Old 03-27-2003, 06:23 PM   #1
SLowery
Member#: 15736
06 STI
crystal grey
Default Where to get oil pressure sensor
I got some gauges through a hook up but I need to get the oil pressure sensor. I was told to get a 1/8 BSP sensor, which I guess is really expensive (comparitively) or to get an adaptor and a less exensive size one. Can anyone give me some info to help me make a descision. And perhaps where to get the stuff.
thanks,
Slowery
SLowery is offline   Reply With Quote
Old 03-27-2003, 06:55 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
You need to get the oil pressure sensor that is made for your new gauge. So, if your gauge is made by Autometer, you need to get an Autometer oil pressure sensor. If it's a VDO, then you need a VDO sensor.
You can get the sensors from Summitracing.com, or practically any place that sells the gauge.
You may need an adapter to convert from 1/8BSPT to 1/8NPT. But, that really depends on the sensor and manufacture.
tmat3 is offline   Reply With Quote
Old 03-29-2003, 04:55 AM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I've had great service and prices dealing with www.egauges.com.
Old 03-30-2003, 04:23 PM   #4
stanton
Member#: 21508
'03 WRX Wagon
I, again, agree with armand1. Don's Sport Vehicle Sales, which is egauges.com was good to me. Good prices and shipped quickly. I haven't installed mine yet, but it looks like with the adapter, the whole thing won't fit well under the alternator (where the current pressure switch is). I plan to put in the other port under the intercooler.
I'm showing my invoice below for reference. The sender I bought is a combination unit with a pressure switch built-in. I probably could've gotten a better deal on the adapter bushing, but I didn't want to go searching too far.
Qty..Part No..Name.......................................... ............ Options..Price....Total....
.. 1..150-121..2 1/16?0-30 In.Hg. to 0-25 PSI?Turbocharger gauge? Vision............$27.30.. $27.30..
.. 1..310-153..2 1/16?250F-1650F?Pyrometer / EGT gauge? Vision.................... $120.00..$120.00..
.. 1..350-108..2 1/16?150 PSI?Elec. engine pressure gauge? Vision.................. $27.38.. $27.38..
.. 1..360-025..Pressure Sender: 0-150 PSI/10 Bar - 1/8-27 NPT - 11.4 PSI............$28.41.. $28.41..
.. 1..BPTNPT.. Adapter Bushing - 1/8 NPT female x 1/8-28BSP male.................... $6.00....$6.00..
stanton is offline   Reply With Quote
Old 03-31-2003, 10:01 PM   #5
TaiChih
Member#: 3467
1998 Dinan3
Bleck
1/8"BSPT and 1/8"npt is close enough to thread together for the sender, just use teflon tape to seal and make sure you screw it down tight, just not HULK tight.
TaiChih is offline   Reply With Quote
Old 04-02-2003, 04:02 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If oil weren't such a vital fluid for the car, I might try this, but why bother when you can easily get an adapter? Also, the happy VDO people recommend NOT using tape or sealant so as to make sure the sender gets properly grounded to the fitting.
Old 04-02-2003, 04:16 PM   #7
TaiChih
Member#: 3467
1998 Dinan3
Bleck
to each there own.
Old 04-02-2003, 05:04 PM   #8
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
The other thing is that the adapter is weak. I broke my autometer sending unit off of the block, leaving the threaded part in the block and the adapter on the sending unit. This happend when going over a speed bump in vegas, this made a big mess. I would remote mount it, with some steel braded lines.
Shane
PARANOID56 is offline   Reply With Quote
Old 04-11-2003, 02:22 PM   #9
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
FYI - Autometer has a 1/8" NPT to 1/8" BSPT adapter, part #2269 on their site.
chrislehr is offline   Reply With Quote
Old 04-12-2003, 11:44 PM   #10
tdxflex
Member#: 13634
if you ever take it apart after cross-threading npt and bspt, you'll see that some of the threads will get jagged and ruined, i've done it before. still useable but probably only to silicone gasket sealer only to make sure the seal is good.
tdxflex is offline   Reply With Quote
Where to monitor oil pressure Patrick Olsen Built Motor Discussion 43 07-08-2008 01:00 PM
Where to install oil pressure sensor? Alaskan EJ20 Alaskan Impreza Club Forum -- AKIC 10 02-21-2008 08:56 PM
JDM EJ207- Where to install oil pressure sensor jjameson Subaru Conversions 2 01-25-2006 07:23 PM
Where to put oil pressure sending unit? rok_toy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-09-2005 10:29 AM
Help - where to get oil pressure fittings CStearns Bay Area Impreza Club Forum -- BAIC 2 03-30-2002 11:01 PM
