#1 |
Member#: 13745
RMIC
Vehicle:2004 STI Silver |
Has anyone removed this? Would it help or hinder performance? Also, would emissions be a problem?
#2 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & 97 OBS AWD 5MT EJ22T AWIC Swap |
You would probably pass without it. It's mainly there to help emissions in the morning.
It passes exhaust gasses back into the intake to help the car warm up faster. They are notorious for getting gunked up though with more miles.... |
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Actually, what EGR does is to lower NOx emissions by reducing combustion temperature. It has nothing to do with warmup and in fact it generally does not operate until the engine is up to temperature.
Engines with EGR do unfortunately tend to get significant carbon buildup in the intake, however one advantage of having it is that because it lowers the combustion temperatures it also reduces the tendency to knock, allowing for more aggressive timing. You can't just remove or disconnect it- you will get a CEL, and most likely some detonation since the timing maps are designed for the EGR being in place. Passing emissions without EGR would not be an issue with an idle test since the EGR does not operate at idle. On a dyno test the lack of EGR would cause an increase in NOx emissions which may or may not be a problem depending on the limits in the particular state and the overall condition of the car and emission system still in place. |
#4 |
Member#: 13745
RMIC
Ok, old cars didnt have it, and If I had my ECU retuned with it ripped out, would it be a plus or negative?
#5 |
Member#: 4800
TXIC
hmmmm.....I must be thinking of something else then....
#6 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
joefocker-your car has no EGR system
mulder-you are 100% correct. Good info sir. jeremy |
| Thread Tools | |
| Display Modes | |
| How does a correct EGR system function? | goodnight1985 | Service & Maintenance | 7 | 02-06-2010 10:17 AM |
| Wanted: Knock Sensor, EGR Solenoid, EGR Backpressure Sensor, Egr Valve | Quix | VIC Private Classifieds | 2 | 07-09-2008 04:09 PM |
| 96 LSI code 400 Best way to clean egr system? | pistoljeff | Service & Maintenance | 0 | 10-25-2006 08:16 PM |
| 96 LSI code 400 Best way to clean egr system? | pistoljeff | Normally Aspirated Powertrain | 0 | 10-25-2006 08:03 PM |
| Removing EGR-system for power.Questions | tonytiger | Normally Aspirated Powertrain | 10 | 12-03-2001 05:17 AM |
