Old 03-27-2003, 09:50 PM   #1
psaeko
Member#: 7057
Default Group N Sti top mounts vs. Stock STi top mounts
Can someone brief me on difference between these?
I have Group N Sti top mounts for fronts and stock Sti for rear
is there significant difference in terms of performance?
psaeko is offline   Reply With Quote
Old 03-28-2003, 08:20 PM   #2
Z1 Performance
Member#: 9327
STi= no such thing..the STi comes with the same mounts as your car came with.
STi Group N - the only strut top upgrade offered by STi.
Adam
Z1 Performance is offline   Reply With Quote
Old 03-31-2003, 02:17 PM   #3
savka
Member#: 12737
MY02 wagon 325/300
MBP
So if a vendor is selling STi top mounts how do we know weather they are simply new STi mounts (just like ours) or the upgraded STi grp N mounts?
Adam - do you have part numbers?
thanks
sav
savka is offline   Reply With Quote
Old 03-31-2003, 03:44 PM   #4
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Somehow im a tad confused also,,I bought the Ra takeoffs with supposedly the STi top mounts.There is def a difference between the stock tops and the Ra mounts for sure.Much harder rubber.So im not thinken they are the same as my stockers in anyway .Maybe not group N,but certainly not stock WRX.
Rudy
jagcars26 is offline   Reply With Quote
Old 03-31-2003, 05:53 PM   #5
Z1 Performance
Member#: 9327
The RA comes with the Group N mounts...the stad. STi does not.
STi part numbers for the rear are ST203704S000 (R) and S010 (L).
Front mounts are all the same dating back to the GC8 - part number is ST2031055000
Adam
Old 03-31-2003, 06:45 PM   #6
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
I would like to point out that STi is the tuning house that installs the harder mounts on the cars so they really are "STi mounts"...
They just may not be on all STi's...
mrbell is offline   Reply With Quote
Old 03-31-2003, 09:12 PM   #7
savka
Member#: 12737
MY02 wagon 325/300
MBP
Adam
So Adam these part numbers are for the STi mounts NOT Group N mounts correct?
(Do you have part numbers fro the gruop N mounts?)
Thanks for all the helpfull info sorry for being so dense
sav
Old 03-31-2003, 09:29 PM   #8
Bolster
Member#: 22290
2002 WRB WRX Wagon
My STi RA take-offs come in tomorrow. I'll have to check that part number.
Bolster is offline   Reply With Quote
Old 03-31-2003, 10:40 PM   #9
Z1 Performance
Member#: 9327
The part #'s above are for STi Group N mounts.
The standard STi model does not get these mounts..it gets the same mounts as the std WRX. Only the Spec C (aka RA) and S202 gets the Group N mounts as standard.
Adam
Old 03-31-2003, 11:48 PM   #10
savka
Member#: 12737
MY02 wagon 325/300
MBP
Adam
Thanks Adam
These are listed on Gruppe-s site under STi top mounts?
ST-2031055000 FRONT pair
ST-203704S0X0 REAR pair
does this seem correct?
Old 04-01-2003, 12:39 AM   #11
Tommy3kGT
Member#: 28572
2003 Subaru
I need to get new Top Mounts for my '03 WRX. Are the ones on the Gruppe-S Correct? the STI Front Pair for GDA?
Tommy3kGT is offline   Reply With Quote
Old 04-01-2003, 12:53 AM   #12
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Originally posted by savka
Thanks Adam
Well, those are the same as what Adam lists for the Group-N top mounts. I assume the X is in the rear because the part number is different from left to right
driggity is offline   Reply With Quote
Old 04-01-2003, 02:59 AM   #13
dbarnblatt
Member#: 7993
1997 SVX LSi
Red
Default So now I'm really confused...
So what's the issue with getting an STi top mount for STi/SPT struts. I was under the impression that the struts have to have the STi top mount or they will cause the car to bounce. If the standard STi has the same top mounts as the Standard WRX the SPT/STi struts should work fine without any STi topmounts installed. I would think the STi has harder mounts for the stiffer suspension.
dbarnblatt is offline   Reply With Quote
Old 04-01-2003, 12:18 PM   #14
gtguy
Member#: 2184
Platinum Silver Metallic
Default Re: So now I'm really confused...
Originally posted by dbarnblatt
So what's teh issue with getting an STi top mount for STi/SPT struts. I was under teh impression that teh struts have to have teh STi top mount or tehy will cause teh car to bounce. If teh standard STi has teh same top mounts as teh Standard WRX teh SPT/STi struts should work fine without any STi topmounts installed. I would think teh STi has harder mounts for teh stiffer suspension.
No, the STi struts don't NEED the Group N strut tops, though they can benefit from the addition of the strut tops in question, especially when running stock tire sizes.
Kevin
gtguy is offline   Reply With Quote
Old 04-01-2003, 12:47 PM   #15
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
The SPT suspension is the same as the STi RA suspension and the STi RA comes with the hardened strut tops. And like Kevin said, this is more of an issue with stock size tires. Since the STis all come with 17s this isn't as big a deal. I even noticed a nice improvement in the ride quality when increasing tire pressure on my car with the STi suspension and 215/45 17s.
Old 04-02-2003, 10:21 AM   #16
dbarnblatt
Member#: 7993
1997 SVX LSi
Red
Default So what should I do...
I ordered a set of STi take-offs from either an STi or an STi type RA... is there a way to tell when they arrive which top mounts are on them?
I will be installing these along with the aluminum arms and the complete bushing and swaybar kit. I have a set of UK 17" rims with 215/45-17 S-03 Potenzas.
Will I be OK with just the standard top mounts or should I be thinking of installing the Group N ones if it turns out that the struts I ordered have only the standard mount? I am thinking of the complaints that I hear of a bouncy ride quality without the firmer top mounts.
Old 04-02-2003, 11:18 AM   #17
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Well hopefully the strut tops have the part number on them. I never looked to see if mine did. I'd try them out and if you're happy with the ride leave them. If they aren't the hardened ones and you're unhappy then replace them. The installation is really easy. Especially the first time since you have the whole assembly in one piece.
Old 04-02-2003, 02:58 PM   #18
Bolster
Member#: 22290
2002 WRB WRX Wagon
Got my STi takeoffs today. Checked the part number on the tops against my factory strut tops- they're the same, so I didn't get group N tops.
Old 04-02-2003, 03:23 PM   #19
no_rex_yet
Member#: 7351
04 330cic
where are the numbers written? i'd like to check out my tops too.
no_rex_yet is offline   Reply With Quote
Old 04-02-2003, 04:33 PM   #20
Bolster
Member#: 22290
2002 WRB WRX Wagon
It's written in the rubber part of the fronts.
Old 04-03-2003, 09:43 PM   #21
trieula
Member#: 26767
2003 Impreza WRX
Silver Metallic
Where can I get the STI upper mounts? I tried ording it from Gruppe-S But they are out of stock. I need them ASAP.
trieula is offline   Reply With Quote
Old 04-04-2003, 09:51 AM   #22
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
bolster, where did you get your take-offs from?
peter
slater is offline   Reply With Quote
STi Heavy Duty engine mounts vs.Stock WRX engine mounts Aspenbullet Transmission (AT/MT) & Driveline 16 04-30-2008 08:13 AM
group n vs stock strut tops generalganja Brakes, Steering & Suspension 10 03-05-2007 10:26 PM
04 wrx top mounts vs. 04 STI top mounts! adizon Brakes, Steering & Suspension 2 06-16-2006 01:50 AM
Group N vs stock Sti strut tops zuczek Brakes, Steering & Suspension 7 03-07-2006 03:17 PM
