Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 03-23-2003, 09:37 PM   #1
NewbyScooby
Member#: 33710
Question Can I tap into the taillights to power a neon light in my trunk??
Hi,
I am looking for the best place to tap the positive side of a neon light in my trunk. I was thinking about the taillights, but I am not sure if that would dim the taillights? If I can tap into those without a problem what color wire do I tap into. I have a 95 Impreza.
Any info would be helpful
Tom
NewbyScooby is offline   Reply With Quote
Old 03-23-2003, 10:25 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
To the best of my knoledge...
You wouln't hve any problems using any of the 12+ wires in the tail lights, BUT they are all switched... Tail lights, blinkers, & reverse lights... (don't quote me on the reverse lights npositive or negitive switching)
If you want the neon on with the tail lights it shoud be fine; otherwise, you'll have to find a constant power
I don't know if there is a constant power back there (if that is what you want) such as a power outlet or trunk light. The other option is tap a fuse in the fuse box, add a switch some where, & run a seperate wire for the light.
GLwagon is offline   Reply With Quote
Old 03-23-2003, 10:32 PM   #3
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Do you know what the current draw of the light is? Somewhere on the unit or in the documentation it should say how many watts or amps or milliamps it draws.
It probably doesn't draw too much, but just check; I wouldn't put more than 5 or 10 watts of extra load constantly on that circuit.
As for finding out which wire to tap, I'd suggest taking a test light and probing each of them (you can disconnect the connector and probe its pins). It should only take you a few minutes. Test lights are very useful; if you don't have one, pick one up from an auto parts store for a buck or two.
vrg3 is offline   Reply With Quote
Old 03-23-2003, 11:12 PM   #4
NewbyScooby
Member#: 33710
Cool,
Thanks alot guys.
Old 03-25-2003, 09:06 PM   #5
STi-Nane
Member#: 18568
2006 7.5L Turbo
TypeR Rotary with Headers
i did this in my last car and i used the positive lead for the trunk light. If you don't have one, buy the switch from your dealer and hook the neon up to the pre-existing harness for the trunk light.
STi-Nane is offline   Reply With Quote
Old 03-26-2003, 07:44 PM   #6
NewbyScooby
Member#: 33710
Cool thanks man,
That sounds better than hooking it up to my tailights. This way it won't be on all the time.
Old 03-27-2003, 11:49 PM   #7
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Damn.. he beat me to it. I have two cold cathodes mounted under my amp rack that are wired this way. Works like a charm: open the hatch, cathodes light up.. close the hatch, they shut off.
lenyx is offline   Reply With Quote
Can you tap into the OEM Sub harness for an aftermarket sub? camelian Car Audio, Video & Security 4 05-16-2008 03:31 PM
Can I tap into 07 hid's without affecting eds2006 Electrical & Lighting 16 11-13-2007 05:46 PM
Can I tap into power source for the sideview mirror controls (by the handbrake) ImportVenom Electrical & Lighting 4 06-29-2004 11:20 PM
What wire do I tap to make a neon light go on when I turn my dash lights on? NewbyScooby Electrical & Lighting 2 03-27-2003 07:44 PM
What type of light in my JDM taillights? dRu888 Newbies & FAQs 8 04-17-2002 11:57 PM
