be like 3280
it was 3260 or 3280 I left the brochure at home
I got it late last night. But it is w/in 20lbs if not the exact weight
I stiil think it was 3260!!!
srad711 is offline
Old 03-27-2003, 03:15 PM   #14
ToddStratton
Member#: 8351
2002 WRX Wagon
For my third post in a row in this thread....
Did the brochure have a picture of the "gun metal" rims? Just asking because the "web survey" SOA sent out had "silver" rims.
TRS
Old 03-27-2003, 03:18 PM   #15
srad711
Member#: 12282
2004 STi silver
TRS
It did not give a picture of the gun metal
but it specifically stated the wheels gold or gun metal grey.
srad711 is offline
Old 03-27-2003, 03:47 PM   #16
Janq
Member#: 33246
TRS...thanks for the info!
Janq is offline
Old 03-27-2003, 03:48 PM   #17
HFTuRbo
Member#: 34388
04 WRX STi
Black w/gunmetal
Smile
No radio = weight saving! Sure... some, but they could have had crank (roll-up) windows to save weight. The missing standard sound system is no doubt from past feedback complaints and not to save weight. The 6 CD system in the WRX was perfectly fine with me and still is. I've had no problems with it. Most folks today want to have their own choice for tunes with satellite radio, DVD, or tracking devices, big amps, sub-woofers, etc... I think it Subaru's way of saying install what ya want! Most people will end up with something heavier than the offered 6 CD changer.
HFTuRbo is offline
Old 03-27-2003, 04:17 PM   #18
akm3
Member#: 9596
2007 Toyota
Prius
Actually, I have heard that electronic roll up windows weigh less then the old crank variety. Can anyone confirm this?
akm3 is offline
Old 03-27-2003, 07:00 PM   #19
97itr153
Member#: 17887
05 LGTW Ltd AT
05 Evo RS
can you scan this in for us. thanks.
97itr153 is offline
Old 03-27-2003, 08:21 PM   #20
srad711
Member#: 12282
2004 STi silver
listen I am not a computer guru, but i will scan it.
I will need some one to post it have no clue how to post it.
Help help
btw my apologies the exact weight was 3263 not the 3260 I posted earlier.
I have scanned the specifications pages, 3pgs who's up to help
srad711 is offline
Old 03-29-2003, 09:25 AM   #21
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Maybe Subaru's electric windows do. Ever notice how slow the Subarus windows are to put up and down? They are twice as slow as any other car I've ever put the windows up or down in.
Corn-Picker is online now
Old 03-30-2003, 06:03 PM   #22
brakemans
Member#: 22859
2005 Legacy GT
Someone please tell me how a semi-automatic air conditioning system works.
I've never even heard of this. Does it save on weight or something? What are the benfitis of it?
brakemans is offline
Old 03-30-2003, 06:09 PM   #23
Corn-Picker
Member#: 8679
2010 The most hated
It's not just hot or cold. You set the dial to a temperature, like 20°C, and the car keeps the temperature in that range. I think it's different from "fully automatic" air conditioning which is usually digital, and chooses which vents to blow air out of, and can have separate zones for the drivers and passenger. So I guess it will be slightly more advanced than the WRX's AC.
Old 03-30-2003, 07:35 PM   #24
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
MY DREAM CAR HAS ARRIVED!!!
how about no undercoating, rustproofing, or sound deadening?
ellisnc is offline
Old 03-31-2003, 09:04 AM   #25
mike of pa
Member#: 32152
Default STI No A/C?
Look at the PDF about the STI. It says that AC is not on the STI.
see the "--" which says below, "not available".
Mike
mike of pa is offline
Precat? WRX STi = no Forester XT = yes Jon [in CT] News & Rumors 17 11-29-2008 10:22 PM
IL: RSR GT2 Turbo back exhaust WRX STI NO RESTRICTIONS NO BAFFLES drale954 MWSOC Private Classifieds 2 11-19-2006 12:33 PM
2004 STi - No air conditioning? SGOSWRX STi Forum Archive 14 04-25-2003 09:04 AM
New STi...No Radio? sugar STi Forum Archive 86 01-08-2003 08:18 AM
