Old 05-17-2001, 09:32 PM   #1
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Post Mileage experiment
I am going to tinker with my baby. I am going to do mods to my car to increase mileage. As of now it is stock, even the tire pressure is stock, 31 front 29 rear psi. I will try to do a tank by tank comparison. Today i put 13.5 u.s. gallons in and checked my trip meter. the magic number was 396.3 miles.Yes, 29+ mpg. that kicked butt. that is highway mostly. driving all week under 3000 rpm's was boring but thats the price i'm willing to pay.
For my next trick I will increase all tire pressure to 35 as recommended by my "I" club specialists and see how and if that helps.
I'll keep you posted.
p.s. future tests will be:
1. plugs/wires I may try several brands of plugs though magnecor will be the wires
2. some brand of ignition.
3. possibly an intake
4. possibly Borla headers & cat back
this is all a clever plot to get the wife to agree to "spend a little now to save alot later". wish me luck.
any suggestions are appreciated.
thanks
Tim Sanderson is offline   Reply With Quote
Old 05-18-2001, 06:11 AM   #2
Nat
Member#: 759
2004 WRX
2000 SV650
Thumbs up
I run 36F/32R all the time. Not that I do any wicked driving on the street, but it's nice for the occasional mountain road up here. I noticed a small gain in mileage when I switched over to a K&N and took out the resonator. More when I added the underdrive pulley, and even more with the cat-back and intake. Depending how I drive I can get up to around 33 or so on the highway with the cruise set around 70. Most of the time it's around 30, but depending on the tank it can go higher. Good luck and let us know how it goes!
Nat is offline   Reply With Quote
Old 05-18-2001, 06:17 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I've been getting 31mpg for past month.
My car has:
32/30psi
Stromung
Ganzflow
SAFC
My car uses:
Regular Hess gas
Currently at 15,000 miles with stock plugs, wires, air filters, etc.. And, I've been using a/c big time.
tmat3 is offline   Reply With Quote
Old 05-18-2001, 07:54 AM   #4
jzinckgra
Member#: 5584
Post
You'll have to be careful how you interpret your findings. Unless you were to drive the same routes, same speed, same shift patterns, etc. while changing one parameter at a time, it will be somewhat difficult to conclude that changing each one of those variable (eg-tire pressure) had any effect at all.
jzinckgra is offline   Reply With Quote
Old 05-18-2001, 08:15 AM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Post
Jz you've made a good point.
My route is the same every day. I shift very similarly every time, eccellerating smoothly to 3k rpm before each shift, not nailing it. i'm glad there is some interest here.
Old 05-18-2001, 08:56 AM   #6
Turboy
Member#: 5933
2004 WRX STi
Java Black Pearl
Post
When you're fully broken in, don't forget to switch to synthetic oil. I've used Mobil 1 in 5 different cars I've owned and it has always returned 8-12% mileage increases.
[This message has been edited by Turboy (edited May 18, 2001).]
Turboy is offline   Reply With Quote
Old 05-18-2001, 09:27 AM   #7
25psi
Member#: 3086
2001 2.5 RS
Post
Wona cheap GOOD mod that will surely work well?
Throw out crappy CHAMPIONS spark plugs and get NGK or Denso.
Eugene
25psi is offline   Reply With Quote
Student loans: Pleasant experience or miserable experience? affinity1 Off-Topic 12 12-20-2009 12:56 AM
Awesome experience w/ Puente Hills Subaru Service and a bad experience w/ Renick robsta1 Southern California Impreza Club Forum -- SCIC 13 07-04-2008 03:17 AM
High Mileage Oil in low mileage car? wopgenius Service & Maintenance 8 04-30-2008 04:29 PM
Anyone Experience the Winter Mileage Drop Yet? Ginseng New England Impreza Club Forum -- NESIC 26 11-02-2001 06:30 AM
any experiences with low gas mileage? the spacecowboy Normally Aspirated Powertrain 11 02-15-2001 06:54 AM
